  3. Home Assistant
  4. HA 0.42.2 'Sensor has no attribute _battery_level' error
3 Posts 2 Posters 1.6k Views 2 Watching
  • proddyP
    proddyP
    proddy
    After the upgrade to 0.42.2 all my sensors are being rejected by HA because of the error:
    File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/mysensors.py", line 391, in device_state_attributes
        ATTR_BATTERY_LEVEL: node.battery_level,
      File "/home/homeassistant/.homeassistant/deps/mysensors/__init__.py", line 420, in battery_level
        return self._battery_level
    AttributeError: 'Sensor' object has no attribute '_battery_level'`
    I haven't tried rolling back to 0.41 or debugging the code yet. Wanted to throw it out there to see if anyone else has experienced similar behaviour?
    • proddyP proddy
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @proddy
      Are you using persistence with a pickle file? I think I've found a bug in that scenario.
      PR with fix:
      https://github.com/home-assistant/home-assistant/pull/7057
      • proddyP
        proddyP
        proddy
        Yes, I'm using the persistence & pickle file. The PR fixes the problem. Just tested with latest HA dev branch. Thanks for the quick answer Martin.
