  3. SecurityPersonalizer.ino: randomized key not shown after first step
2 Posts 2 Posters 761 Views 2 Watching
    A Former User
    I'm trying to personalize my ATSHA204A as documented here:
    https://www.mysensors.org/about/signing#how-this-is-done
    So I set this values:
    Enable LOCK_CONFIGURATION
    Disable LOCK_DATA
    Enable SKIP_KEY_STORAGE
    Disable SKIP_UART_CONFIRMATION
    Disable USER_KEY
    But in serial console - no randomized key is shown -as written in documentation "Execute the sketch on the “master” device to obtain a randomized key. Save this key to a secure location and keep it confidential so that you can retrieve it if you need to personalize more devices later on."
    If I'm checking the code it's clear - because of disabled SKIP_KEY_STORAGE:
    #ifdef SKIP_KEY_STORAGE
    	Serial.println(F("Disable SKIP_KEY_STORAGE to store key."));
    #else
    #ifdef USER_KEY
    	memcpy(key, user_key_data, 32);
    	Serial.println(F("Using this user supplied HMAC key:"));
    #else
    	// Retrieve random value to use as key
    So I think documentation is wrong at this point or do I understand it incorrectly?
    Best regards,
    Chris
    AnticimexA 1 Reply Last reply
    • ? A Former User
      Disable LOCK_DATA
      Disable USER_KEY
      #else
      #ifdef USER_KEY
      #else
      Best regards,
      Chris
      AnticimexA
      AnticimexA
      Anticimex
      @nog76 you are probably right. Thanks for reporting. A new release is soon to come which will change things quite a lot and documentation will update with that update.
