  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 752.0k Views 98 Watching
    @bjacobse or get redundant beer coolers :) Important to always have cool beer.
    dbemowskD
    dbemowskD
    @mfalkvidd Can't have too much redundancy there...
    • NeverDieN
      NeverDieN
      #362
      Made this 12 button keypad. Requires only one analog pin to read which button is pressed, and any button press can also wake an arduino from sleep:
      Consumes no power when no button is pressed.
      NeverDieN 1 Reply Last reply
      • NeverDieN NeverDie
        NeverDieN
        NeverDieN
        Here's a thread which covers it in more detail: https://forum.mysensors.org/topic/8936/6-8-buttons-battery-remote-node/36
          rozpruwaczR
          rozpruwaczR
          rozpruwacz
          @neverdie what happens when you press two or more buttons ??
          • rozpruwaczR rozpruwacz
            NeverDieN
            NeverDieN
            #365
            @rozpruwacz Well, with the sketch I wrote (see link), you'd get the value of the first button pressed, and that's it. You'd have to release all the buttons before selecting a new button.
            In terms of the hardware itself, there's an order of precedence to the buttons, so at all times you'd only be able to read the value of a single button, even if more than one button were pressed. In a multi-button press scenario, the buttons of lower precedence are ignored.
            It's a good question though. If you needed to read more than one button simultaneously (such as, for example, move an RC car forward and turn right at the same time), this wouldn't do it. Seems like such a circuit would be possible though, maybe even one based on simple voltage dividing like this one. Somehow you'd need to sum unique resistances for each button pushed instead of just choose a single resistance. I can imagine doing that for a few buttons on an arduino, but maybe not as many as 12.
              rozpruwaczR
              rozpruwaczR
              rozpruwacz
              @neverdie I'm asking because I Was trying to do something like this. If there was a resistor values set that would make all 2**n (where n is the number of buttons) choices spaced enough in voltage domain it would work, but I couldn't find such a set ...
                NeverDieN
                NeverDieN
                #367
                @rozpruwacz said in What did you build today (Pictures) ?:
                That's why it might work if you needed it for only a few buttons. With only 1024 units of voltage, seems like you'd quickly run out of resolution if you tried to do more.
                • sundberg84S
                  #368
                  I built my first MysX daughter board which I will connect to my EasyPCB to drive a led strip.
                  This will power everything from 12v so 2 things. Power main board and dim LED strip.
                  • sundberg84S sundberg84
                    Do anyone knows it the back of a TO-220 always is connected to GND and if this should be connected to the board GND as well? Currently I have a exposed copper as a heatsink but this copper is not connected to GND.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @sundberg84
                      Depends on the manufacturer / device type.. So look in the datasheet of the one that you want to use.
                      sundberg84S dbemowskD 2 Replies Last reply
                      • tbowmoT tbowmo
                        @sundberg84
                        #371
                        @tbowmo
                        Thank you - I want to be able to use them all/different (ie. 5v, 3.3v, different manufacturer) so I wont connect it and just use it as a heatsink.
                        • tbowmoT tbowmo
                          @sundberg84
                          dbemowskD
                          dbemowskD
                          @tbowmo I agree, it would be per device specs. In many cases I see that connected to the middle pin (whatever that may be), but not always.
                          • NeverDieN
                            NeverDieN
                            Made this two-button nRF52832 remote control:
                            It only draws power when one of the buttons is pressed.
                            • rozpruwaczR
                              rozpruwaczR
                              rozpruwacz
                              nice :) what about range of the nRF52832 ? is it better than nfr24l01+ with pcb antenna ? I had problems with nrf24 and now I'm trying with rfm69. From first tests I can tell that it has much better range - but it is slightly larger and requires an antenna ...
                                NeverDieN
                                NeverDieN
                                yes
                                • NeverDieN
                                  NeverDieN
                                  Assembled and tested final version of LoRa Leak Detector:
                                  Thanks to an external watchdog (TPL5010), it consumes very little current while sleeping. Also, the external watchdog will reboot the pro mini should it ever become unresponsive, so, in addition, it should be highly reliable.
                                  Nca78N 1 Reply Last reply
                                    Nca78N
                                    Nca78N
                                    @neverdie said in What did you build today (Pictures) ?:
                                    TPL5010
                                    That's a really nice IC, I was looking for something like that but it seems I didn't search with the right keywords.
                                    Thank you for sharing the discovery !
                                    • NeverDieN
                                      NeverDieN
                                      Made a simple LoRa node using my CNC:
                                      • NeverDieN
                                        NeverDieN
                                        #379
                                        Upgraded it to include two AA batteries and a DS18B20 temp sensor. Future versions will tap the I2C pins on the pro mini, so those will have better TH sensors.
                                        Range is noticeably better than when I was running the LoRa from just a breadboard. :)
                                        I'm tempted to use a double sided PCB and give the LoRa a more proper and really big ground plane to see if that boosts range even more (at the same power level).
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @neverdie You can also consider replicating the 1/4 wave against ground in the opposite direction perhaps? ;)
