  3. Raspberry PI 3 - Serial Gateway failing with Serial - write failed: Resource temporarily unavailable
4 Posts 3 Posters 2.1k Views 3 Watching
  • E
    E
    esawyja
    Hi all,
    Has anyone seen this before on a Raspberry PI, when I restart it is fine again
    root@mmm_gateway:~# systemctl status mysgw
    ● mysgw.service - MySensors Gateway daemon
    Loaded: loaded (/etc/systemd/system/mysgw.service; enabled)
    Active: active (running) since Mon 2017-02-20 10:06:27 SAST; 20h ago
    Main PID: 577 (mysgw)
    CGroup: /system.slice/mysgw.service
    └─577 /usr/local/bin/mysgw
    Feb 20 10:50:01 mmm_gateway mysgw[577]: Serial - write failed: Resource temporarily unavailable
    Feb 20 10:50:05 mmm_gateway mysgw[577]: Serial - write failed: Resource temporarily unavailable
    Feb 20 10:50:06 mmm_gateway mysgw[577]: Serial - write failed: Resource temporarily unavailable
    Feb 20 10:50:07 mmm_gateway mysgw[577]: Serial - write failed: Resource temporarily unavailable
    Feb 20 10:50:09 mmm_gateway mysgw[577]: Serial - write failed: Resource temporarily unavailable
    root@mmm_gateway:~#
    root@mmm_gateway:~# systemctl restart mysgw
    Active: active (running) since Tue 2017-02-21 07:03:21 SAST; 1s ago
    Main PID: 30189 (mysgw)
    └─30189 /usr/local/bin/mysgw
    Feb 21 07:03:21 mmm_gateway systemd[1]: Started MySensors Gateway daemon.
    Feb 21 07:03:21 mmm_gateway mysgw[30189]: Starting gateway...
    Feb 21 07:03:21 mmm_gateway mysgw[30189]: Protocol version - 2.1.1
    root@mmm_gateway:~#
    I don't see any errors in /var/log/messages
    Thanks!
      A Former User
      Doesn't the WiFi & Bluetooth on the RPi 3 use the serial port? Have you looked in to that?
      • E
        E
        esawyja
        mmmh I havent, but I don't use either on this implementation... Has not happened again.... Confusing...
          Consider using the ethernet gateway if you keep having trouble with the serial one
