  3. Binary switch code written for 1.5.4
5 Posts 2 Posters 1.5k Views 4 Watching
  • ihtgtwtdI
    ihtgtwtdI
    ihtgtwtd
    I found the following sketch somewhere in the forum. It is written for MySensors 1.5.4, I tried to convert it for 2.1 but ended up with code that wont compile.
    What needs to be changed to make it compile?
    #include <Bounce2.h>
    #define NUMBER_OF_SWITCHES 6
    Bounce debouncer[NUMBER_OF_SWITCHES];
    int oldValue[NUMBER_OF_SWITCHES];
    byte switchPin[NUMBER_OF_SWITCHES] = {3,4,5,6,7,8}; //<<<<<<<<<<< set your switch pins here
    MyMessage msg(0,V_STATUS);
      gw.begin();
      for (int i = 0; i < NUMBER_OF_SWITCHES; i++)
        pinMode(switchPin[i],INPUT_PULLUP);
        debouncer[i] = Bounce();
        debouncer[i].attach(switchPin[i]);
        debouncer[i].interval(5);
        gw.present(i, S_BINARY);
        delay(250);
        debouncer[i].update();
        int value = debouncer[i].read();
        if (value != oldValue[i])
          gw.send(msg.setSensor(i).set(value == HIGH? true : false), false);
        oldValue[i] = value;
    this is the original sketch without changes.
    greetings
    • ihtgtwtdI ihtgtwtd
        gw.begin();
          delay(250);
      greetings
      @ihtgtwtd https://forum.mysensors.org/post/42715 has instructions on how to convert from 1.x to 2.x.
      • ihtgtwtdI
        ihtgtwtdI
        ihtgtwtd
        thanks @mfalkvidd
        I already read that post. I tried again and now it worked.
        Thanks again
          thanks @mfalkvidd
          Thanks again
          @ihtgtwtd great!
          Would you mind posting the converted sketch, in case someone else comes looking for it later?
          • ihtgtwtdI
            ihtgtwtdI
            ihtgtwtd
            No, of course not. Here you go, have fun everyone :-)
            #define SKETCH_NAME "Binary Sensor"
            #define SKETCH_MAJOR_VER "1"
            #define SKETCH_MINOR_VER "0"
            #define first_CHILD_ID 0
            #define second_CHILD_ID 1
            #define third_CHILD_ID 2
            #define fourth_CHILD_ID 3
            #define fifth_CHILD_ID 4
            #define sixth_CHILD_ID 5
                delay(250);
