  3. WiFi Gateway (ESP8266) - reconnect to controller
esp8266 nrf24l01+ gateway
3 Posts 2 Posters 1.5k Views 3 Watching
  • ThomasDrT
    ThomasDrT
    ThomasDr
    in contrast to the topic "WiFi Gateway (ESP8266) - reconnect to Router", I have the problem with reconnecting to the controller.
    The Gateway is made of the nodeMCU V0.9 and the NRF24L01+ in TCP Client Mode.
    I try to reboot the Router, the Gateway connects easily, switch the AP, also no problem. Restart the Controller. But the Gateway does not reconnect.
    After rebooting the Gateway the connection stays immediately.
    Is there a solution for this?
    regards
    ThomasDr
    YveauxY 1 Reply Last reply
    • ThomasDrT ThomasDr
      regards
      ThomasDr
      YveauxY
      YveauxY
      @ThomasDr I suspect that the ESP doesn't see the TCP connection going down when resetting the controller, only when resetting the router.
      Too bad the Arduino port doesn't seem to support tweaking these parameters directly....
      • ThomasDrT
        ThomasDrT
        ThomasDr
        there is a possibility to check the connection.
        I will test with receive command from controller to the gateway and write a timeout to reset the ESP with ESP.reset or ESP.restart.
        regards
        ThomasD
