  3. MyWindSensor
MyWindSensor
5 Posts 3 Posters 2.5k Views 3 Watching
  • Bert RamselaarB
    Bert RamselaarB
    Bert Ramselaar
    Made een Windsensor for MySensors, Works well!
    used an adafruit https://www.adafruit.com/product/1733 windmeter.
     * versie 1.1 bert ramselaar
     * Used an UNO with a NRF24+ with external antenna
     * Arduino Wind Sensor
     * Adafruit Anemometer Wind Speed Sensor -> https://www.adafruit.com/product/1733
     * connect the sensor as follows :
     *   VCC  (brown)      >>> 5V
     *   A    (blue)      >>> A0 or any other analog pin
     *   GND  (black)      >>> GND
    // Enable debug prints
    #define CHILD_ID_WIND 0
    #define WIND_SENSOR_ANALOG_PIN 0
    unsigned long SLEEP_TIME = 2000; // Sleep time between reads (in milliseconds)
    // VARIABLES
    float W_Raw_A0 = 0; // stores the RAW value coming from the sensor 0 to 1023
    float W_Volt = 0; // stores voltage calculated form A0
    float W_WindSpeed = 0; // Windspeed in meters per second (m/s)
    float W_WindSpeed_last = 0; // previus Windspeed sended
    float W_Voltage_Conversion = .004882814; //This constant maps the value provided from the analog read function, which ranges from 0 to 1023, to actual voltage, which ranges from 0V to 5V
    float W_voltageMin = .4; // Mininum output voltage from anemometer in mV.
    float W_voltageMax = 2.0; // Maximum output voltage from anemometer in mV.
    float W_windSpeedMin = 0; // Wind speed in meters/sec corresponding to minimum voltage
    float W_windSpeedMax = 32; // Wind speed in meters/sec corresponding to maximum voltage
    int W_beaufort = 0; // Calculated beaufort scale
    MyMessage windMsg(CHILD_ID_WIND, V_WIND);
      sendSketchInfo("Wind Sensor", "1.1");
      present(CHILD_ID_WIND, S_WIND);
      W_Raw_A0 = analogRead(WIND_SENSOR_ANALOG_PIN); // Get WIND value from A0
      W_Volt = W_Raw_A0 * W_Voltage_Conversion; //Convert sensor value to actual voltage
    //Convert voltage value to wind speed using range of max and min voltages and wind speed for the anemometer
    if (W_Volt <= W_voltageMin)
     W_WindSpeed = 0; //Check if voltage is below minimum value. If so, set wind speed to zero.
    else
      // calculate winspeed in Meters per Second
      W_WindSpeed = (W_Volt - W_voltageMin) * W_windSpeedMax / (W_voltageMax - W_voltageMin); //For voltages above minimum value, use the linear relationship to calculate wind speed.
      // corrected // ~~W_WindSpeed = W_WindSpeed * 3.6 // convert from m/s to km/h~~
      Serial.print("Raw Signal Value (0-1023): ");
      Serial.print(W_Raw_A0);
      Serial.print(" - Voltage: ");
      Serial.print(W_Volt);
      Serial.print(" - Windspeed M/S: ");
      Serial.print(W_WindSpeed); // unit: M/S
      Serial.print(" - Beaufort: ");
      Serial.println(beaufort()); // unit: beaufort scale
      if (ceil(W_WindSpeed) != W_WindSpeed_last)
    **/// CHANGED convert float to de nearest integer and converted (W_WindSpeed * 3.6) to km/h ///**
    send(windMsg.set((int16_t)ceil(W_WindSpeed * 3.6)));
     W_WindSpeed_last = ceil(W_WindSpeed);
        //beaufort(); // option windspeed in beafort
        //send(windMsg.set(W_beaufort)); // option windspeed in beafort
      sleep(SLEEP_TIME);
    int beaufort(void)
        if (W_WindSpeed < 0.39)
        W_beaufort = 0;
        return W_beaufort;
        else if (W_WindSpeed >= 0.3 & W_WindSpeed <= 1.5)
        W_beaufort = 1;
        return W_beaufort;
        else if (W_WindSpeed >= 1.6 & W_WindSpeed <= 3.3)
        W_beaufort = 2;
        return W_beaufort;
        else if (W_WindSpeed >= 3.4 & W_WindSpeed <= 5.4)
        W_beaufort = 3;
        return W_beaufort;
        else if (W_WindSpeed >= 5.5 & W_WindSpeed <= 7.9)
        W_beaufort = 4;
        return W_beaufort;
        else if (W_WindSpeed >= 8.0 & W_WindSpeed <= 10.7)
        W_beaufort = 5;
        return W_beaufort;
        else if (W_WindSpeed >= 10.8 & W_WindSpeed <= 13.8)
        W_beaufort = 6;
        return W_beaufort;
        else if (W_WindSpeed >= 13.9 & W_WindSpeed <= 17.1)
        W_beaufort = 7;
        return W_beaufort;
        else if (W_WindSpeed >= 17.2 & W_WindSpeed <= 20.7)
        W_beaufort = 8;
        return W_beaufort;
        else if (W_WindSpeed >= 20.8 & W_WindSpeed <= 24.4)
        W_beaufort = 9;
        return W_beaufort;
        else if (W_WindSpeed >= 24.5 & W_WindSpeed <= 28.4)
        W_beaufort = 10;
        return W_beaufort;
        else if (W_WindSpeed >= 28.5 & W_WindSpeed <= 32.6)
        W_beaufort = 11;
        return W_beaufort;
        else if (W_WindSpeed >= 32.7)
        W_beaufort = 12;
        return W_beaufort;
    YveauxY 1 Reply Last reply
    • Bert RamselaarB Bert Ramselaar
      // VARIABLES
      else
        sleep(SLEEP_TIME);
      int beaufort(void)
          W_beaufort = 0;
          return W_beaufort;
          W_beaufort = 1;
          return W_beaufort;
          W_beaufort = 2;
          return W_beaufort;
          W_beaufort = 3;
          return W_beaufort;
          W_beaufort = 4;
          return W_beaufort;
          W_beaufort = 5;
          return W_beaufort;
          W_beaufort = 6;
          return W_beaufort;
          W_beaufort = 7;
          return W_beaufort;
          W_beaufort = 8;
          return W_beaufort;
          W_beaufort = 9;
          return W_beaufort;
          W_beaufort = 10;
          return W_beaufort;
          W_beaufort = 11;
          return W_beaufort;
          W_beaufort = 12;
          return W_beaufort;
      YveauxY
      YveauxY
      @Bert-Ramselaar HI and welcome to the forum!
      I modified your post slightly to include code tags, which improves readability.
      Could you give some more info on your project (which sensor did you use? And did I mention that we simply looooove pictures ;-))?
      gohanG 1 Reply Last reply
      • YveauxY Yveaux
        @Yveaux He actually posted the link to the sensor :)
        It is rather expensive but since it isn't a pulse counter sensor but it gives a voltage to read it is probably why it isn't cheap.
        YveauxY 2 Replies Last reply
          YveauxY
          YveauxY
          @gohan @Bert-Ramselaar sorry, I'd better not browse the forum on my phone anymore :grimacing:
            YveauxY
            YveauxY
            @gohan said in MyWindSensor:
            A simple pro-mini can do the same; only costs a few €...
            Looks like it's full metal, so probably a lot more durable than the plastic ones that tend to agree rapidly in the sun...
