  3. HomeAssistant > MySensors:MQTT relay actuator works but very slow
1 Posts 1 Posters 712 Views 2 Watching
  • Andrew CreahanA
    Andrew CreahanA
    Andrew Creahan
    It's my first outing with MySensors and I hoping someone might be able to help me out.
    I've set up three relays connected to HA via the mysensors 5100mqttgateway. All is working except for the variable and sometimes very slow reaction times. I've experimented with different brokers and with tweaking the sketch, but still it's slow - ranging from 2s up to 30s.
    What are other's experiences with response times in this sort of set-up? Any thoughts on what the issues might be?
    Here's the sketch:
    //#define MY_RADIO_NRF24
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "jungle1-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "jungle1-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "mysensors-jungle"
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,xxx,xxx
    #define MY_IP_GATEWAY_ADDRESS 192,168,xxx,xxx
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, xxx, xxx
    #define MY_PORT 1883
    #define CHILD_ID_REL1 101
    #define CHILD_ID_REL2 102
    #define CHILD_ID_REL3 103
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Ethernet use the following PINs, do not use them:
    UNO:  4, 10, 11, 12, 13
    #define REL1_PIN 7
    #define REL2_PIN 6
    #define REL3_PIN 5
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <Ethernet.h>
    MyMessage msgREL1(CHILD_ID_REL1, V_STATUS);  // 2
    MyMessage msgREL2(CHILD_ID_REL2, V_STATUS);  // 2
    MyMessage msgREL3(CHILD_ID_REL3, V_STATUS);  // 2
    bool FirstRun = true;
    const unsigned long tUpdate=20000; //update interval
    unsigned long t0;
    byte StateREL=0;
    byte StateRELH=0;
    bool StateREL1=false, StateREL2=false, StateREL3=false;
    bool ChgREL=false;
    void before()
      pinMode(REL1_PIN, OUTPUT);
      digitalWrite(REL1_PIN, StateREL1);
      pinMode(REL2_PIN, OUTPUT);
      digitalWrite(REL2_PIN, !StateREL2);
      pinMode(REL3_PIN, OUTPUT);
      digitalWrite(REL3_PIN, !StateREL3);
    t0=millis();
     sendSketchInfo("JungleRelay", "2.1");
      present(CHILD_ID_REL1, S_BINARY);
      present(CHILD_ID_REL2, S_BINARY);
      present(CHILD_ID_REL3, S_BINARY);
    	if (FirstRun) {
        send(msgREL1.set(StateREL1?RELAY_ON:RELAY_OFF));
        Serial.println("Requesting initial value from controller 1");
        request(CHILD_ID_REL1, V_STATUS);
        wait(2000, C_SET, V_STATUS);
        send(msgREL2.set(StateREL2?RELAY_ON:RELAY_OFF));
        Serial.println("Requesting initial value from controller 2");
        request(CHILD_ID_REL2, V_STATUS);
        send(msgREL3.set(StateREL3?RELAY_ON:RELAY_OFF));
        Serial.println("Requesting initial value from controller 3");
        request(CHILD_ID_REL3, V_STATUS);
      if (((millis()-t0) > tUpdate) or (ChgREL)){
          ServerUpdate();
          t0=millis();
          ChgREL = false;
    void ServerUpdate() {
          send(msgREL1.set(StateREL1 ? RELAY_ON:RELAY_OFF));
          send(msgREL2.set(StateREL2 ? RELAY_ON:RELAY_OFF));
          send(msgREL3.set(StateREL3 ? RELAY_ON:RELAY_OFF));
      if (message.type==V_STATUS) {
          if (FirstRun) {
          Serial.println("Receiving initial value from controller");
          FirstRun = false;
        StateRELH=strcmp(message.data,"1")==0;
        StateREL = StateRELH;
        ChgREL = true;
        Serial.println(message.sensor);
        switch(message.sensor) {
          case 101: {
            if (StateREL) {
              digitalWrite(REL1_PIN, HIGH);
              StateREL1 = true;
              Serial.println(message.sensor, "ON");
            else {
              digitalWrite(REL1_PIN, LOW);
              StateREL1 = false;
          break;
          case 102: {
            StateREL2=StateREL;
            if (StateREL) {
              digitalWrite(REL2_PIN, LOW);
              StateREL2 = true;
            else {
              digitalWrite(REL2_PIN, HIGH);
              StateREL2 = false;
          break;
          case 103: {
            StateREL3=StateREL;
            if (StateREL) {
              digitalWrite(REL3_PIN, LOW);
              StateREL3 = true;
            else {
              digitalWrite(REL3_PIN, HIGH);
              StateREL3 = false;
          break;
