  3. Arduino UNO ethernet gateway problem
20 Posts 4 Posters 9.6k Views 4 Watching
    Misna
    Hi!
    I'm just starting my Mysensors journey with building an ethernet gateway based on Arduino UNO.
    Parts I'm using:
    • Arduino UNO from somewhere on Aliexpress (link does not work anymore)
    • UNO ethernet shield from here: https://www.aliexpress.com/item/UNO-Shield-Ethernet-Shield-W5100-R3-Development-board-FOR-arduino/32341820750.html?spm=2114.13010608.0.0.lpQQAC
    • NRF24L-module from here: https://www.aliexpress.com/item/1sets-Special-promotions-1100-meter-long-distance-NRF24L01-PA-LNA-wireless-modules-with-antenna/32341792715.html?spm=2114.13010608.0.0.lpQQAC
    I connected the RF-module how described here: https://www.mysensors.org/build/ethernet_gateway
    A2 - MISO
    A1 - MOSI
    A0 - SCK
    6 - SCN
    5 - CE
    I uploaded the W5100 Gateway scetch and the device seems to be in a endless boot loop.
    Here's what I see in the serial monitor of Arduino IDE:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;!TSM:INIT:TSP FAIL
    0;255;3;0;9;TSM:FAIL:CNT=1
    0;255;3;0;9;TSM:FAIL:PDT
    0;255;3;0;9;TSM:FAIL:RE-INIT
    0;255;3;0;9;TSM:FAIL:CNT=2
    0;255;3;0;9;TSM:FAIL:CNT=3
    And here is the scetch:
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    //#define MY_IP_ADDRESS 192,168,178,66   // If this is disabled, DHCP is used to retrieve address
    #define MY_IP_RENEWAL_INTERVAL 60000
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    Boots33B 1 Reply Last reply
      I don't see any capacitor on vcc of radio module.
        Misna
        Hi!
        That is true. I thought that it was optional as described here. If you experience bad reception or if transmitted data never reaches destination, try adding a decoupling capacitor
        I can try adding a capasitor when I get home.
          Well... it depends on the source of the 3.3v, but looking at your picture you are taking power directly from arduino and that is for sure not able to supply enough power for a PA radio. Try also to set nrf24 power to MIN and start from there. If I were you I would use an adapter with voltage regulator from 5v to 3.3v that would make like easier. If you are going to add capacitor, put it as close as possible to radio module (you could solder on the other side of the pins.
          • M Misna
            Hi!
            Parts I'm using:
            A2 - MISO
            A1 - MOSI
            A0 - SCK
            6 - SCN
            5 - CE
            #define MY_SOFTSPI
            // Enable to UDP
            Boots33B
            Boots33B
            Boots33
            @Misna You have un-commented the line
            That will stop soft spi from being used. You should comment it back out. //#define MY_W5100_SPI_EN 4
            see this post for some more info and wiring hookup
              Misna
              wrote on last edited by Misna
              Hi!
              I commented the line #define MY_W5100_SPI_EN 4 and wired the module as described in the post linked.
              I also added this line: #define MY_RF24_PA_LEVEL RF24_PA_MIN to lower the power need.
              Tried to add this adapter board: https://www.aliexpress.com/item/New-Socket-Adapter-plate-Board-for-8Pin-NRF24L01-Wireless-Transceive-module-51/32655936568.html?spm=2114.13010608.0.0.WnqXqC
              Now this is what I'm getting with DHCP configuration:
              0;255;3;0;9;TSM:INIT:TSP OK
              0;255;3;0;9;TSM:INIT:GW MODE
              DHCP FAILURE...0;255;3;0;9;!MCO:BGN:TSP FAIL
              And with static IP:
              IP: 192.168.10.25
              0;255;3;0;9;MCO:BGN:STP
              Btw my versions used:
              • macOS 10.12.3
              • Arduino IDE 1.8.2
              • Arduino AVR Boards 1.6.18
              • MySensors library 2.1.1
              Still the board is somehow looping and does not appear to the network.
                Remember the capacitor.
                It's strange the ethernet is not getting the IP from DHCP
                  Misna
                  Yes it is and even the link lights wont light up on my switch. I'll try to add the capasitor tomorrow. I'll also try this with a regular radio module (without the antenna)
                    I hope you don't have a faulty shield as I had that cost me many hours of debugging for nothing
                    • M Misna
                      Boots33B
                      Boots33B
                      Boots33
                      wrote on last edited by Boots33
                      @Misna Don't know if this is still a problem but some time back there was an issue with certain versions of the Arduino IDE causing problems with the w5100 gateway.
                      You may need to roll back the IDE or board definitions and see if that fixes the problem. Have a look Here for a bit more info.
                      • A
                        A
                        ArduiSens
                        You will solve the problem when compiling your arduino sketch with IDE 1.6.8.
                        I have compiled my UNO with ethernet shield at top 2 minutes ago and now I have full contact with Domotics (on Synology NAS).
                        go for it!
                        MySensors 2.3.2; contr:Domoticz; layer: RS485, nRF24; gw: Ethernet, Serial
                          Misna
                          Hi!
                          Investigating this issue it seems that my chinese ethernet shield has the wrong kind of terminating resistors on the ethernet line as described here.
                          So first I'll try to apply the common fix for that problem (change the resistors) and then I'll get back to you.
                          Btw thanks for the awesome support!
                            Do you have a link for that fix? I may try to fix the faulty one that I have
                              Misna
                              Hi!
                              Sure. Here is the link: https://forum.arduino.cc/index.php?topic=351477.15
                              There are many options for the fix but the easiest is defined by klggi on page2 (just solder 2 100ohm resistors on the backside of the ethernet connector).
                              I'll try to apply this fix tomorrow evening, I'll get back to you on how it went.
                                On second thought maybe I'll skip the fixing, too much hassle to handle with SMD without proper tools :D
                                  Misna
                                  @gohan check the post by klggi. No need to touch the SMD's, just solder 2 regular resistors to the backside of the connector.
                                    Misna
                                    Evening!
                                    Happy to report that soldering the two resistors to the back fixed the problem!
                                    So no need to downgrade Arduino IDE etc..
                                      in fact i have that 511 resistor in the back of connector. What resistors did you use?
                                        Misna
                                        gohanG 1 Reply Last reply
                                        • M Misna
                                          @Misna Added the 2 100Ohms resistors and it seems it is working. Maybe I could order some more shields and complain again they are faulty and have them refunded and do this quick repair :D
                                          At least it would be a little revenge on the many hours I lost with this faulty shield
