  3. light and relay turn on automatically !
12 Posts 3 Posters 4.3k Views 2 Watching
  • R
    R
    Reza
    hi guys
    i found 2 new strange problem!
    one problem is related to turn on light automatically ! i have some light with button . some time for example 3:00 AM relay auto turn on ! :O did anybody experience this ?
    second problem is related to LED on arduino (L) . some sensors (for example gas sensors) some time i see L led is bilinking fast and dont stop .stop just with power off/on.
    J scalzS 2 Replies Last reply
    • R Reza
      hi guys
      J
      J
      Jan Gatzke
      @Reza
      The LED blinks when the radio is active. This could be caused by a bug in your code. Can you share your sketch?
      The light turning in by itself could be a forgotten rule in your controller or maybe a neighbor using mysensors, too? :D
      R 1 Reply Last reply
      • J Jan Gatzke
        @Reza
        R
        R
        Reza
        @Jan-Gatzke
        thank you for answer.
        about blink i see this before ( bug in code ) and TX led was blink . but now L led is blink. 2 nodes have this problem . one a gas sensors, two is a relay 6 channel. this is strange because i use same code for other device , but for these ....
        my sketch:
        gas:
        #define MY_RF24_CHANNEL 0
        #define MY_NODE_ID 4
        #define MY_REPEATER_FEATURE
        #include <avr/wdt.h>
        #define CHILD_GAS 3
        int mq2 = A0;
        int value;
        uint16_t GAS;
        MyMessage msg(CHILD_GAS, V_HUM);
          pinMode(mq2, INPUT);
          wdt_enable(WDTO_4S);
        void presentation()  {
          sendSketchInfo("R_M Gas sensor", "1.0");
          present(CHILD_GAS, S_HUM);
            value = analogRead(mq2);
            Serial.print("LPG SENSOR : ");
            if (value <= 60)
              GAS = 0;
            else
              GAS = (value - 60) / 9.64;
            Serial.println(GAS);
            send(msg.set(GAS));
            wait(60000);
        relay:
        #define MY_TRANSPORT_WAIT_READY_MS 10000
        #define MY_NODE_ID 160
        #include <Bounce2.h>
        #define RELAY_ON 0
        #define RELAY_OFF 1
        #define A_ID 1
        #define B_ID 2
        #define C_ID 3
        #define D_ID 4
        #define E_ID 5
        #define F_ID 6
        const int buttonPinA = 14;
        const int buttonPinB = 15;
        const int buttonPinC = 16;
        const int buttonPinD = 17;
        const int buttonPinE = 18;
        const int buttonPinF = 19;
        const int relayPinA = 3;
        const int relayPinB = 4;
        const int relayPinC = 5;
        const int relayPinD = 6;
        const int relayPinE = 7;
        const int relayPinF = 8;
        int oldValueA = 0;
        int oldValueB = 0;
        int oldValueC = 0;
        int oldValueD = 0;
        int oldValueE = 0;
        int oldValueF = 0;
        unsigned long time_m;
        unsigned long a, b, c, d, e, f ;
        bool stateA = false;
        bool stateB = false;
        bool stateC = false;
        bool stateD = false;
        bool stateE = false;
        bool stateF = false;
        int trigger = 0;
        Bounce debouncerA = Bounce();
        Bounce debouncerB = Bounce();
        Bounce debouncerC = Bounce();
        Bounce debouncerD = Bounce();
        Bounce debouncerE = Bounce();
        Bounce debouncerF = Bounce();
        MyMessage msgA(A_ID, V_STATUS);
        MyMessage msgB(B_ID, V_STATUS);
        MyMessage msgC(C_ID, V_STATUS);
        MyMessage msgD(D_ID, V_STATUS);
        MyMessage msgE(E_ID, V_STATUS);
        MyMessage msgF(F_ID, V_STATUS);
          pinMode(buttonPinA, INPUT_PULLUP);
          pinMode(buttonPinB, INPUT_PULLUP);
          pinMode(buttonPinC, INPUT_PULLUP);
          pinMode(buttonPinD, INPUT_PULLUP);
          pinMode(buttonPinE, INPUT_PULLUP);
          pinMode(buttonPinF, INPUT_PULLUP);
          // After setting up the buttons, setup debouncer
          debouncerA.attach(buttonPinA);
          debouncerA.interval(5);
          debouncerB.attach(buttonPinB);
          debouncerB.interval(5);
          debouncerC.attach(buttonPinC);
          debouncerC.interval(5);
          debouncerD.attach(buttonPinD);
          debouncerD.interval(5);
          debouncerE.attach(buttonPinE);
          debouncerE.interval(5);
          debouncerF.attach(buttonPinF);
          debouncerF.interval(5);
          digitalWrite(relayPinA, RELAY_OFF);
          digitalWrite(relayPinB, RELAY_OFF);
          digitalWrite(relayPinC, RELAY_OFF);
          digitalWrite(relayPinD, RELAY_OFF);
          digitalWrite(relayPinE, RELAY_OFF);
          digitalWrite(relayPinF, RELAY_OFF);
          pinMode(relayPinA, OUTPUT);
          pinMode(relayPinB, OUTPUT);
          pinMode(relayPinC, OUTPUT);
          pinMode(relayPinD, OUTPUT);
          pinMode(relayPinE, OUTPUT);
          pinMode(relayPinF, OUTPUT);
          sendSketchInfo("Re.Mi RELAY6", "1.0");
          present(A_ID, S_LIGHT);
          present(B_ID, S_LIGHT);
          present(C_ID, S_LIGHT);
          present(D_ID, S_LIGHT);
          present(E_ID, S_LIGHT);
          present(F_ID, S_LIGHT);
            time_m = millis();
            a = time_m % 3600000;
            b = time_m % 3601000;
            c = time_m % 3602000;
            d = time_m % 3603000;
            e = time_m % 3604000;
            f = time_m % 3605000;
            if (a == 0) {
              send(msgA.set(stateA ? true : false), true);
            if (b ==0){
              send(msgB.set(stateB ? true : false), true);
            if (c==0){
              send(msgC.set(stateC ? true : false), true);
            if (d==0){
              send(msgD.set(stateD ? true : false), true);
            if (e==0){
              send(msgE.set(stateE ? true : false), true);
            if (f==0){
              send(msgF.set(stateF ? true : false), true);
            if (trigger == 0) {
            send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
            send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
            send(msgC.set(false));
            send(msgD.set(false));
            send(msgE.set(false));
            send(msgF.set(false));
            trigger = 1;
          debouncerA.update();
          // Get the update value
          int valueA = debouncerA.read();
          if (valueA != oldValueA && valueA == 0) {
            send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
          oldValueA = valueA;
          debouncerB.update();
          int valueB = debouncerB.read();
          if (valueB != oldValueB && valueB == 0) {
            send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
          oldValueB = valueB;
          debouncerC.update();
          int valueC = debouncerC.read();
          if (valueC != oldValueC && valueC == 0) {
            send(msgC.set(stateC ? false : true), true); // Send new state and request ack back
          oldValueC = valueC;
          debouncerD.update();
          int valueD = debouncerD.read();
          if (valueD != oldValueD && valueD == 0) {
            send(msgD.set(stateD ? false : true), true); // Send new state and request ack back
          oldValueD = valueD;
          debouncerE.update();
          int valueE = debouncerE.read();
          if (valueE != oldValueE && valueE == 0) {
            send(msgE.set(stateE ? false : true), true); // Send new state and request ack back
          oldValueE = valueE;
          debouncerF.update();
          int valueF = debouncerF.read();
          if (valueF != oldValueF && valueF == 0) {
            send(msgF.set(stateF ? false : true), true); // Send new state and request ack back
          oldValueF = valueF;
        wdt_reset();
            switch (message.sensor) {
              case 1:
                stateA = message.getBool();
                digitalWrite(message.sensor + 2, stateA ? RELAY_ON : RELAY_OFF);
                break;
              case 2:
                stateB = message.getBool();
                digitalWrite(message.sensor + 2 , stateB ? RELAY_ON : RELAY_OFF);
                break;
              case 3:
                stateC = message.getBool();
                digitalWrite(message.sensor + 2 , stateC ? RELAY_ON : RELAY_OFF);
                break;
              case 4:
                stateD = message.getBool();
                digitalWrite(message.sensor + 2 , stateD ? RELAY_ON : RELAY_OFF);
                break;
              case 5:
                stateE = message.getBool();
                digitalWrite(message.sensor + 2, stateE ? RELAY_ON : RELAY_OFF);
                break;
              case 6:
                stateF = message.getBool();
                digitalWrite(message.sensor + 2 , stateF ? RELAY_ON : RELAY_OFF);
                break;
            // Write some debug info
            Serial.println(message.sensor);
            Serial.print("from node:");
            Serial.println(message.sender);
        about light turning auto i have neighbor but we use several channel for network.
        what is forgetten rule in my controller ? please explain more. Could have other reasons? this is suddenly for example 3:00 AM o'clock a channel of relay turn on auto. i change relay module and radio and arduino but repeat again
        thank you
        J 1 Reply Last reply
        • R Reza
          @Jan-Gatzke
          my sketch:
          gas:
          #define CHILD_GAS 3
          int mq2 = A0;
          int value;
          uint16_t GAS;
              if (value <= 60)
                GAS = 0;
              else
              send(msg.set(GAS));
              wait(60000);
          relay:
          #define RELAY_ON 0
          #define RELAY_OFF 1
          #define A_ID 1
          #define B_ID 2
          #define C_ID 3
          #define D_ID 4
          #define E_ID 5
          #define F_ID 6
          int oldValueA = 0;
          int oldValueB = 0;
          int oldValueC = 0;
          int oldValueD = 0;
          int oldValueE = 0;
          int oldValueF = 0;
          int trigger = 0;
              time_m = millis();
              if (a == 0) {
              if (b ==0){
              if (c==0){
              if (d==0){
              if (e==0){
              if (f==0){
              if (trigger == 0) {
              trigger = 1;
            oldValueA = valueA;
            oldValueB = valueB;
            oldValueC = valueC;
            oldValueD = valueD;
            oldValueE = valueE;
            oldValueF = valueF;
          wdt_reset();
                case 1:
                  break;
                case 2:
                  break;
                case 3:
                  break;
                case 4:
                  break;
                case 5:
                  break;
                case 6:
                  break;
          thank you
          J
          J
          Jan Gatzke
          @Reza
          What do you mean with L led?
          The gas sensor is sending a value for every iteration of the loop. You should only send a new value to the controller if it changed (more than x). This way the node is always active and spamming the controller.
          I don't see anything wrong with the relay sketch.
          Regarding the self switching relay node I just wanted to say that I you should look for external reasons for this behaviour. Either the controller or another sender is telling the node to switch the relay on.
          • J Jan Gatzke
            @Reza
            R
            R
            Reza
            @Jan-Gatzke
            this led :
            i think blink led is not related to gas skatch because this problem is for both (relay and gas)
            is that possible my controller have problem ? because some time controller auto go to offline....
            • R Reza
              @Jan-Gatzke
              this led :
              J
              J
              Jan Gatzke
              @Reza
              Does the blinking stop when you shutdown the controller?
              • J Jan Gatzke
                @Reza
                R
                R
                Reza
                @Jan-Gatzke
                i dont test this . when start blink just i power off/on node and true again and after some sent command again blink.
                • scalzS
                  scalzS
                  the blinking led which doesn't stop without poweroff, makes me think:
                  • autoreset generated by brownout and power supply issues,
                  • wdt and bootloaders
                  perhaps the first one
                  J R 2 Replies Last reply
                  • scalzS scalz
                    J
                    J
                    Jan Gatzke
                    @scalz
                    He only wrote about a blinking led not about the whole node failing.
                    • scalzS scalz
                      R
                      R
                      Reza
                      @scalz thank you for answer . i use a power 5v 10A that share for 5 devices . 1 relay 6 channel. 2 gas sensors. 1temp sensor . 1 motion sensor. about WDT i dont use this for gas sensors sketch.thank you
                      • R Reza
                        hi guys
                        scalzS
                        scalzS
                        wrote on last edited by scalz
                        @Jan-Gatzke
                        I answered to his 2nd problem ;)
                        @Reza said in light and relay turn on automatically !:
                        In mcu there is a brownout mechanism which reset the mcu if its voltage falls below a threshold which is set by fuses.
                        Also, depending of the bootloader used, this "L" (in general 13 if i remember) blinks at startup.
                        Then if you have hw issues like relays, multiple sensors, radio which consumes too much it can reset. I'm not talking about input power supply but about the vcc provided by voltage regulator
                        The same kind of autoreset can happen with a bad bootloader and wrong wdt settings.
                        It's all covered in arduino forums. And here too, i don't remember the links.
                        Finally, and that can also triggers same kind of problems (weird behaviour etc..), is playing with AC voltage, relays, RF radios etc due to noise etc.. Add to this that when you don't care about filtering in those case, you will get a bad Signal-to-Noise Ratio for your radio and get a poor range and sensibility.
                        You can have a quick idea when to take care of this by reading this
                        http://hackaday.com/2017/01/26/pcb-design-guidelines-to-minimize-rf-transmissions/
                        • scalzS scalz
                          @Jan-Gatzke
                          R
                          R
                          Reza
                          @scalz very thank you :pray:
