  3. Celsius to Fahrenheit Conversion with HTU21DF
2 Posts 2 Posters 1.1k Views 2 Watching
  • I
    I
    irenla
    wrote on last edited by gohan
    I am building a humidity controller using the humidity and temperature sensor. So far everything is working correctly but I was wondering how I could get the temperature to read back in Fahrenheit rather than Celsius. I know the formula is 9/5*C+32=F but I don't know exactly how to get this to work with my code.
    Here is the code I have written:
    Code: [Select]
    #include <Wire.h>
    #include "Adafruit_HTU21DF.h"
    Adafruit_HTU21DF htu = Adafruit_HTU21DF ();
    int ledPin = 13;
    int relayPin = 9;
       pinMode (ledPin, OUTPUT);
       pinMode (relayPin, OUTPUT);
       Serial.begin(9600);
       Serial.println("HTU21DF Humidity Controller");
       if (!htu.begin()) {
         Serial.println("Couldn't find sensor!");
      if (htu.readHumidity()>=75) {
        Serial.print("Humidifier Off");
        digitalWrite(ledPin, LOW);
        digitalWrite(relayPin, LOW);
        Serial.print("\t\tTemp: "); Serial.print(htu.readTemperature());
        Serial.print("\t\tHum: "); Serial.println(htu.readHumidity());
      else {
        Serial.print("Humidifier On");
        digitalWrite(ledPin, HIGH);
        digitalWrite(relayPin, HIGH);
      delay(1000);
    This is the section of the file "Adafruit_HTU21DF.cpp" that deals with temperature:
    Code: [Select]
    float Adafruit_HTU21DF::readTemperature(void) {
      // OK lets ready!
      Wire.beginTransmission(HTU21DF_I2CADDR);
      Wire.write(HTU21DF_READTEMP);
      Wire.endTransmission();
      delay(50); // add delay between request and actual read!
      Wire.requestFrom(HTU21DF_I2CADDR, 3);
      while (!Wire.available()) {}
      uint16_t t = Wire.read();
      t <<= 8;
      t |= Wire.read();
      uint8_t crc = Wire.read();
      float temp = t;
      temp *= 175.72;
      temp /= 65536;
      temp -= 46.85;
      return temp;
    S 1 Reply Last reply
    • I irenla
      Code: [Select]
      #include <Wire.h>
      int ledPin = 13;
      int relayPin = 9;
         Serial.begin(9600);
         if (!htu.begin()) {
        else {
        delay(1000);
      Code: [Select]
        // OK lets ready!
        t <<= 8;
        t |= Wire.read();
        float temp = t;
        temp *= 175.72;
        temp /= 65536;
        temp -= 46.85;
        return temp;
      Scott Wilson
      @irenla
      You have probably already figured this out but try this.
      return temp;
      float tempF = (temp * 9.0) / 5.0 + 32.0;
      you get the idea now.
