  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 753.0k Views 98 Watching
  • FotoFieberF FotoFieber
    My actual project is a doorbell sensor with additional temperature and humidity sensors. Tried different ways to detect the ring:
    • hall sensor (failed)
    • microphone (FFT, ongoing research)
    • optocoupler to detect the 12V AC -> favorite solution
    As I was heavy prototyping, I tried wire wrapping and it is fun:
    bjacobseB
    bjacobseB
    bjacobse
    @fotofieber
    Wirewrapping is an "old" and well proven technology, remember to have extra cable in case you need to re-wire your cables. Not so popular by DIY as tools used to be fairly expensive as it was protected by patents...
    • bjacobseB bjacobse
      @monte I didn't notice this, but you are right, "hidden" LCD :-)
      bjacobseB
      bjacobseB
      bjacobse
      wrote on last edited by bjacobse
      #722
      @bjacobse
      Just to add a little more info about adding a GND plane to your PCB
      I work in a electronic company, not doing PCB layout there though.
      but we have a TV adapter which have 2.4GHz transmitter. and this PCB is GND on both sides and with plenty GND via's (all the small holes) to ensure good grounding
      In case you wonder what it is, then it's an Oticon TV adapter 3.0
      https://www.youtube.com/watch?v=r4bTIQPdCEo
      • alowhumA
        alowhumA
        alowhum
        A picture from the touch screen version of the universal 433Mhz signal cloner.
        • kalinaK
          kalinaK
          kalina
          I have finished an enclosure for the my MDMSPanel "Nextion" today.
          4_1550659232406_Panel_5.png 3_1550659232406_Panel_4.png 2_1550659232405_Panel_3.png 1_1550659232405_Panel_2.png 0_1550659232404_Panel_1.png
          dbemowskD bjacobseB 2 Replies Last reply
          • alowhumA
            alowhumA
            alowhum
            #725
            Wow, very cool! Can you share a bit more about the project? Is it MySensors based? Is there code available? What does the hardware inside look like? What processor is it base on?
            Ah, scrolling up answered some of my questions :-)
            kalinaK 1 Reply Last reply
            • alowhumA alowhum
              kalinaK
              kalinaK
              kalina
              @alowhum Yes of course. I am going to publish this project this week.
              • kalinaK kalina
                dbemowskD
                dbemowskD
                @kalina Kudos on the case. Is that a case you designed, or is it a prefab case that you bought somewhere? I am assuming that from the markings inside the case that it is a prefab.I do like the design though and love it's underlying project. Is that just a thermostat, or is it a multi option controller?
                • dbemowskD dbemowsk
                  kalinaK
                  kalinaK
                  kalina
                  @dbemowsk Yes, it is a factory case, and before the changing it looked like this :
                  At the moment this is termostat, but I will not limit myself to this)) The purpose of the panel will be determined by the software project loaded into it. I will describe this in more detail when I publish the project.
                  dbemowskD 1 Reply Last reply
                  • kalinaK kalina
                    bjacobseB
                    bjacobseB
                    bjacobse
                    @kalina
                    Yes it's very impressing what you have achieved
                    • kalinaK kalina
                      dbemowskD
                      dbemowskD
                      @kalina I like that case design so much that I may design one like it in OpenSCAD and post it on thingiverse.
                        @kalina
                        kalinaK
                        kalinaK
                        kalina
                        wrote on last edited by kalina
                        #731
                        @bjacobse said in What did you build today (Pictures) ?:
                        Thanks, the project is published already.
                        https://www.openhardware.io/view/676/MDMSPanel-Nextion
                        • FotoFieberF
                          FotoFieberF
                          FotoFieber
                          Building a (xenon) flash to notify alarms. Flashes every 5 seconds if activated.
                          • sundberg84S
                            O 1 Reply Last reply
                            • sundberg84S
                              Today I made a iscp pogo pin adapter... Great for uploading bootloaders.
                              • berkseoB
                                berkseoB
                                berkseo
                                Almost finished one of my projects. The test sketch showed that HW works as it should. Now i need to make good software.
                                https://youtu.be/dfhDseDaGiA
                                • sundberg84S sundberg84
                                  O
                                  O
                                  Omemanti
                                  @sundberg84 that board looks nice and crisp 👍
                                  • berkseoB
                                    berkseoB
                                    berkseo
                                    Birth of water leakage sensor:) on mysensors..
                                    https://youtu.be/xsoeffaGAG0
                                    • O
                                      O
                                      Omemanti
                                      wrote on last edited by Omemanti
                                      #738
                                      After months of slow painstaking work (day job is somewhat busy, o and the kids ;) ) I finally completed my Domoticz server(case) with Dashticz as frontend.
                                      The Endgame; when my new house is finished every room is monitored for motion, RH and Temperature using my MySensors PCB's. (Jung AS500 Node)
                                      Everything is monitored using a raspberry with a MySensors serial gateway (NRF52) and an RFLink controller for my KAKU switches.
                                      To make everything nice and shiny I use Dasticz to interface the data in a proper way using a tablet that somehow will be mounted on a wall or something.
                                      So far the introduction;
                                      To put everything away nice and tidy I used a box to install everything using 2 pieces of din-rail.
                                      It has a 230V inlet that is converted to 5V using an off the shelf (safety sake) MeanWell RS-15-5 converter. This powers everything using a couple of din-Rail terminals.
                                      • Terminal => USB-micro => Raspberry
                                      • Terminal => just a couple of wires => old nrf52 prototype => FTDI => Raspberry
                                      • Raspberry => RF-link (ard. Mega +433mhz)
                                      Since the Raspberry has Wifi no other cable then power is needed to operate
                                      Second part: the 2 screenshots of dasthicsz.
                                      The best part, it took some work, but the WAF incread big time, because everything looks clean :)
                                      • O Omemanti
                                        dbemowskD
                                        dbemowskD
                                        @omemanti Nice DIN rail enclosure.
                                          O
                                          O
                                          Omemanti
                                          @dbemowsk
                                          If someone would be interested:
                                          Enclosure
                                          Ard. Mega enclosure
                                          Raspberry enclosure
                                          Had to do some modifications for the mega, but the cost of this enclosure was more than worth it.
                                          Hmz.. normaly don't buy stuff at conrad but apparently they have good prices on cases... 😏
                                          monteM 1 Reply Last reply
