  3. Atmega328+rfm69hw sleep mode consumption
3 Posts 2 Posters 2.4k Views 2 Watching
  • mar.conteM Offline
    mar.conteM Offline
    mar.conte
    Re: RFM69HW temp-humidity node
    i have a problem with atmega328p + rfm69hw. I have bootloader with bod disable for 8 mhz internal. The problem is not run in power mode when i wire rf69 to atmega with sketch lowpowerlab, radiohead, etc consumption near 5 mAh, but if upload simple sketch in atmega with avr/sleep library without rfm69 consumption is 30 uAh .What is the proble for you? The output pin 11 is HIGH when use sketch example lowpowerlab etc library!!!!
    M.C.
    P 1 Reply Last reply
    • mar.conteM mar.conte
      P Offline
      P Offline
      peres
      @mar.conte
      Hi, I'm in the same boat to.
      My RFM69HW(high power) + Arduino sleeps at 450uA.
      But RFM69W(low power) + Arduino sleeps at 5.6uA.
      My Arduino pro mini v2 alone, sleeps at 4.5uA.(info here)
      I have searched high and low for reported sleep current on RFM69HW, but none have come up. This is very sad, as RFM69HW is king on range.
      My same topic here.
      Please leave a note if you or anybody else find a solution to this.
      -peres
      mar.conteM 1 Reply Last reply
      • P peres
        @mar.conte
        My same topic here.
        -peres
        mar.conteM Offline
        mar.conteM Offline
        mar.conte
        @peres
        I have now resolved with good results by connecting a simple atmega328 to my rfm69hw, with a pir in sleep mode consumes
        About 100 micro, use 8mhz bootloader without
        Crystal, use mysensors library and nodemanager
        M.C.
