  3. 💬 Aeos : a NRF52 versatile, up to 9in1, device
motionnrf52pressureweatheraccelerometerlight luxhumiditymicrophoneair qualitydoor contactbletemperaturesecuritynfcmultisensors
51 Posts 15 Posters 22.0k Views 20 Watching
  • scalzS
    scalzS
    wrote on last edited by scalz
    #21
    @NeverDie
    yes sure. For example, in Mysensors, I have now 4x nrf52 nodes (aeos and other custom boards) talking to esp32+nrf24 gw.
    So, NRF52 <-> NRF52 and NRF52 <-> NRF24 are working well, and you can simply use Mysensors examples and set the defines, that's all, nothing more to do, it's transparent. Thx to the Mysensors NRF52 ESB port, pretty cool.
    For bluetooth, I've started to take a look for a simple BLE phone app too, for fun. That said with BLE available, we could get nice features in Mysensors..
    Finally, little sidenote about my simple range tests. They were quick, not in ideal conditions, but gave me an indication.
    I have tested BLE and Mysensors modes. Power supply for the node was 2x fresh AAA battery:
    • as a BLE beacon, and was checking the rssi with a phone app. Not a precise test as rssi is not linear.
    • with Mysensors. A simple counter was sent to the gw and i was looking for missing packet.
    I'll do more tests of course because some variables can change the results (like if it is in enclosure depending of wire antenna or not, orientation ..). For example, I will check pcb antennas by testing communication between two identical nodes.
    alexsh1A 1 Reply Last reply
    • d00616D
      d00616D
      d00616
      @scalz Have you checked if there is a difference in range between NRF5_1MBPS and NRF5_BLE_1MBPS data rate?
      • scalzS scalz
        @NeverDie
        alexsh1A
        alexsh1A
        alexsh1
        @scalz 👍 Thumbs up for a 2450! You have it on your other sensor and I'm using it for PIR is makes sense. 2032 is fine for a long sleeping sensor, but PIR will drain it very quickly.
        • scalzS
          scalzS
          @d00616 no. that was just a quick test during euphoria :blush: but that's an interesting point i need to add on my ToTest :+1:
          • KoreshK
            KoreshK
            Koresh
            wrote on last edited by Koresh
            #25
            Congratulations. Very nice concept. But I understand nothing about the range. Is it comparable with nrf24 or is it by a decade more? :)
            • scalzS
              scalzS
              #26
              @Koresh
              thx. I'm not sure about what you don't understand :)
              If you're wondering about nrf24 vs nrf52 range, i've not tested this, i'll do that as soon as i get my custom antenna version of the board.
              Because comparing a nrf24 module with pcb antenna Vs nrf52 with a chip antenna or an untuned wire antenna isn't a valid test, I think.
              KoreshK 1 Reply Last reply
              • scalzS scalz
                @Koresh
                KoreshK
                KoreshK
                Koresh
                #27
                @scalz OK, waiting your results. For now I've just found some information about tx power:
                nrf24: nominal - 0dbm, max - +4dbm
                nrf51: nominal - 4dbm, max - +6dbm
                Not very high power :(
                • Nca78N
                  Nca78N
                  wrote on last edited by Nca78
                  #28
                  @scalz have you seen this module ?
                  PCB antenna + IPEX, and with 52832 we're sure it's not a clone...
                  At this price I can directly dump my atsamds and nrf modules :o
                  http://www.ebay.com/itm/nRF52832-E73-2G4M04S-Low-Power-2-4GHz-SMD-Wireless-Module-with-PCB-IPX-Antenna-/192237288810
                  • Nca78N Nca78
                    NeverDieN
                    NeverDieN
                    @Nca78
                    It's very nice that they offer up the info needed to create the land pattern. That info seems absent from quite a number of the aliexpress modules.
                    • scalzS
                      scalzS
                      #30
                      @Koresh
                      Yes, still an interesting improvement :) And i have powerful multirf boards too so..
                      Well i think you know it, but range is not so easy to compare, that depends on a lot of factors like datarate, ant, enclosure etc..
                      @Nca78
                      yep, saw it too. I don't think they're selling clones, they looks nice ;)
                      Module is too big regarding my board and all what's embedded. I also wanted a stronger antenna.
                      This kind of meandered antenna, often the same for wire antenna though, may be prone to some detuning (regarding enclosure, environment etc.) and loosing some efficiency etc. So maybe not the full range, can be a lot less, depends (100m for this module in datasheet).
                      But yes i agree with you :) 328p too limited, obsolete imho, "end" of nrf24 lol, and atsam is nice depending on the usecase. Personal view of course!
                      Nca78N 1 Reply Last reply
                      • scalzS scalz
                        @Koresh
                        @Nca78
                        Nca78N
                        Nca78N
                        @scalz said in 💬 Aeos : a NRF52 versatile, up to 9in1, device:
                        But I think I'm still about to make one last 328 board to make a really small and low power sensor.
                        Would you share eagle and schematic files for your prototype with the module ? I have ordered modules from EByte and I'd like some inspiration to prepare a first test board :D
                        • Nca78N Nca78
                          NeverDieN
                          NeverDieN
                          #32
                          @Nca78
                          Thanks for posting that. I just now ordered some. However, they may not arrive until September! Yowza. That means their shipping container is practically a time capsule.
                          • NeverDieN NeverDie
                            @Nca78
                            Nca78N
                            Nca78N
                            @NeverDie great ! Don't thank me I'm pretty sure I'll benefit a lot from your testing on that module :)
                            NeverDieN 1 Reply Last reply
                            • Nca78N Nca78
                              NeverDieN
                              NeverDieN
                              #34
                              @Nca78
                              One quick thing: I've started a PCB layout for this module. From the looks of the pictures on the e-bay listing, I'm assuming pins 0, 1, 2, 42, and 43 are all Ground.
                              Is that your interpretation also?
                                @Nca78
                                Nca78N
                                Nca78N
                                @NeverDie said in 💬 Aeos : a NRF52 versatile, up to 9in1, device:
                                @Nca78
                                It's what's written in the datasheet ;)
                                0_1499826898882_E73-2G4M04S_Datasheet_EN_v1.1.pdf
                                • Nca78N Nca78
                                  @Nca78
                                  @Nca78 now you're cheating ;-)
                                  • scalzS
                                    scalzS
                                    #37
                                    @NeverDie hmm.. guys could you open a new topic regarding your nrf52 module please?
                                    (as i'm not planning to use it for Aeos, cost almost the same for me to use the IC, and i can do more compact stuff)
                                    Else that will be a mess here ;) Thx!
                                    @Nca78 will upload some sch, was busy..
                                    Here a very simple rfm69 extension for Aeos, when i need more range:
                                    And a simple pcb for quick reprogramming the first time (as the next times it will be through OTA).
                                    • scalzS scalz
                                      Nca78N
                                      Nca78N
                                      And a simple pcb for quick reprogramming the first time (as the next times it's through OTA).
                                      OTA ? Is a bootloader already made ? :o
                                      • scalzS
                                        scalzS
                                        #39
                                        @Nca78
                                        There are some stuff already existing though.
                                        You can take a look at Adafruit nrf52 board, they have a bootloader for BLE, and their sch can also help you to understand how the above module is working in case.
                                        Regarding Mysensors OTA etc, stay tuned..
                                        d00616D 1 Reply Last reply
                                        • scalzS scalz
                                          @Nca78
                                          d00616D
                                          d00616D
                                          d00616
                                          It would be nice if you can enable OTA. The DFU bootloader is placed at the top of Flash. This region conflicts with the NVM driver. You have to move the used Flash region.
                                          The bootloader is documented at http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.1.0/lib_bootloader_modules.html
                                          At the moment I have no time to work on an bootloader. If you want to discuss things you can contact me.
