  3. Sending an integer >32767
7 Posts 4 Posters 2.2k Views 4 Watching
  • AndurilA
    AndurilA
    Anduril
    wrote on last edited by Anduril
    Hey there,
    I'm trying to send a value between 10.000 and 99.999, but as soon as it gets bigger than 32.767 (size of int16) I receive totally senseless numbers. Is there a way to send this big number e.g. with an int32? I use V_VAR1 as message type.
    Regards,
    Anduril
    F AWIA 2 Replies Last reply
    • AndurilA Anduril
      Hey there,
      Regards,
      Anduril
      F
      F
      flopp
      wrote on last edited by flopp
      @Anduril
      I have checked my sketches. But I don't know so much about code.
      double VAR1
      long VAR1
      Try if they work
      • AndurilA Anduril
        Hey there,
        Regards,
        Anduril
        AWIA
        AWIA
        AWI
        @Anduril Are you sending it from your sketch or the controller? If you are sending from the sketch make sure the "setter"
           // Setters for payload
            MyMessage& set(void* payload, uint8_t length);
            MyMessage& set(const char* value);
            MyMessage& set(uint8_t value);
            MyMessage& set(float value, uint8_t decimals);
            MyMessage& set(unsigned long value);
            MyMessage& set(long value);
            MyMessage& set(unsigned int value);
            MyMessage& set(int value);
        can recognize the variable as a type > int16. (long or unsigned long) i.e
        unsigned long variableToBeSend = 1234567 UL ;
        I assume the value is now 'overflowing' to a negative number.
        • AndurilA
          AndurilA
          Anduril
          I tried to send from controller. When sending 32768 the node 'received' 4294934528 (written to the serial monitor)...
          • AndurilA
            AndurilA
            Anduril
            well I did some further testing... sending e.g. 65000 from the node to the controller works, sending back 65001 does not. That seems more related to the controller (MyController) than MySensors. Maybe @jkandasa can help shine some light on this.
            • AndurilA
              AndurilA
              Anduril
              I found the problem... or to be honest @jkandasa found it. He told me in the MyController forum to check my receiving code and not use getInt() but getLong(). Thanks again to him.
              • AndurilA Anduril
                @Anduril great that you found the problem. Thanks for sharing the solution, it might help someone else in the future.
