  3. Newline of debug output
2 Posts 2 Posters 1.3k Views 3 Watching
    Malte Deiseroth
    wrote on last edited by Malte Deiseroth
    Hey when one tries to read the serial output of a gateway/node directly, it doesn't seem to send a correct newline char at the end of a line.
    I tried reading the output of a gateway /dev/ttyUSB0 with:
    picocom -b 115200 /dev/ttyUSB0
    But the output looks like:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
                                                    0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSF:WUR:MS=0
                0;255;3;0;9;TSM:INIT:TSP OK
                                           0;255;3;0;9;TSM:INIT:GW MODE
                 0;255;0;0;18;2.1.1
                                   0;255;3;0;9;MCO:BGN:STP
    I have also tried Using minicom and screen. All show the same
    EDIT:
    I found out, that I can use cat if I first set the baudrate correctly:
    stty -F /dev/ttyUSB0 115200
    cat /dev/ttyUSB0
    This works, but I wonder what is going on in the case if picocom
    EDIT:
    Okay, I found the solution. I guess its the same for minicom as well.
    picocom -b 115200 /dev/ttyUSB1 --imap lfcrlf
    the --imap lfcrlf maps line feed to line feed and carriage return. This then gives the desired formatting.
      If you compile an ethernet gateway, you can use myscontroller to debug
