  3. 💬 NModule
💬 NModule
mysensorsnmoduletemperaturedoorlightpirhumidityrelaymilighttouchaccelerometer
89 Posts 12 Posters 30.2k Views 10 Watching
  • Z zmatokan
    @Nca78 Thanks! I'l check what you suggested.
    If I would use:
    • 5v power supply
    • 5v arduino
    • 5v motion sensor
    i would need to
    • remove onboard arduino voltage regulator
    • connect RAW and GND to the 5v powersupply
    • add radio volt regulator and capacitor
    • soldier JPOWER
    And if i use:
    5v power supply
    3,3v arduino
    3v sensor
    i would need to:
    • add 3.3V AMS1117
    • add radio capacitor
    • soldier JRADIO
    Thanks man!
    Nca78N
    Nca78N
    @zmatokan said in 💬 NModule:
    @Nca78
    If I would use:
    • 5v power supply
    • 5v arduino
    • 5v motion sensor
    i would need to
    • soldier JPOWER
    Yes. If your sensor can work with the voltage drop of the arduino regulator (I think yes), you can also keep it and leave JPOWER open. Less risky and you might have a "cleaner" power for the motion sensor.
    And if i use:
    5v power supply
    3,3v arduino
    3v sensor
    i would need to:
    • add 3.3V AMS1117
    • soldier JRADIO
    No, with a normal SMD radio the onboard regulator of the promini will be enough to supply power to board + radio + i2C sensors. So keep the arduino regulator, don't add an AMS1117, leave JPOWER opened, solder JRADIO.
    Z 1 Reply Last reply
    • G
      G
      ghiglie
      Hi there! In these days I got some boards from my drawer - I spare quite a lot, I ordered 10 panelized one, so I have 40 NModules! :O :smiley:
      4 sensors are yet running on battery (2 on CR2032 and 2 with with 2xAA). The fifth module had an accident and I need to program it via SPI. is it safe to flash it with the antenna still soldered?
      atmega328p serial killer
      HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
      Nca78N 1 Reply Last reply
      • G ghiglie
        Nca78N
        Nca78N
        @ghiglie said in 💬 NModule:
        Haha that's a lot of boards. May I know what the accident was ? There was a case of a nmodule having a shortcut when manipulated, is it something similar ?
        The radio SPI pins can handle 5V but not it's power supply. So as you have no regulator on radio for these boards, I see 3 choices :
        1. best one = use a programmer running at 3.3V and you can power the board & radio with it. 100% safe. You can do this with the ArduinoISP sketch, a 3.3V pro mini and a ftdi adapter.
        2. if you only have a 5V powered programmer, power the board separately and connect only the SPI pins with the 5V programmer. But this is out of spec as the voltage on SPI pins will be higher than VCC + 0.5V
        3. open the JRDIO jumper so that the radio is not connected to VCC and use 5V programmer for SPI pins + power supply of the board. In that case to respect the datasheet of NRF24 you need to supply separately at least 3V to VCC radio, else you are in the same situation than point 2, but with the radio and that is I think a worse situation so in that case solution 2. is safer.
        G 1 Reply Last reply
        • Nca78N Nca78
          G
          G
          ghiglie
          @Nca78 said in 💬 NModule:
          Oh, easy! I already had soldered TX/RX pins and the angled ones (towards the atmega). I decide to take them off and reverse the angled... Iron's temperature was quite high... Some tracks got as bright as old 100W bulbs filament! :D
          I'm yet programming it with ArduinoISP on a genuine UNO, so I'm safe. I'll solder the SMD antenna ASAP, the TH one isn't bearable once you see how slim the node gets with your PCB!
          • G
            G
            ghiglie
            wrote on last edited by ghiglie
            #85
            Ok, just for record: be very very very very very carefull when desoldering the regulator+led+resistance. Do it before soldering the ping legs on module: I had a pair of nodes, correctly running, beatyfully soldered, legs trimmed... and darn, dunno what I did on tracks, they are not powering up anymore.
            Luckily I could desolder the antenna from under the PCB and stick on another (the first I told) and put the other as spare.
            Oh, I love DIY when I fix my errors! :laughing:
            {update: one sensor died yesterday. Maybe my Minis are too cheap? }
            • Nca78N Nca78
              @Nca78
              If I would use:
              • 5v power supply
              • 5v arduino
              • 5v motion sensor
              i would need to
              • soldier JPOWER
              And if i use:
              5v power supply
              3,3v arduino
              3v sensor
              i would need to:
              • add 3.3V AMS1117
              • soldier JRADIO
              Z
              Z
              zmatokan
              @Nca78 Thanks man! I managed to make it work. Seems like the problem was with radio modules. Now it works fine!
              • Z zmatokan
                Nca78N
                Nca78N
                Happy to hear that, thank you for the feedback !
                • Nca78N Nca78
                  Z
                  Z
                  zmatokan
                  wrote on last edited by zmatokan
                  #88
                  @Nca78 Are you still working on this pcbs? i think it would be great to add a version that supports HiLink 220ac->5dc module on powerboard.
                  • Z zmatokan
                    Nca78N
                    Nca78N
                    No I'm not working on NModules anymore, I have a few old nodes using atmega/nrf24 but I switched to NRF5 for "basic" nodes now, and to ESP32 for more "advanced" stuff.
                    NModule was designed for beginner and simple/riskless use, so I don't think adding high voltage option is a great idea, it's better to use an external power supply and connect the output to the powerboard.
