  3. Sensor "persistence"?
26 Posts 2 Posters 7.3k Views 3 Watching
  • I
    I
    iahim67
    Hi, I'm new to mysensors, like it very much!
    I noticed a weird (from my point of view) behavior of the examples available in the Arduino "mysensors" library.
    To get the examples working (like the Dimmable LED or Relay Actuator, etc.) with Domoticz for example this is what I need to do:
    1. Start Domoticz (on a raspberry pi)
    2. Connect the serial gateway (Arduino nano)
    3. Download the example firmware into the sensor (Arduino mini pro or nano)
      Fine so far, but if I power off the sensor and then power it on again it will not work any more, Domoticz and the gateway will not "see" the sensor until I re-flash the sensor.
      My question is how can I overcome that? What shall I do to avoid always re-flashing the sensor after powering it off?
      Interesting to say, if I power off the raspberry pi and the gateway then power on again both the sensor will still work assuming the sensor was not powered off.
      Seems like the gateway can only recognize the sensor once, after flashing the sensor code.
      Happens with both Domoticz and MyController.
      What am i doing wrong?
    • tbowmoT
      tbowmoT
      tbowmo
      What example firmware do you use for the sensor node?
      • I
        I
        iahim67
        I have used the Motion Sensor example, Relay Actuator, DimmableLED Actuator, Temperature ... I am uploading a few sketches:
        0_1496830979756_RelayActuator.ino
        0_1496831036727_TH_and_RELAY.ino
        0_1496831051014_TH1.ino
        0_1496831066368_MotionSensor.ino
        The gateway is this:
        0_1496831118872_GatewaySerial.ino
        Thanks!
        • I
          I
          iahim67
          If viewing my uploads is problematic, I'll copy paste some code below:
          The serial gateway:
          • The MySensors Arduino library handles the wireless radio link and protocol
          • between your home built sensors/actuators and HA controller of choice.
          • The sensors forms a self healing radio network with optional repeaters. Each
          • repeater and gateway builds a routing tables in EEPROM which keeps track of the
          • network topology allowing messages to be routed to nodes.
          • Created by Henrik Ekblad henrik.ekblad@mysensors.org
          • Copyright (C) 2013-2015 Sensnology AB
          • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
          • Documentation: http://www.mysensors.org
          • Support Forum: http://forum.mysensors.org
          • This program is free software; you can redistribute it and/or
          • modify it under the terms of the GNU General Public License
          • version 2 as published by the Free Software Foundation.
          • DESCRIPTION
          • The ArduinoGateway prints data received from sensors on the serial link.
          • The gateway accepts input on seral which will be sent out on radio network.
          • The GW code is designed for Arduino Nano 328p / 16MHz
          • Wire connections (OPTIONAL):
            • Inclusion button should be connected between digital pin 3 and GND
            • RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
          • LEDs (OPTIONAL):
            • To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
            • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
            • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
            • ERR (red) - fast blink on error during transmission error or recieve crc error
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Enable inclusion mode
          //#define MY_INCLUSION_MODE_BUTTON_PIN 3
          // Set blinking period
          #define MY_WITH_LEDS_BLINKING_INVERSE
          // Flash leds on rx/tx/err
          #define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin
          #define MY_DEFAULT_RX_LED_PIN 6 // Receive led pin
          #define MY_DEFAULT_TX_LED_PIN 5 // the PCB, on board LED
          The Motion Sensor:
          REVISION HISTORY
          Version 1.0 - Henrik Ekblad
          DESCRIPTION
          Motion Sensor example using HC-SR501
          http://www.mysensors.org/build/motion
          // Enable debug prints
          #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
          #define CHILD_ID 1 // Id of the sensor child
          // Initialize motion message
          pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input
          sendSketchInfo("Motion Sensor", "1.0");
          present(CHILD_ID, S_MOTION);
          // Read digital motion value
          bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
          Serial.println(tripped);
          send(msg.set(tripped ? "1" : "0")); // Send tripped value to gw
          switch (tripped) {
          case LOW:
          Serial.println("NO alarm");
          break;
          case HIGH:
          Serial.println("#####ALARM#####");
          break;
          sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
          Thermistor and Relay:
          REVISION HISTORY
          DESCRIPTION
          Example sketch showing how to control physical relays.
          This example will remember relay state after power failure.
          http://www.mysensors.org/build/relay
          #define MY_REPEATER_FEATURE
          #define NODE_ID 5
          int _nominal_resistor = 4700;
          int _nominal_temperature = 25;
          int _b_coefficient = 3950;
          int _series_resistor = 5630;
          int _pin = 1;
          MyMessage msg(NODE_ID, V_TEMP);
          //uint8_t value = OPEN;
          int8_t temp = 25;
          #define RELAY_1 7 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
          #define RELAY_ON 1 // GPIO value to write to turn on attached relay
          void before()
          for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
          // Set relay pins in output mode
          pinMode(pin, OUTPUT);
          digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
          Serial.begin(115200);
          sendSketchInfo("2xRelay+Thermistor", "1.0");
          present(NODE_ID, S_TEMP);
          present(sensor, S_BINARY);
          temp = measure_temperature();
          Serial.println(temp);
          send(msg.set(temp));
          sleep(5000);
          // Change relay state
          digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
          // Store state in eeprom
          // Write some debug info
          Serial.print(message.sensor);
          int8_t measure_temperature()
          // read the voltage across the thermistor
          float adc = analogRead(_pin);
          // calculate the temperature
          float reading = (1023 / adc) - 1;
          reading = _series_resistor / reading;
          float temperature;
          temperature = reading / _nominal_resistor; // (R/Ro)
          temperature = log(temperature); // ln(R/Ro)
          temperature /= _b_coefficient; // 1/B * ln(R/Ro)
          temperature += 1.0 / (_nominal_temperature + 273.15); // + (1/To)
          temperature = 1.0 / temperature; // Invert
          temperature -= 273.15; // convert to C
          if (! getControllerConfig().isMetric) temperature = temperature * 1.8 + 32;
          return int8_t(temperature);
          • tbowmoT
            tbowmoT
            tbowmo
            could you please reformat your post, and add "code" tags to each chunk of code/ file? (use the "insert code-tag" button above the editor).
            It's a bit hard to see where one stops, and the next starts..
            • tbowmoT
              tbowmoT
              tbowmo
              Also try and stick with one piece of code, until you get that working, and understand what it does, before trying multiple sketches, etc. Take it step by step.. Instead of jumping all around :)
              A simple node, like an actuator, with a LED on the node, that you will try to turn on / off using domoticz
              • I
                I
                iahim67
                Sorry, i was just a bit too enthusiastic ... to see it all working :-), I'll reformat the post as you say.
                • I
                  I
                  iahim67
                  So this is the gateway code:
                  * The ArduinoGateway prints data received from sensors on the serial link.
                  * The gateway accepts input on seral which will be sent out on radio network.
                  * The GW code is designed for Arduino Nano 328p / 16MHz
                  * Wire connections (OPTIONAL):
                  * - Inclusion button should be connected between digital pin 3 and GND
                  * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
                  * LEDs (OPTIONAL):
                  * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                  • I
                    I
                    iahim67
                    And this is my temperature sensor code (I'm using a thermistor):
                    #define NODE_ID 0
                    int _pin = 1;
                    int8_t temp = 25;
                      sendSketchInfo("Thermistor", "1.0");
                      sleep(3000);
                      float temperature;
                    I start Domoticz, enter the Gateway setup and delete every node while the sensor is powered off.
                    I power on the sensor (connect the USB cable to my laptop) and nothing happens, I click refresh on the nodes but no nodes shows up, the RX and TX LEDs on the gateway do not blink.
                    Then I reflash (upload) the code above and suddenly the RX and TX LEDs on the Gateway start blinking and Domoticz recognizes my sensor.
                    It is like if I power off the sensor it will not be recognized unless I upload the sensor code again.
                    • I
                      I
                      iahim67
                      Sorry ... still learning how to use the Insert Code Block :-)
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        Try a simpler approach, use a serial terminal to access the gateway, and check the messages that is coming in there.
                        Next check the serial port on the node, and check if it indicates any errors etc, both on first power up, and on second/third/fourth etc.
                        • I
                          I
                          iahim67
                          OK, I tried to power ON the sensor 5 times, I opened the Arduino serial monitor every time and waited a couple of minutes, the terminal window was empty every time like the sensor has no serial output.
                          Sixth time I hit the upload button in Arduino and in a few seconds the sensor starts working and this is what I can see in the terminal window:
                          3 TSM:INIT
                          4 TSF:WUR:MS=0
                          11 TSM:INIT:TSP OK
                          13 TSF:SID:OK,ID=2
                          14 TSM:FPAR
                          51 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          411 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          416 TSF:MSG:FPAR OK,ID=0,D=1
                          2058 TSM:FPAR:OK
                          2059 TSM:ID
                          2060 TSM:ID:OK
                          2062 TSM:UPL
                          2065 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          2071 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          2076 TSF:MSG:PONG RECV,HP=1
                          2078 TSM:UPL:OK
                          2080 TSM:READY:ID=2,PAR=0,DIS=1
                          2084 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          2092 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          2099 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                          2107 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                          2113 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          2120 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=OK:Thermistor
                          2129 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                          2138 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                          2143 MCO:REG:REQ
                          2147 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                          2153 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          2158 MCO:PIM:NODE REG=1
                          2160 MCO:BGN:STP
                          2162 MCO:BGN:INIT OK,TSP=1
                          27
                          2166 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:27
                          2172 MCO:SLP:MS=3000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          2178 MCO:SLP:TPD
                          2180 MCO:SLP:WUP=-1
                          27
                          2184 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:27
                          2190 MCO:SLP:MS=3000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          2195 MCO:SLP:TPD
                          2197 MCO:SLP:WUP=-1
                          27
                          2201 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:27
                          2207 MCO:SLP:MS=3000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          2212 MCO:SLP:TPD
                          2214 MCO:SLP:WUP=-1
                          27
                          2219 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:27
                          2225 MCO:SLP:MS=3000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          2230 MCO:SLP:TPD
                          2231 MCO:SLP:WUP=-1```
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            what hardware do you use for the node?
                            • I
                              I
                              iahim67
                              The node is an Arduino Mini - it is not an Arduino Mini Pro as reccomended, true!
                              But I'll try soon with an Arduino Nano as a node.
                              The gateway is an Arduino nano.
                              on The gateway side the serial monitor only shows
                              0;255;0;0;18;2.1.1
                              no matter how many times I power ON and OFF the sensor.
                              But after I reflash the sensor then the Gateway serial output is:
                              0;255;0;0;18;2.1.1
                              2;255;3;0;11;Thermistor
                              2;255;3;0;12;1.0
                              2;0;0;0;6;
                              2;0;1;0;0;27```
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                Just a thought..
                                Program a simple blinking sketch in your node, see if the LED is blinking (this is without mysensors at all!)
                                Now try powercycling it a couple of times, does it start blinking?
                                If not, then there is a problem with your arduino mini.
                                • I
                                  I
                                  iahim67
                                  OK, I'll try that too, thanks!
                                  • I
                                    I
                                    iahim67
                                    Amazing! You were absolutely right! I tried a simple LED blink like below, it only works once after the code upload. No matter how many times I power cycle after that, it will not work any more. What could be wrong with this Arduino Mini? It is the original Arduino Mini from Farnell ...
                                      Blink
                                      Turns on an LED on for one second, then off for one second, repeatedly.
                                      Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
                                      it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
                                      the correct LED pin independent of which board is used.
                                      If you want to know what pin the on-board LED is connected to on your Arduino model, check
                                      the Technical Specs of your board  at https://www.arduino.cc/en/Main/Products
                                      This example code is in the public domain.
                                      modified 8 May 2014
                                      by Scott Fitzgerald
                                      modified 2 Sep 2016
                                      by Arturo Guadalupi
                                      modified 8 Sep 2016
                                      by Colby Newman
                                    // the setup function runs once when you press reset or power the board
                                      // initialize digital pin LED_BUILTIN as an output.
                                      pinMode(8, OUTPUT);
                                    // the loop function runs over and over again forever
                                      digitalWrite(8, HIGH);   // turn the LED on (HIGH is the voltage level)
                                      delay(1000);                       // wait for a second
                                      digitalWrite(8, LOW);    // turn the LED off by making the voltage LOW
                                    • I
                                      I
                                      iahim67
                                      Many thanks nevertheless:-)
                                      I use Arduino 1.8.2
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        I have no idea what could be wrong with it..
                                        Have you checked the soldering of the board? Tried another powersupply?
                                        • I
                                          I
                                          iahim67
                                          Forgot to tell I have a few such Arduino Mini, all have the same issue!
                                          Might have something to do with both the way I have connected the power and the reset, like here, "Connecting the Arduino Mini and Mini USB Adapter":
                                          https://www.arduino.cc/en/Guide/ArduinoMini
                                          Power to the Arduino (+5V) comes from the USB Adapter while reset goes through a capacitor.
                                          I will abandon this setup and use a nano based sensor for now.
