  3. Reapeter and relay actuactor
7 Posts 2 Posters 1.8k Views 2 Watching
  • G
    G
    guillaume brucker
    wrote on last edited by gohan
    Hi all,
    First, thanks for all the work on MySesnor project, it's fun and working perfectly.
    But still have one question on repeater and relay actuator.
    From my house, i have a serial gateway on a Arduino Uno, different node, and one node as repeater because some node are far away and sometime reach the gateway directly, sometime not.
    For this repeater, could it work with a "receive" function i use for a relay actuator ? Seem not, but not sure.
    Or do I need to add some function in the receive function in order to process incoming messages to repeat ?
    Here, the same code use for the far node and repeater, off course, i enable repeat feature if need
    Some comment on best codung is also possible, i'm not a king in coding ;)
    // Noeud 3 ârent par défaut, si le neoud répond pas une nouvelle election a lieu
    //#define MY_PARENT_NODE_ID 3
    //#define MY_PARENT_NODE_IS_STATIC
    #define MY_RF24_PA_LEVEL RF24_PA_MAX  //RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH or RF24_PA_MAX.
    #define MY_REPEATER_FEATURE
    #include <OneWire.h>
    #include <Bounce2.h>  //pour les boutons
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    #define INTER1 2
    #define INTER2 3
    #define RELAY_1  6  // Lamp as a RELAYArduino Digital I/O pin number for first relay (second on pin+1 etc)
    int numSensors = 1;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(4, V_TEMP);
    MyMessage msg1(1, V_TRIPPED);
    MyMessage msg2(2, V_TRIPPED);
    MyMessage msg4(5, V_STATUS);
    Bounce debouncer_one = Bounce();
    Bounce debouncer_two = Bounce();
    void before() {
      sensors.begin();
      pinMode(INTER1, INPUT); // sets the digital pin as input
      pinMode(INTER2, INPUT); // sets the digital pin as input
      // Activate internal pull-ups  ?
      digitalWrite(INTER1, LOW);
      digitalWrite(INTER2, LOW);
      debouncer_one.attach(INTER1);
      debouncer_one.interval(100);
      // Deuxieme bouton
      debouncer_two.attach(INTER2);
      debouncer_two.interval(50);
      for (int RELAY = 5, pin = RELAY_1; RELAY <= NUMBER_OF_RELAYS + 5; RELAY++, pin++) {
        pinMode(pin, OUTPUT);
      sendSketchInfo("Boitier Complet", "1.9");
      for (int RELAY = 5, pin = RELAY_1; RELAY <= NUMBER_OF_RELAYS + 4; RELAY++, pin++) {
        present(RELAY, S_LIGHT);
        digitalWrite(pin, loadState(RELAY) ? RELAY_ON : RELAY_OFF);
      for (int i = 4; i < numSensors + 4 && i < MAX_ATTACHED_DS18B20; i++) {
        present(i, S_TEMP);
      // Present all button to controler
      for (int i = 1; i < 3; i++) {
        present(i, S_DOOR);
      // Gestion de la temperature
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        float temperature = static_cast<float>(static_cast<int>(( sensors.getTempCByIndex(i)) * 10.)) / 10.;
        float TempValue1 = temperature * 10;
        int TempValue2 = (int)TempValue1;
        int Calcul = TempValue2 - lastTemperature[i] ;
        Calcul = abs(Calcul);
        if ( Calcul > 2 ) {
          send(msg.setSensor(i + 4).set(temperature, 1));
          lastTemperature[i] = TempValue2;
      boolean stateChanged_one = debouncer_one.update();
      if ( stateChanged_one ) {
        // Get relay state
        boolean Relay_state = loadState(msg4.sensor) ? RELAY_ON : RELAY_OFF ;
        boolean New_state = 0;
        // Change relay state
        if (Relay_state == RELAY_ON ) {
          // Nouvel Etat
          New_state = 0;
        else {
          New_state = 1;
        // Activation du PIN
        digitalWrite(msg4.sensor - 5 + RELAY_1, New_state);
        //digitalWrite(RELAY_1, New_state);
        // Envoi des infos au controleur
        send(msg4.set(New_state ? "1" : "0"), 0);
        // Envoi du changement d'état de l'inter
        send(msg1.set(digitalRead(INTER1) ? "1" : "0"), 0);
        // Store state in eeprom
        saveState(msg4.sensor, New_state);
      // Deuxieme bouton
      boolean stateChanged_two = debouncer_two.update();
      if ( stateChanged_two ) {
        send(msg2.set(digitalRead(INTER2) ? "1" : "0"), 0);
        digitalWrite(message.sensor - 5 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
        // Write some debug info
        Serial.print(message.sensor);
    Thanks a lot
    rejoe2R 1 Reply Last reply
    • G guillaume brucker
      Hi all,
      #define INTER1 2
      #define INTER2 3
      int numSensors = 1;
      bool metric = true;
      void before() {
        sensors.begin();
        // Deuxieme bouton
          present(i, S_TEMP);
          present(i, S_DOOR);
          if ( Calcul > 2 ) {
          // Get relay state
            // Nouvel Etat
            New_state = 0;
          else {
            New_state = 1;
        // Deuxieme bouton
      Thanks a lot
      rejoe2R
      rejoe2R
      rejoe2
      @guillaume-brucker
      Just enabling the repeater feature should do the trick - as you already did.
      But: The way you solved the DS18B20 part will most likely cause troubles:
      First, imo, it is not recommended to make a measurement each time you go through the loop(), to me, it seems to be better to skip this part as long as not a minimum time has passed since last measurement - if you want to know how to achieve this: see e.g. the ServoActuator-Example.
      Second, usually one has to wait a conversionTime, until the DS18x20 gives an answer. This can be done blocking (this seems to be standard), but has the disadvantage, that you may also miss keypresses within this periode (1sec. as default).
      Imo you may get around that by initialising the sensors with sensors.setWaitForConversion(false); (after begin() in before()) and issue a requestTemperatures after minPeriod has passed an then read the temperatures, if minPeriod+conversionTime has passed (use an older Version of the DStemp-lib, if you encounter problems with conversionTime) .
      May sound a little complicated at first glance, but isn't rocket science...
      G 1 Reply Last reply
      • rejoe2R rejoe2
        @guillaume-brucker
        G
        G
        guillaume brucker
        @rejoe2
        Hi ,
        So if i understand, no need to chnage receive function to process repeater feature and incoming message for actuator.
        But one issue of communication in repeater, and other node, may be the way i process the D18b20 component.
        I'll check and keep you inform
        rejoe2R G 2 Replies Last reply
          @rejoe2
          Hi ,
          rejoe2R
          rejoe2R
          rejoe2
          wrote on last edited by rejoe2
          This post is deleted!
            @rejoe2
            Hi ,
            G
            G
            guillaume brucker
            @guillaume-brucker
            In fact the question, is
            Does i need to make change if i want to make a repeater sensor with a relay actuator.
            There is lot of example of repeater, repeater with sensor, but not with actuator, Mine can be the first :)
              @guillaume-brucker
              rejoe2R
              rejoe2R
              rejoe2
              @guillaume-brucker It is definitely not first! I got at least one working for more than 20 months:simple_smile:
              So the simple answer remains: beside the definition of the repeater feature itself there is no need for any further change in the code of any working node's code - apart from the obvious check that there is no "sleep()" used anywhere in the sketch:laughing:.
              Onother question may be to suply the node with enough power. Relays need some when working and the node may have to handle more transmissions.
              • rejoe2R rejoe2
                G
                G
                guillaume brucker
                @rejoe2
                Thanks rojoe2,
                I don't really use relay, too much power consumption, i use opto-triac to manage light.
                Less consumption and noise
                Will try with a single repeater, but you're right with the D18B20, it take much time each loop, i'll see the change when power on the light, there is no delay now :+1:
