π¬ Micro (nano) ampere meter (double)
I am confused the 1k resistors seem to be wired differently in AWI photo's and Nca78 photo's.
I would like to build this but not certain how it is wired now@rmtucker said in π¬ Micro (nano) ampere meter (double):
I would like to build this but not certain how it is wired nowIf you do like drawn on my post from July 7, it works.
@Nca78 said in π¬ Micro (nano) ampere meter (double):
Are the blue and green resistors you have drawn on the back of the adc module the 1k resistors?
Have you soldered them on the other side? -
Have you soldered them on the other side?@rmtucker said in π¬ Micro (nano) ampere meter (double):
Have you soldered them on the other side?Yes & yes.
@rvendrame said in π¬ Micro (nano) ampere meter (double):
@Nca78 , my HX711 board looks like yours. I'm a bit confused on how to connect the J1 pins to the load / power. Can you share how did you connected it? Thx!
Soldering is a bit messy and not helping much to understand, so I did a (gorgeous) drawing. I think I'll frame that in my living room :D
And in case you want to increase the data rate
I had some spare time and all parts so decided to assemble ampere meter.
Firstly, the sketch has to be changed. The lib Button.h does not exist (it has been renamed). It has to be changed to JC_Button.h. This has to be added to setup {}:myBtn.begin();in order for the button to work.
My question is this - reading are jumping like a yo-yo despite having a separate power supply (power bank). After calibration, reading maybe +30% or -30% off needless to say that its drifting dynamically. So constant current of 120uA is read +90 or +150 jumping up and down. Is this the way this meter is supposed to work?
Can you make a schematic of this circuit please?
I need this project. -
@mfalkvidd If you have something related to this project, can you share it? (circuit schema or something)
@metceyn said in π¬ Micro (nano) ampere meter (double):
Hello, I will try to work again on this project in the coming days, I have made one years ago but reused (then broke !) the screen so it's not fonctional now. I will use another screen and make a functional one again as I will need it for some project.
@rvendrame sure, I'll do it tomorrow morning as I cannot do it right now. In case I forget, don't hesitate to ring me ;)
Hi to all,
These two resistors are 1K ? (betwen E+ and A+) and (E- and B+) ?
Need I use Diodes to ground ? -
Hi to all,
Need I use Diodes to ground ?@ligteltelecom said in π¬ Micro (nano) ampere meter (double):
There a way you may have a chance to correct me, I have ordered everything I will need to build this project. I need your help to make a Scheme and how to wire part and connect the load, I have to 2 days trying to figuring out but I yet I need to understand it. You are the last user who visited the project. Thank you in advance if you are able to. -
@mfalkvidd HI, There's a way you may help to do a circuit schema I am studying it, but yet I need to understand many thing how to wire it. If are able to. Thanks.
With your input, this post could be even better π
