  2. Feature Requests
  3. Fibaro Home center 2 possible?
6 Posts 3 Posters 5.0k Views 1 Watching
  • J
    J
    Johan71
    Hi
    is it possible with ago control and later a working plugin with my sensors to use it with my home center 2?
    • axillentA
      axillentA
      axillent
      I think that API provided by FIBARO can be more or less sufficient to have mysensors integrated.
      You will need a special version of Mysensors gateway. Join us to develop it.
      sense and drive
        Yes, the Fibaro APIs is today somewhat limited. I hope they open up more in the future.
        I posted question about Fibaros apis/openness a few moths ago. But some members of their community were almost upset at me and questioned how I could propose such a strange thing. They said that I didn't understand the HC2 platform and how to use it.
        The problem is you cannot have a open socket to anything external. You cannot access the USB ports. You cannot programmatically create virtual devices. You cannot set custom variables by posting through their http-api.
        In order to create a plugin you'll have to put more intelligence into the gateway at do http-polling from the HC2.
        http://forum.fibaro.com/viewtopic.php?t=3022
        • J
          J
          Johan71
          I do not know if you understand my question properly.
          What I mean is if I'm with a raspberry pi and mysensors can have virtual sensors in FHC2 to see heat, motion sensor, etc..
          • axillentA
            axillentA
            axillent
            wrote on last edited by axillent
            I'm not sure you get my answer properly. Yes, you can.
            The only issue with this is that there is a set of the programming that someone need to do for this.
            Can you do?
            sense and drive
            • J
              J
              Johan71
              no I'm sorry, i can't
