  3. Home Assistant
  4. Home Assistant doesn't connect to MySensors on Arduino MEGA
3 Posts 3 Posters 2.7k Views 3 Watching
  • M Offline
    M Offline
    mrlele
    wrote on last edited by mrlele
    it's the first time that I'm using MySensors (on Arduino MEGA) with Home Assistant (on Raspberry Pi 3) and I really don't understand why this two devices don't talk with each other.
    I have upload this simple scatch on Arduino:
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    //#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
    #define MY_SOFTSPI
    #define MY_SOFT_SPI_SCK_PIN 54
    #define MY_SOFT_SPI_MISO_PIN 56
    #define MY_SOFT_SPI_MOSI_PIN 55
    //#endif
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_IP_ADDRESS 192,168,1,70
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 200
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    #include <Bounce2.h>
    #define RELAY_PIN  40
    #define BUTTON_PIN  8
    #define CHILD_ID 2
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    bool state = false;
    bool initialValueSent = false;
    MyMessage msg(CHILD_ID, V_STATUS);
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(10);
      pinMode(RELAY_PIN, OUTPUT);
    void presentation()  {
      sendSketchInfo("Relay+button", "1.0");
      present(CHILD_ID, S_BINARY);
      if (!initialValueSent) {
        delay(500);
        send(msg.set(state?RELAY_ON:RELAY_OFF));
        delay(500);
        Serial.println("Requesting initial value from controller");
        delay(500);
        request(CHILD_ID, V_STATUS);
        wait(4000, C_SET, V_STATUS);
      if (debouncer.update()) {
        if (debouncer.read()==LOW) {
          state = !state;
          // Send new state and request ack back
          send(msg.set(state?RELAY_ON:RELAY_OFF), true);
      Serial.println(message.type);
      delay(500);
      if (message.isAck()) {
          Serial.println("Receiving initial value from controller");
          initialValueSent = true;
        // Change relay state
        state = (bool)message.getInt();
    Debug output is this one:
    IP: 192.168.1.70
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
    0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.1.1
    It is showed every 2 sec. in Arduino Serial Panel.
    On the other side I have writen this configuration in "configuration.yaml":
    mysensors:
      gateways:
        - device: '192.168.1.70'
          persistence_file: 'mysensors.json'
          tcp_port: 5003
      optimistic: false
      persistence: true
      retain: true
      version: 2.0
    but Home Assitant log show me this messages:
    2017-09-07 13:43:20 ERROR (Thread-2) [mysensors.gateway_tcp] Receive from server failed.
    2017-09-07 13:43:20 ERROR (Thread-2) [mysensors.gateway_tcp] Failed to shutdown socket at ('192.168.1.70', 5003)
    So what I can do?
    Thanks to all.
    Edit:
    I've enabled debug on Home Assistant and it show me this:
    2017-09-07 14:49:42 INFO (Thread-2) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.70', 5003)
    2017-09-07 14:49:42 INFO (Thread-2) [mysensors.gateway_tcp] Connected to ('192.168.1.70', 5003)
    2017-09-07 14:49:52 DEBUG (Thread-2) [mysensors.gateway_tcp] Sending 0;255;3;0;2;
    2017-09-07 14:49:52 ERROR (Thread-2) [mysensors.gateway_tcp] Receive from server failed.
    2017-09-07 14:49:52 INFO (Thread-2) [mysensors.gateway_tcp] Closing socket at ('192.168.1.70', 5003).
    2017-09-07 14:49:52 ERROR (Thread-2) [mysensors.gateway_tcp] Failed to shutdown socket at ('192.168.1.70', 5003).
    2017-09-07 14:49:52 INFO (Thread-2) [mysensors.gateway_tcp] Socket closed at ('192.168.1.70', 5003).
      Can you connect to the gateway using myscontroller?
      • M mrlele
        #define MY_SOFTSPI
        //#endif
        #define CHILD_ID 2
        #define RELAY_ON 1
        #define RELAY_OFF 0
        bool state = false;
            delay(500);
            delay(500);
            delay(500);
              state = !state;
          delay(500);
        IP: 192.168.1.70
        mysensors:
          gateways:
              tcp_port: 5003
          optimistic: false
          persistence: true
          retain: true
          version: 2.0
        So what I can do?
        Thanks to all.
        Edit:
        martinhjelmareM Offline
        martinhjelmare
        @mrlele
        My guess is that the arduino gateway reboots every two seconds, either due to a bug in the core arduino library or due to low power availability when sending from the radio.
        See similar topic:
        https://forum.mysensors.org/topic/7187/problem-adding-nodes-to-ha/2
