  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 750.7k Views 98 Watching
  • O Omemanti
    @dbemowsk
    If someone would be interested:
    Enclosure
    Ard. Mega enclosure
    Raspberry enclosure
    Had to do some modifications for the mega, but the cost of this enclosure was more than worth it.
    Hmz.. normaly don't buy stuff at conrad but apparently they have good prices on cases... 😏
    monteM
    monteM
    monte
    @omemanti well...enclosure at a price of 3 raspberry pi zero. Good price indeed :)
    • sundberg84S
      • HonkH
        HonkH
        Honk
        Nothing fancy. Got my new ts100 today and I pre-soldered some V10 easyPCBs with 3.3v Arduino pro minis.
        The iron is pretty good. It is Louis Rossmann approved. Now I need a good 24V power source to drive this thing.
        • FotoFieberF
          FotoFieberF
          FotoFieber
          Testing a CCS811 CO2 sensor. It seems to use less power then the MH-Z14A I am using now. The CCS811 may even run on battery. I will compare measurements of these two sensors with a Netatmo sensor. The sensors have to burn in for two days bevore I start the comparison.
          The CCS811 breakout board I use hast temp, hum and barometer sensors (and the CO2).
          Nca78N 1 Reply Last reply
          • FotoFieberF FotoFieber
            Nca78N
            Nca78N
            wrote on last edited by Nca78
            #745
            @fotofieber said in What did you build today (Pictures) ?:
            Unfortunately this is not a CO2 sensor. It's only a VOC sensor giving an estimated eCO2 value. It's useful to tell you if your room needs ventilation, but not much more. And as even the VOC part is not calibrated it's only good for relative measurement.
            AFAIK the only similar sensors which are calibrated and give absolute values are SGP30 and BME680.
            If you want to measure CO2 you need a CO2 sensor and it's going to consume a lot of power, at least too much for a battery powered sensor.
            [edit] there's also the MiCS-VZ-89TE TVOC sensor, they claim to have a curve of eCO2 not too far from NDIR sensor in their datasheet. But that datasheet is strangely poor in details, they didn't even put any electrical characteristics...
            https://sgx.cdistore.com/datasheets/sgx/MiCS-VZ-89TE_V1.0.pdf
            FotoFieberF 1 Reply Last reply
            • berkseoB
              berkseoB
              berkseo
              My battery operated mini touch switch
              1_1554642160825_photo_2019-04-07_13-58-03.jpg 0_1554642160824_photo_2019-04-07_13-58-02.jpg
              • berkseoB
                berkseoB
                berkseo
                1_1554642422327_photo_2019-04-05_21-32-08.jpg 0_1554642422326_photo_2019-04-05_21-32-08 (2).jpg
                • sundberg84S
                  I don't think I ever managed to get it right the first revision.
                  • sundberg84S sundberg84
                    But it's something...
                      Nca78N
                      Nca78N
                      @sundberg84 you should print the board on paper, stick it on a piece cardboard and cut. Then check if size is good, you can even put the "big" components on it by sticking the pins through the cardboard to make sure you'll have enough space.
                      • Nca78N Nca78
                        @nca78 great tip! But it's more common it's a schematic or footprint error. The outline "should" be the easy part even if I messed up.
                        • Nca78N Nca78
                          FotoFieberF
                          FotoFieberF
                          FotoFieber
                          wrote on last edited by FotoFieber
                          #752
                          @nca78 said in What did you build today (Pictures) ?:
                          My tests will show, how far away I am with this sensor in my indoor usage scenario.
                          My Netatmo sensors claim to measure CO2 and are battery powered. They seem to calibrate themselves to the lowest level they measure in 24 hours. This behaviour seems to be similar with the CCS811. The Netatmo sensors seem quite close to my MH-Z14A.
                          In the datasheet for the CCS811 I have read, that you can't use them in your green house, because of its self calibration. Netatmo may have the same restriction too.
                          I have ordered a SGP30 some days ago and will test it too. The BME680 needs binary code linked which is a no go for me. (As a gift I would take it into my test setup. :) )
                          The problem with high power sensors is, that they produce heat, which can make your temperature measurements unusable. :(
                          As my CO2 sensors have a color led to show air quality, they are mains powered anyway.
                          Thank you for the link. I have ordered one for my test setup. They are really expensive, about twice the price of the MH-Z14A, the SGP30 or the CCS811.
                          Other CO2 sensors I should use in my test setup?
                          I like the MH-Z14A and depending on my tests may stay with them.
                          EDIT: ordered a MHZ-19 for the tests
                            Nca78N
                            Nca78N
                            Make sure you order a MHZ-19B, it uses less power and has fixed an autocalibration problem.
                            SenseAir S8 has a better calibration process using several days, so if you don't ventilate your room during 24h it will not use a wrong reference level and report wrong values.
                            And about BME680 there are boards on AliExpress with included STM32 Cortex M0+, basically it's the same than the MiCS-VZ-89. Search for GY-MCU680V1.
                            • Nca78N Nca78
                              FotoFieberF
                              FotoFieberF
                              FotoFieber
                              #754
                              Thx, ordered one on aliexpress. Hope I have time to test when they arrive... :)
                              EDIT: first results, hope CCS811 will calibrate better in the next two days
                              • berkseoB
                                berkseoB
                                berkseo
                                wrote on last edited by berkseo
                                #755
                                All elements are assembled :)
                                https://youtu.be/U437QXp3pqI
                                petewillP 1 Reply Last reply
                                • berkseoB berkseo
                                  petewillP
                                  petewillP
                                  petewill
                                  @berkseo nice! What did you use for the capacitive sensor? MPR121?
                                  • petewillP petewill
                                    Nca78N
                                    Nca78N
                                    @petewill said in What did you build today (Pictures) ?:
                                    TTP223s in top left and top right corners ;)
                                    @berkseo I'm curious about that, why not use the capacitive touch function of the NRF52832 ?
                                    berkseoB 1 Reply Last reply
                                    • berkseoB
                                      berkseoB
                                      berkseo
                                      yep :)
                                      • Nca78N Nca78
                                        berkseoB
                                        berkseoB
                                        berkseo
                                        Ttp223 chips suit me. Very stable stuff. When I tried to do it on amtel328, these mcu also had this feature (almost all mcu have this feature). But it was not very stable. I'm not sure that a stable device using the mcu 52832 would be possible. If there is an example of a stable software implementation, I would be happy to test it, and then it would be clear to do it without external capacitive chips or not.
                                          My new workbench is coming along nicely.
