  3. Any parallel interface accellerometers ?
lsm303dlhcaccellerometers
5 Posts 3 Posters 2.0k Views 3 Watching
  • N
    N
    ny51sens
    I have built a few projects using a few different 3 axis accelerometers, such as the LSM303DLHC. All of them used the i2c interface.
    I'm wondering if anyone knows of a somewhat similar device that can be connected to a microcontroller via a parallel (eg: 8 bit) interface ?
    AWIA 1 Reply Last reply
    • N ny51sens
      AWIA
      AWIA
      AWI
      @ny51sens The "standard" alternative would be the SPI (serial) interface. A parallel interface imho would be not very efficient considering the size of the information and relatively low sampling rates of the sensors.
      N 1 Reply Last reply
      • AWIA AWI
        N
        N
        ny51sens
        @AWI - looking at parallel so I can process data faster ... I can't save to pc at a rate fast enough to keep up with sampling rate.
        • N ny51sens
          AWIA
          AWIA
          AWI
          @ny51sens I'm curious what kind of application you are looking at. You can take a look at ADXL377 (analog sensor) and use whatever kind of ADC to read parallel at enormous speeds..
          • pansenP
            pansenP
            pansen
            SPI can be blazing fast. A colleague of mine recently implemented some memory interface in the range of two/three digit MBits per second. Intuitively I would say bit banging an 8 bit parallel data input using a microcontroller is slower than using high-speed SPI. Just polling the 8 bits from the pins will take ages...Of course I am assuming you're using a uc and not a FPGA.
            You need to be precise, just because you can read data faster doesn't mean you can process it faster. I'd be a bit shocked to hear that an accelerometer could produce more data than a standard uc SPI can take...but then, I also have no experience.
            So I'm also curious what you are planning to do!
            Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
