  3. Double Micro (nano) Ampere meter
54 Posts 9 Posters 23.4k Views 11 Watching
  • NeverDieN
    NeverDieN
    I received the red HX711 board with the metal can. What does the J1 solder jumper on the back do?
    Also, any mods I should make before attaching the metal lid (to, for example, speed up the sample rate?)
    NeverDieN 1 Reply Last reply
    • NeverDieN
      NeverDieN
      I threw together this wireless node for measuring and reporting sub-milliamp currents using an ADS1220. I hope to do the same now with the HX711. Since it's auxillary to the circuit being tested, the extra measurement time of the HX711 won't matter so much.
      • NeverDieN NeverDie
        NeverDieN
        NeverDieN
        #43
        The reference PCB in the HX711 datasheet (https://cdn.sparkfun.com/datasheets/Sensors/ForceFlex/hx711_english.pdf) does not show a J1. Whatever it is, AWI did not solder bridge his J1, at least not in the photographed version he posted.
        • korttomaK
          korttomaK
          korttoma
          Hi guyes!
          Finished my device yesterday but to my surprise the display is blank all the time when running the "Double Micro Ampere meter" sketch. I tested the display with the "Hello World!" example from the Lib and it seems to work. What might I be doing wrong?
          • Tomas
          • korttomaK
            korttomaK
            korttoma
            Seems like it cannot communicate with the HX711 so it gets stuck at "scale.begin"
            Need to look in to that. I'm using A3 and A6 for the dout and sck this should work right? Or do I have to use A0 and A1?
            • Tomas
            • korttomaK
              korttomaK
              korttoma
              Seems I can't use A6 since A6 and A7 are "Analog Exclusively Pins". Darn, need to disassemble and correct...
              • Tomas
              • Nca78N
                Nca78N
                Looking great !
                @NeverDie check the pinout of the IC on the datasheet and check if the jumper is connected to RATE pin on one side.
                korttomaK NeverDieN 2 Replies Last reply
                • Nca78N Nca78
                  Looking great !
                  korttomaK
                  korttomaK
                  korttoma
                  @Nca78 Seems to be working now :D I should not have deviated from the instructions :blush:
                  • Tomas
                  • korttomaK korttoma
                    Hi guyes!
                    NeverDieN
                    NeverDieN
                    #49
                    @korttoma
                    The banana plugs (is that what they are?) look very smart.
                    • Nca78N Nca78
                      Looking great !
                      NeverDieN
                      NeverDieN
                      #50
                      @Nca78 said in Double Micro (nano) Ampere meter:
                      Yup, it is. Thanks! Another mystery solved.
                      Nca78N 1 Reply Last reply
                        Nca78N
                        Nca78N
                        @NeverDie said in Double Micro (nano) Ampere meter:
                        Then you might have to solder it if you're not ready to very very patient :p
                        • Nca78N Nca78
                          I have the same problem, I don't have a jumper on my HX711 board so I soldered directly the pin of the IC with a small wire.
                          It has clearly improved things, but it's still slow so I will try to reduce number of samples and if it's not enough switch to TTP223 touch buttons in toggle mode, one to reset, one to change screen, so I will never miss a press.
                          NeverDieN
                          NeverDieN
                          I just now ordered these:
                          https://www.aliexpress.com/item/10PCS-LOT-Touch-Sensor-Jog-type-touch-module-capacitive-touch-buttons/32416625224.html?spm=2114.13010608.0.0.IOBe1p
                          Is it the kind you're using? I guess the solder bridge determines whether or not it latches?
                            Nca78N
                            Nca78N
                            wrote on last edited by Nca78
                            #53
                            Not using them yet. But using them for other boards and the "big" solder bridge in the corner is for adding a capacitor to set sensitivity (up to 50pF, the higher the less sensitive it is so by default it's at max sensitivity). Toggle mode is set using the the "B" tiny jumper in the middle of the board.
                            Jumper A is for AHLB pin, it inverses the logic level of the output.
                            • NeverDieN
                              NeverDieN
                              Once I decided to power the HX711 externally rather than through the solar node, it has turned out to be a nice little current monitor. Typical charging currents for indoor solar nodes that are far from windows is only around 50ua, and the HX711 seems good enough for monitoring charge currents at around that amount. :)
                              Thanks @AWI for posting the project!
