  3. GatewayESP8266 compiler errors
3 Posts 2 Posters 934 Views 2 Watching
  • C Offline
    C Offline
    coolnicklas
    I couple of months ago I tried the GatewayESP8266 example together with Domoticz as a controller and it was a success.
    Now I have upgraded my environment to Arduino IDE 1.8.x MySensors 2.1.0 and latest Esp8266 board support. When I try compiling the example I run into a couple of compiler errors.
    If I define a controller address with
    #define MY_CONTROLLER_IP_ADDRESS 192,168,149,3
    I end up with following errors:
    ESP8266WiFi.h:39: In file included from
    GatewayESP8266nicke.ino:126: from
    WiFiClient.h: In instantiation of size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]
    MyGatewayTransportEthernet.cpp:207: required from here
    WiFiClient.h: 123:36: error: request for member 'available' in 'source', which is of non-class type 'char*
    size_t left = source.available()
    WiFiClient.h: 127:5: error: request for member 'read' in 'source', which is of non-class type 'char*
    This could be solved by changing
    nbytes = client.write(_ethernetMsg, strlen(_ethernetMsg));
    to
    nbytes = client.write(&_ethernetMsg[0], strlen(_ethernetMsg));
    If I enable
    #define MY_USE_UDP
    Even more errors will show up, for example:
    MyGatewayTransportEthernet.cpp: 303:14: error: no match for 'operator[]' (operand types are 'inputBuffer' and 'int')
    inputString[0].string[packet_size] = 0
    Is this a compatibility issue between any of the involved libraries?
    Or am I doing something wrong?
    • H Offline
      H Offline
      Running gateway in client-mode isn't supported by many controllers so I guess not many have tried this combination (with the ESP).
      Maybe you can post an issue over at github with your findings. A test sketch should probably also be created for our continuous integration, so this won't happen again.
      C 1 Reply Last reply
      • H hek
        C Offline
        C Offline
        coolnicklas
        @hek !
        Actually I remember now, that I did not run the gateway in client mode last time I used it with Domoticz. I used it in server mode. However I'll post this on github if it can be of any help.
        /Nicklas
        12.1k
