  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 752.0k Views 98 Watching
  • NeverDieN NeverDie
    @dbemowsk Nice work!
    Now that I finally own a 3D printer, I can't believe I waited so long to get one. I encourage anyone who doesn't yet have a 3D printer to get one too. Sharing enclosure files in addition to PCB designs is the next level.
    bjacobseB
    bjacobseB
    bjacobse
    @neverdie I can only agree - to buy ans use a 3D printer is really good and some fun too
      alexsh1A
      alexsh1A
      alexsh1
      @neverdie how are you getting on with setting the printer up? I have been struggling with the correct setting for some time with problems like the plastic would stick to the surface even though it is pre-heated. At the end I got really frustrated and retuned the printer. I am using www.3dhubs.com now if I need to print anything.
      dbemowskD NeverDieN 2 Replies Last reply
      • alexsh1A alexsh1
        dbemowskD
        dbemowskD
        @alexsh1 What brand/model of printer were you using? Also, what type of plastic were you trying to print with?
        alexsh1A 1 Reply Last reply
        • alexsh1A alexsh1
          NeverDieN
          NeverDieN
          #524
          @alexsh1 said in What did you build today (Pictures) ?:
          It's working like a dream with both PLA and PETG, which are the only plastics I've tried thus far. I'm using the Prusa I3 MK3 (Prusa's 4th generation 3D printer). Following dbemowsk's suggestion, I'm now using Octoprint, running on a Raspi3b, which is mostly useful for uploading print files and monitoring from a distance using a webcam. Honestly, though, once it gets past the first layer, I haven't had any failures, so the webcam probably isn't needed at all.
          • dbemowskD dbemowsk
            alexsh1A
            alexsh1A
            alexsh1
            @dbemowsk I was using PLA. The printer was the most popular model on Amazon.
            That's the one:
            https://www.amazon.co.uk/Wanhao-i3-V2-Duplicator-3D-Printer/dp/B01LWL4CTY/ref=sr_1_11?s=industrial&ie=UTF8&qid=1526325539&sr=1-11&keywords=3d+printer
            dbemowskD 1 Reply Last reply
            • alexsh1A alexsh1
              That's the one:
              dbemowskD
              dbemowskD
              @alexsh1 Strange, that looks like a pretty decent printer.
              • NeverDieN
                NeverDieN
                @alexsh1 You can buy PEI print beds as an add on for most printers. Maybe that might have helped your issue. When printing PLA, I print a 5mm brim on the first layer, and that keeps the print object from prematurely dislodging later. Haven't needed a brim though when printing PETG, which just naturally bonds very strongly to the PEI print bed.
                If there are going to be failures, they'll probably happen in the first layer. Once you get beyond that, it's smooth sailing.
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @neverdie said in What did you build today (Pictures) ?:
                  That's exactly what happened. The first layer simply would not stick to the surface. Especially, if it is, say, a larger project box. For small items - no problem.
                  I must admit I did not spend too much time on this. I tried it for a week and then just returned it. Too much trouble for occasional prints I do.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @dbemowsk It is a good printer I suppose. I only used PLA and just did not spent too much time trying to find the right settings. Given that a few prints I ordered were also warped at the first run, I concluded that this is still at the DIY stage.
                    I'll probably get a printer when technology is going to be more advanced.
                    • alexsh1A alexsh1
                      dbemowskD
                      dbemowskD
                      @alexsh1 NO problem. I realize they are not for everyone.
                      • vladimirV
                        vladimirV
                        vladimir
                        Finally, I can join this discussion!
                        Today I drew a scheme of my first device! This is a system to protect against water leakage. I also posted it in the "hardware" section. Link.
                        • sundberg84S
                          A temp-node on 2xAA. Also a sneak-peak on EasyPCB rev 10...
                          https://youtu.be/TxzvhG4uo9I
                          bjacobseB M 2 Replies Last reply
                          • sundberg84S sundberg84
                            bjacobseB
                            bjacobseB
                            bjacobse
                            @sundberg84 Which microscope are you using, looking 8:07 into your video?
                            • bjacobseB bjacobse
                              @bjacobse it's the cheapest one on eBay with the software cheese on Linux. I think it's a replica on Andostar x500 so search Usb microscope Andostar and you will find.
                              mfalkviddM bjacobseB 2 Replies Last reply
                                @sundberg84 very professional video with multiple camera angles. Great work!
                                  I've been busy this week building my first native android app in (nativescript-vue). It will control my new car charging station (HALO Wallbox). The charging port will automatically turn on when I'm closing in to our house and turn off off when leaving the area.
                                  NeverDieN 1 Reply Last reply
                                    NeverDieN
                                    NeverDieN
                                    @hek Is that to prevent others from using it?
                                      @NeverDie, yes, and to have a small project to learn app development.
                                      • GertSandersG
                                        GertSandersG
                                        GertSanders
                                        wrote on last edited by GertSanders
                                        #539
                                        One of three ongoing projects:
                                        lasercut box
                                        atmega1284p based
                                        DS3231 rtc (very accurate and 2 alarms!)
                                        LDR
                                        20 by 4 LCD, two sizes of numbers, menu driven setup
                                        buzzer
                                        leds for moodlighting
                                        doppler for proximity detection
                                        encoder for scrolling through values (for setting time)
                                        buttons with LED feedback for interactivity
                                        mp3 player
                                        most interface objects MySensorised :-)
                                        This entry is to boost my energy, because we are still a long way from home (pcb is still not made, focus is now on prototype and software).
                                        • NeverDieN
                                          NeverDieN
                                          #540
                                          I love the design of the air vent on the righthand side of your laesrcut box. Does that pattern have a name?
                                          GertSandersG 2 Replies Last reply
