  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 751.7k Views 98 Watching
    @gohan SCT-013 is a hall-based sensor I think. I was looking for more specific that just the type of sensor.
    YveauxY
    YveauxY
    @mfalkvidd said in What did you build today (Pictures) ?:
    No, it's only a current transformer, and you possibly need (at least) a burden resistor to measure the current. Ofcourse we already have a thread on it ;-)
    • YveauxY Yveaux
      @yveaux yes I've read that thread and I would choose one of the sct-013 variants that already contains a burden resistor.
        Today's test was to see if the regular reed switches can be closed by the magnetic field created by a 1A current.
        I got an opportunity to try out my recently USB power meter and adjustable load.
        Since I am not sure how the reed switch is mounted inside the sensor, I tried different orientations but nothing triggered the sensor. I also tried 2A but that wasn't enough either.
        I need a non-invasive way to know if (how much) current is flowing in a DC cable. I was hoping the reed switch would be an easy way. My next hope is something like a SCT-013, unless someone has suggestions for other sensors. Requirements: 6-48V DC. 0.5-10A. I only need to know if the circuit is consuming >0.5A, no need for an exact measurement.
        NeverDieN
        NeverDieN
        #403
        @mfalkvidd Didn't you play with electromagnets when you were a kid? At least try coiling the wire and maybe putting a metal core inside it. Use a lot of coils. The more the better. Then maybe your reed-type switch would have a chance of seeing enough magnetism to trigger it.
        gohanG mfalkviddM 2 Replies Last reply
        • NeverDieN NeverDie
          @neverdie wouldn't that choke the current passing through the coil? He said he needs 6-48V DC. 0.5-10A
          • petewillP
            petewillP
            petewill
            wrote on last edited by petewill
            #405
            @NeverDie The wires are there in case I need to upload a new bootloader. This sensor one of the first ones I have done where the Arduino isn't easily removable and I wanted to try to make it a little easier in case I had to change it.
            I used an original Prusa I3 MK2 to do the printing. This is in ABS (because I didn't have any white PLA) so the print is a little rougher than if it was done with PLA.
            @dbemowsk Thanks! No, my son didn't help with the case design (yet). It was from a previous project that I slightly modified. My son is 6 so he doesn't really have the attention span to do too much yet. I'm hoping that doing little parts of a project will be fun for him and eventually turn into full projects. :)
            @mfalkvidd & @sundberg84 Thanks. I guess I need to rig something up if he is going to be helping me more often...
            @gohan No, it's not battery powered. I didn't want to have to deal with changing batteries and there is a power outlet right near the location he wanted it. Here is the code:
              The MySensors Arduino library handles the wireless radio link and protocol
              between your home built sensors/actuators and HA controller of choice.
              The sensors forms a self healing radio network with optional repeaters. Each
              repeater and gateway builds a routing tables in EEPROM which keeps track of the
              network topology allowing messages to be routed to nodes.
              Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
              Copyright (C) 2013-2015 Sensnology AB
              Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
              Documentation: http://www.mysensors.org
              Support Forum: http://forum.mysensors.org
              This program is free software; you can redistribute it and/or
              modify it under the terms of the GNU General Public License
              version 2 as published by the Free Software Foundation.
              REVISION HISTORY
              Version 1.0 - PeteWill
            #define SKETCH_NAME "Controller"
            #define SKETCH_VERSION "1.0"
            //Child (sensor) name that will be sent to gateway
            #define CONTROLLER_CHILD_NAME "Room Control"
            #define MY_DEBUG //MySensors debug messages
            #define LOCAL_DEBUG //Code specific debug messages
            #define MY_RF24_PA_LEVEL RF24_PA_HIGH //Options: RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
            #define MY_RF24_CHANNEL  76
            #define MY_NODE_ID 1  //Manually set the node ID here. Comment out to auto assign
            #include <Bounce2.h>
            #define SCENE_CHILD_ID 0
            #define BAUD_RATE 57600
            #ifdef LOCAL_DEBUG
            #define dbg(...)   Serial.print(__VA_ARGS__)
            #define dbgln(...) Serial.println(__VA_ARGS__)
            #else
            #define dbg(x)
            #define dbgln(x)
            //Button Pins -- Arduino Digital I/O pin button is connected to
            #define BLIND_UP_PIN 5
            #define BLIND_STOP_PIN 4
            #define BLIND_DOWN_PIN 3
            #define LIGHT_ON_PIN 8
            #define LIGHT_OFF_PIN 7
            #define EXTRA_BUTTON_PIN 6
            #define LED_PIN A0 //Pin for the LED transistor
            #define FLASH_TIME 300 //Amount of time to flash the LED (in milliseconds)
            #define ARRAY_SIZE(x) (sizeof(x)/sizeof(x[0]))
            uint8_t ledOn = 0;
            uint32_t ledMillis; //Used for tracking the LED flash time
            //The sceneNum array corresponds with the buttonPins array so if a button pin is read, it will send the scene number to the gateway
            int sceneNum[] = {0, 1, 2, 3, 4, 5};
            uint8_t buttonPins[] = {
              BLIND_UP_PIN,
              BLIND_STOP_PIN,
              BLIND_DOWN_PIN,
              LIGHT_ON_PIN,
              LIGHT_OFF_PIN,
              EXTRA_BUTTON_PIN
            //Debouncer is used for the buttons.  Need to have the same number as the total buttons.
            Bounce debouncer[] = {
              Bounce(),
              Bounce(),
              Bounce(),
              Bounce(),
              Bounce(),
              Bounce()
            //used to keep track of previous values contact sensor values
            uint8_t buttonPrev[] = {1, 1, 1, 1, 1, 1};
            MyMessage scene(SCENE_CHILD_ID, V_SCENE_ON);
            void before()
            #ifdef LOCAL_DEBUG
              Serial.begin(BAUD_RATE);
              present(SCENE_CHILD_ID, S_SCENE_CONTROLLER, CONTROLLER_CHILD_NAME);
              //Set up Pins
              for (int i = 0; i < ARRAY_SIZE(buttonPins); i++) {
                // Setup the pins
                pinMode(buttonPins[i], INPUT_PULLUP);
                debouncer[i].attach(buttonPins[i]);
                debouncer[i].interval(100);
                dbg(F("Set up contact Pin: "));
                dbgln(buttonPins[i]);
              pinMode(LED_PIN, OUTPUT);
              uint32_t currentMillis = millis();
                debouncer[i].update();
                // Get the update value
                uint8_t value = debouncer[i].read();
                if (value != buttonPrev[i]) {
                  dbg(F("Value is for sensor #"));
                  dbg(buttonPins[i]);
                  dbg(F(" is "));
                  dbgln(value);
                  if (value == 0)
                    //Button is pressed send scene value
                    send(scene.set(sceneNum[i]));
                    ledOn = 1;
                    ledMillis = currentMillis;
                  buttonPrev[i] = value;
              if (ledOn)
                digitalWrite(LED_PIN, HIGH);
                if (currentMillis - ledMillis > FLASH_TIME)
                  ledOn = 0;
                  digitalWrite(LED_PIN, LOW);
              @neverdie said in What did you build today (Pictures) ?:
              Yes, but that would unfortunately completely defeat my purpose. The device should be easy to install (I can't expect the end-user to coil their cable) and work with cables that are designed for >10A which means they will be too thick to coil. I understand that I did not mention all aspects of the use case in my post though so thanks anyway.
              NeverDieN 1 Reply Last reply
              • petewillP petewill
                My son and I finally finished his first MySensors project- a remote control for his room. He wasn't too interested but you have to start somewhere right...? :)
                Question for you all... what are you doing (if anything) to vent the fumes from soldering? I haven't really been worried about it in the past but it makes me nervous with my son doing it with me.
                Anyway, here are the pictures.
                Nca78N
                Nca78N
                @petewill said in What did you build today (Pictures) ?:
                I have a Hakko 493 clone, it has a carbon filter to absorb the smoke (or most of it) so it doesn't smell too much in the room when I need to solder for a long time and I can't open the windows. I don't have a link because I bought it in my local shop (it was cheaper than AliExpress + shipping), but you can easily find similar models or clones of the FA400 by searching "smoke absorber" on AliExpress.
                petewillP 1 Reply Last reply
                  NeverDieN
                  NeverDieN
                  #408
                  @mfalkvidd
                  I had a similar requirement recently, which was determining when my CNC was finished. I decided to measure the current to decide that. It's 24VDC and might have a current as high as 6amp in a theoretical worst case, but as little as 0.5a when moving just one of the stepper motors. So, what I came up with was this, which I've tested and it works:
                  Basically, it uses six 5-watt 3 ohm resistors in parallel to create a 1/2-ohm sense resistor, which an arduino then measures the voltage drop across by just doing an analog read from an analog GPIO pin across a voltage divider. I don't really know your use-case, but maybe you could adapt it for your application? You can ignore the LoRa module, which in my case I use to send out a signal to a remote receiver inside my house that the CNC print job (in the garage) is done.
                  • sundberg84S
                    #409
                    I made a MysX template for anyone who wants to create a MysX board to any EasyPCB in KiCadd.
                    Found here: https://github.com/sundberg84/HomeAutomation/tree/master/MysX template EasyPCB
                    • Nca78N Nca78
                      petewillP
                      petewillP
                      petewill
                      @nca78 thanks! I'll check that out.
                      • NeverDieN
                        NeverDieN
                        Today I made and assembled a board which instantiates the schematic I posted above two days ago on this thread:
                        Basically, it sends a wireless signal as soon as the CNC machine finishes its work.
                        gohanG 1 Reply Last reply
                          My old Yamaha YSP-1100 soundbar just decided to die.
                          After some searching I found the problematic capacitor. A 22uF 600V had dropped to 6uF....
                          1_1519064477580_20180219_191926.jpg !
                            NeverDieN
                            NeverDieN
                            @hek How did you find the faulty capacitor?
                              @NeverDie, well, I started my trouble shooting with a lucky google search. For old devices like this, you are often not the first person experiencing a problem.
                                I had a good laugh when examining the other board. Is this a normal solution for remote-in?
                                YveauxY dbemowskD 2 Replies Last reply
                                  YveauxY
                                  YveauxY
                                  @hek said in What did you build today (Pictures) ?:
                                  DIY optocoupler?
                                    dbemowskD
                                    dbemowskD
                                    @hek If this is for a sound bar, I know on some older stereos they had a remote signal out that you could tie into other components in the system. Maybe it's something like that.
                                      @neverdie could you achieve something similar with a sonoff pow measuring the whole cnc power consumption?
                                        NeverDieN
                                        NeverDieN
                                        #419
                                        @gohan I don't know, as I'm not familiar with Sonoff, or how sensitive it is.
                                          It's a WiFi power meter with a relay to turn off the load, so you could set a rule on controller that if measured power goes below a certain amount it will notify something
