  3. Multiple Sensors on Gateway
5 Posts 2 Posters 2.7k Views 2 Watching
  • numanxN
    numanxN
    numanx
    I Want to use multiple sensors (motion sensor, temperature, rain sensor etc) on one Arduino MEGA.
    For the moment I use a module with 4 relays, 2 Dallas temperature sensors, 1 motion sensor(I would like to change the sketch to use multiple motion sensor as the temperature example) and the problem is that I have to prioritize the sensors, for example I need update for the temperature sensors every 20-30 seconds but the motion sensor should update instantly.
    Here is my code based on the MySensors examples.
    // Debug
    // Partea cu Conexiunea la net
    #define MY_GATEWAY_ENC28J60
    #define MY_IP_ADDRESS 192,168,1,66
    #define MY_PORT 5003
    #include <UIPEthernet.h>
    // Sfarsit parte
    #include <OneWire.h>
    //==TEMP==
    #define ONE_WIRE_BUS 2 // Pin where dallase sensor is connected
    unsigned long SLEEP_TIME = 20000; // Sleep time between reads (in milliseconds)
    #define MAX_ATTACHED_DS18B20 1
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msgtemp(0,V_TEMP);
    //==TEMP==
    //==RELAY==
    #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    //==RELAY==
    //==MOTION==
    #define CHILD_ID_MISCARE 15   // Id of the sensor child
    unsigned long SEND_FREQUENCY = 10;              // Minimum time between send (in seconds). We don't want to spam the gateway.
    long lastDebounce = 0;
    long debounceDelay = 500;
    unsigned long lastSend;
    unsigned long currentTime;
    unsigned int isTripped =0;
    // Initialize motion message
    MyMessage msgmiscare(CHILD_ID_MISCARE, V_TRIPPED);
    void before()
      sensors.begin();
        pinMode(pin, OUTPUT);
      lastSend = -1;
    void presentation() {
      sendSketchInfo("Arduino SmartHub", "1.1");
      present(CHILD_ID_MISCARE, S_MOTION);
        present(sensor, S_BINARY);
         present(i, S_TEMP);
    //==MOTION==
      currentTime = millis();
    // Read digital motion value
      Serial.println(tripped);
      Serial.println(currentTime-lastSend);
    if ((isTripped==0) &&(tripped==1)) {
        Serial.println("tripped");
        send(msgmiscare.set(tripped?"1":"0"));  // Send tripped value to gw
        lastSend=currentTime;
        isTripped=1;
    if ((tripped==0) && (isTripped==1) && (currentTime - lastSend > 1000*SEND_FREQUENCY)){
        Serial.println("un-tripped");
        isTripped=0;
      //wait(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msgtemp.setSensor(i).set(temperature,1));
      wait(SLEEP_TIME);
    void receive(const MyMessage &message) //Loop for receiving messages
      if (message.type==V_STATUS) {
        // Change relay state
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
      How about using interrupts? You connect the pir sensors on the pins supporting interrupts.
      • numanxN
        numanxN
        numanx
        Thank you for your reply!
        The motion sensor part from the sketch works perfectly, the problem is with the temperature part.
        If I am using wait or sleep for temperature, arduino won't listen the motion sensor until the time elapses.
        If I am commenting the wait the sensor will spam the controller until the controller stop receiving data from arduino.
          That's my point, use interrupts that will "wake" the Arduino when pin changes status and process the pir signal
          • numanxN
            numanxN
            numanx
            @gohan I understand what you are saying but if I am doing in that way I will spam the controller with the interrupts(flaps) right now it works like this
            if pin=0 send the state of the pin(the next update is when pin state changes), if pin=1 send the state and wait for 10 seconds for the next update.
            For the moment I have found a solution with millis[if(time%frequency==0)]:
            time=millis()/1000;
            if(time%10 ==0)
            Any suggestion for improving this part?
