  3. Noob problem with NodeMCU and OneWire
6 Posts 5 Posters 2.8k Views 3 Watching
  • E
    E
    emme
    Ciao to all,
    I'm moving to MySensors network in my home to be used with Domoticz... after a first phase made by a gateway on a raspberry PI2, a rain (on/off), I'm now approaching to reorganize the entire network and move to a nodeMCU (12e) gateway which include the rain sensor and I would like to add a DS18B20 too (to gather external temp)
    While the gateway and the on/off switch works pretty fine, I'm having a bad problem with OneWire: even if the sketch is compiled with no error, I see no device, nr presented, nor updated, no device at all
    Wirings are ok: using D1 pin (no luck with other pins), with a 4k7 resistor... 3.3v are provided from an external 5v (2A) power supply and a AMS1117 3.3
    I checked the same sketch on a ATMega328p nano and it works... seems to be a NodeMCU device issue
    does anyone experienced the same?
    Is there a solution for this (which does not include to move to DHT22 :P :P )
    thanks
    ciao
    • E emme
      Ciao to all,
      thanks
      ciao
      @emme welcome to the MySensors community. Are you still stuck on this? If so, could you post your sketch and describe all your wiring?
      • E
        E
        emme
        still unsolved, but workaround by replacing the onewire with a DHT22 :P :P
        this is my sketch:
        // Gateway MySensors on NodeMCU with some Devices
        // OneWire for DS18B20
        // Bounce for S_DOOR (Rain Sensor)
        #define MY_BAUD_RATE 115200
        // #define MY_GATEWAY_SERIAL
        #define MY_GATEWAY_ESP8266
        #define MY_ESP8266_SSID "myWiFi"
        #define MY_ESP8266_PASSWORD "******"
        #define MY_ESP8266_HOSTNAME "sensor-gateway"
        #define MY_PORT 5003
        #define MY_GATEWAY_MAX_CLIENTS 3
        #include <ESP8266WiFi.h>
        #include <OneWire.h>
        #define ONE_WIRE_BUS D1 // Pin where dallase sensor is connected
        #define MAX_ATTACHED_DS18B20 5
        unsigned long temp_Sleep = 30000; // Sleep time between reads (in milliseconds)
        unsigned long temp_nTime;
        OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices
        int numSensors=0;
        bool receivedConfig = false;
        bool metric = true;
        MyMessage msgTemp(0,V_TEMP);
        #include <Bounce2.h>
        // RAIN Sensor Definitions and settings
        #define CHILD_ID 10
        #define BUTTON_PIN D4  // Arduino Digital I/O pin for button/reed switch
        Bounce debouncer = Bounce();
        int oldValue=-1;
        MyMessage msgRain(CHILD_ID,V_TRIPPED);
        unsigned long cTime;  // Current Time
        void before()
          sensors.begin();
          pinMode(BUTTON_PIN,INPUT);
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
        void presentation() {
          sendSketchInfo("Temperature Sensor", "1.1");
             present(i, S_TEMP);
          present(CHILD_ID, S_DOOR);
          cTime = millis();  // Get current Timing
          if ((cTime - temp_nTime) >= temp_Sleep) {     // this is supposed to replace the sleep function
              float temperature = static_cast<float>(static_cast<int>(sensors.getTempCByIndex(i)));
              #if COMPARE_TEMP == 1
              #else
                send(msgTemp.setSensor(i).set(temperature,1));
            temp_nTime = millis();
          debouncer.update();
          int value = debouncer.read();
          if (value != oldValue) {
             // Send in the new value
             send(msgRain.set(value==HIGH ? 1 : 0));
             oldValue = value;
        if I enter a
        Serial.print("Sensors Count over 1W bus: ");
        Serial.println(sensors.getDeviceCount());
        I got 0 :(
        wirings are ok... I checked with the tester and I get correct voltage (3,3) and impedence (4,7k)
        DHT works fine at first try on the same PIN
        thanks for the help
        ciao
        Marco
        • B
          B
          bagou91
          I have exactly the same issue with ESP8266 nodemcu as Gateway + sensor DHT22.
          I tested with 2 different libraries DHT22.
          And I also tested with mySensors 2.1.0 and 2.1.1
          Console serial write out: Failed reading from DHT
          Otherwise the gateway works well without sensor (so alone) and with the DHT22 sensor on a node (arduino nano)
            I'm moving to I2C sensors to avoid these kinds of problems 😀
            • sundberg84S
              I tried with two different Dallas Onewire and checked out the library at github. Have build these sensors before but got -127 all the time. Just adding this here if it pops up alof of people having issues...
