  3. Watermark arduino 3.3 headache
5 Posts 3 Posters 4.0k Views 3 Watching
  • E
    E
    ecabanas
    Hi all,
    I'm programming a watermark sensor and an arduino 3.3v. I tried a lot of sketches and connections and did not work.
    Anybody used this sensor? does anybody has docs or sketch or pictures connecting...?
    I'm desperate!!!
    thank's
    Eduard
    AWIA 1 Reply Last reply
    • E ecabanas
      Hi all,
      I'm desperate!!!
      thank's
      Eduard
      AWIA
      AWIA
      AWI
      @ecabanas Reading from what is published on the watermark sensors it is "resistance" based. E.g. a couple of electrodes in a nice housing and corrosion resistant. Standard method of reading these sensors is determine resistance (Ohms law) by applying a (AC = reversing polarity) current and measuring the voltage over the sensor. Most of the moisture sketches are written this way. You need to know the "resistance / moisture curve" of the sensor.
      Can you show us what have and tried?
      • E
        E
        ecabanas
        wrote on last edited by ecabanas
        @AWI said in Watermark arduino 3.3 headache:
        how us
        Hi @AWI
        I tryied this hardware as a watermark: WATERMARK 200SS from http://www.irrometer.com/sensors.html
        My logger is a Sodag One based on arduino:
        http://support.sodaq.com/sodaq-one/
        I followed this schema to wire it because the One is working at 3.3V
        0_1491590848328_upload-39c6ebc4-f302-4310-9652-c23bc66734b4
        and this sketch
        I don't know if you need more info about it.
        Thank's
        Eduard
        //Tabular Serial Printing  of Leaf Sensor Signal Data - AgrHouse.com
        const int LeafSensor1=0;  //Leaf Sensor on Analog Pin 0
          Serial.begin(9600); //Start Serial Port with Baud = 9600
          Serial.println("Leaf Sensor Arduino Data Logger");  // AgriHouse.com
          Serial.println("\nAnalog Pin #\tRaw Value\tPercent");
          Serial.println("------------------------------------------");
          for (int i = 0; i < 10; i++)
            int val = analogRead(LeafSensor1);           //Read Leaf Sensor Pin A0
            int per = map(val, 0, 1023, 0, 100); //Convert to Percentage
            Serial.print("A0\t\t");
            Serial.print(val);
            Serial.print("\t\t");
            Serial.print(per);           //Print Percentage Analog Value
            Serial.println("%");         //Print % Sign and Newline
            delay(1000);                 //Wait 1 second, then repeat
        • E ecabanas
          how us
          Hi @AWI
          and this sketch
          Thank's
          Eduard
              Serial.print(val);
          AWIA
          AWIA
          AWI
          wrote on last edited by AWI
          @ecabanas Your sketch and circuit look fine to me. I don't know the Sodaq One, but should the line
          const int LeafSensor1=0; //Leaf Sensor on Analog Pin 0 not refer to pin "A0"...
          const int LeafSensor1=A0; //Leaf Sensor on Analog Pin 0 ?
          • P
            P
            pierrot10
            I hope your are still around about this topic.
            I very very oft read that we need to take twice the measure by inversing the polarity. As say the doc
            A special circuit is needed to measure the electrical resistance of the Watermark sensor. DC currents
            must not be allowed to flow through the wet part of the circuit, or else irreversible reactions
            will occur and spoil the readings. AC excitation avoids these problems, by reversing the polarity
            of the current many times per second, so that no net reaction takes place at either electrode
            In your above sketch, you do not inverse the polarity and it's look like you read 10 time with the same polarity.
            However, in the above schema, it look like you power (3.3 at the sensor) once the WATERMAK, and then 3.3 at the resistance.
            Could you explian me your sketch code? And what does the capacitor?
            Thank a lot..
