  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 751.9k Views 98 Watching
  • zboblamontZ zboblamont
    @neverdie You can also consider replicating the 1/4 wave against ground in the opposite direction perhaps? ;)
    NeverDieN
    NeverDieN
    @zboblamont said in What did you build today (Pictures) ?:
    I don't understand what you mean. Can you explain a bit more what that would be?
    • NeverDieN NeverDie
      zboblamontZ
      zboblamontZ
      zboblamont
      @neverdie Sure.
      A quarter wave on an ideal Ground Plane mimics a half wave, the GP is sort of like a mirror in radio terms for the 1/4 above it....
      Ergo two identical 1/4 waves, one attached to RF feed the other attached to ground, does the same thing, although in fact slightly better...
      NeverDieN 1 Reply Last reply
        @neverdie Sure.
        NeverDieN
        NeverDieN
        #383
        @zboblamont So, what you are advocating is a dipole antenna? i.e. something notionally similar to this:
        https://www.openhardware.io/view/277/ESP8266-RFM69HW-gateway-with-dipole-antenna
        At least, that is what it sounds like to me.
          zboblamontZ
          zboblamontZ
          zboblamont
          @neverdie Not advocating a dipole as such, only pointing to an alternative to your suggested ground plane at 90 degrees to the base of the antenna. Electrically, the second half of the dipole IS the ground plane, and vice versa.
          With such physically small boards, it is virtually impossible to achieve the ideal ground plane unless the wavelength is very small, I suggested a duplicate helical tied to GND in the opposite direction to your antenna essentially accomplishes the same thing.
          • NeverDieN
            NeverDieN
            #385
            Interestingly, I just now checked, and it appears my LoRa leak detectors have even better range still. Maybe it's because GND completely encircles the PCB along all four edges. This may cause me to rethink the design of the gateway node, which up to now has been much smaller than the leak detectors....
            • sundberg84S
              #386
              Today some maintenance on my GW.
              Added a ground wire for debug and also corrected a buildmisstske and grounded the case.
              And relocated (let's hope for the best) it to my new HA DIY board...
              NeverDieN YveauxY 2 Replies Last reply
              • sundberg84S
                #387
                And there was the first failing sensor.... But was it because I changed the location on the gw? Nope... I had a temp/hum right beside the gw which I pushed so it fell on the floor...
                Radio cap de-attashed and sensor died.
                Easy fix and now back in operation.
                gohanG 1 Reply Last reply
                • sundberg84S sundberg84
                  NeverDieN
                  NeverDieN
                  @sundberg84 Sorry for the stupid question, but what holds your WEB/MAIL black box in place?
                    @sundberg84 said in What did you build today (Pictures) ?:
                    You meant "the first FALLING sensor" :sweat_smile:
                      #390
                      @neverdie said in What did you build today (Pictures) ?:
                      Screws.
                        YveauxY
                        YveauxY
                        @sundberg84 +1 for the mySensors sticker!
                        • petewillP
                          petewillP
                          petewill
                          My son and I finally finished his first MySensors project- a remote control for his room. He wasn't too interested but you have to start somewhere right...? :)
                          Question for you all... what are you doing (if anything) to vent the fumes from soldering? I haven't really been worried about it in the past but it makes me nervous with my son doing it with me.
                          Anyway, here are the pictures.
                          NeverDieN dbemowskD mfalkviddM gohanG Nca78N 5 Replies Last reply
                          • petewillP petewill
                            NeverDieN
                            NeverDieN
                            #393
                            @petewill What up with the red, yellow, and blue wires on the pro mini?
                            Also, did you print the case with a volcano?
                              dbemowskD
                              dbemowskD
                              @petewill That's awesome. Did you work with him too on the design of the box? Great job.
                                @petewill I put a regular 120mm pc fan to blow the fumes sideways. Not perfect, but I think it is good enough for the short time I spend soldering.
                                  @petewill is it battery powered? Can you share the code?
                                    #397
                                    @petewill , @gohan I use the same as @mfalkvidd and its pretty much a PC fan with the wires to a 9v battery.... been thinking for a long time to make a more permanent sollution with a tubes from outside....
                                      #398
                                      Today's test was to see if the regular reed switches can be closed by the magnetic field created by a 1A current.
                                      I got an opportunity to try out my recently USB power meter and adjustable load.
                                      Since I am not sure how the reed switch is mounted inside the sensor, I tried different orientations but nothing triggered the sensor. I also tried 2A but that wasn't enough either.
                                      I need a non-invasive way to know if (how much) current is flowing in a DC cable. I was hoping the reed switch would be an easy way. My next hope is something like a SCT-013, unless someone has suggestions for other sensors. Requirements: 6-48V DC. 0.5-10A. I only need to know if the circuit is consuming >0.5A, no need for an exact measurement.
                                      gohanG NeverDieN 2 Replies Last reply
                                        @mfalkvidd Hall sensor?
                                          #400
                                          @gohan SCT-013 is a hall-based sensor I think. I was looking for more specific that just the type of sensor.
                                          YveauxY 1 Reply Last reply
