  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 819.9k Views 98 Watching
    #81
    Today I also started upgrading my Domoticz running Raspbian 7 (Wheezy) to Raspbian 9 (Stretch). I tried to do an in-place upgrade but the rpi wouldn't start after the upgrade so I had to start over on a clean Raspbian 9 image.
    I took the chance to switch to f2fs for the root filesystem, which should make the SD card less susceptible to corruption. I used this guide and it worked, except that I also added discard to the fourth field in /etc/fstab and changed the sixth field to 0 to not fsck before boot.
    When I wake up tomorrow, domoticz might have finished compiling.
    sinczeS 1 Reply Last reply
    • dbemowskD
      dbemowskD
      Though not directly MySensors related, I am setting my 3D printer up with some lights to see my prints for my MySensors projects better when running a job. These are some white LED light assemblies that have been salvaged from some recycled document cameras. I built a simple 7805 regulator circuit to run them. The next step is to design and print some brackets and articulating arms to mount them to the printer.
      0_1510472883445_upload-624321fb-df7a-41d4-a54f-1b8337715289
      0_1510472909796_upload-ad6d9514-19ea-43dd-91ce-87e302af64f5 0_1510472927556_upload-0332836f-c3ef-4256-9df9-60c6f6980b28
        sinczeS
        sinczeS
        sincze
        MySensors Evangelist
        wrote on last edited by sincze
        #83
        @mfalkvidd ai ai. Yes. I was warned on the Domoticz website about the 'not being able to startup'. I was able to successfully update from Wheezy to Jessi. Skipped the Stretch part for now.
        Just made some preparations for the new node that has to replace several individual nodes in the technical-room. (Control of WTW, Measurement of heating pipes of CV using Temperature Sensors, Leakage Detector of CV, Door Sensor and last but not least OTGW-Reset)
        Could not complete the PCB due to some missing components. The Sketch is running fine on my NANO
        Looks like a mess now, but this development PCB comes in quite handy.
        • scalzS
          scalzS
          wrote on last edited by scalz
          #84
          That was yesterday.. :blush:
          @tekka and I tested some new features he made, so here was my humble and fun test setup
          Of course the Halo GW didn't disappoint us! All boards (mixed mcus and radios nodes) were attacking it at an agressive rate (100ms rate), and there was no crash at all. Halo GW was laughing & kidding us saying "Please give me more, I like doing this" :) (but I was lazy to assemble more, there was 13 nodes on the table..).
          Too strong @tekka ;)
          • NeverDieN
            NeverDieN
            #85
            Here is my Wemos "Serial" wireless gateway that I just today put together and installed. Connects to Domoticz as an ethernet gateay over wi-fi. Uses a static IP address that I configured on the wi-fi router. By the way, it's powered (and physically supported) by an Ikea USB charger, as seen in the photo. :)
              wrote on last edited by gohan
              #86
              Mqtt IR remote controller for air conditioning / heat pump
              Quick interface design using Mqtt dash
              Not mysensorized, but still a neat and cheap solution.
              NeverDieN 1 Reply Last reply
                NeverDieN
                NeverDieN
                @gohan That would make for a very interesting project write-up, so that others might quickly replicate your work without a lot of head scratching.
                  It is actually very simple project: I followed this guide -> http://www.sysrun.io/2017/02/22/use-a-esp8266-to-control-your-ac-via-mqtt/ and used a pn2222a to boost the IR Led.
                  Also the app is very simple: just link each item to one of the topics.
                  It was meant to be a simple stand alone solution, connected to an external mqtt broker so you can turn on heating/cooling before coming back home without using any complex Home automation system. It is still in the test phase as I just have the IR led transmitting something and I have to test if it is actually working with the Daikin unit I need to control (it is not in my house so I have to way for the real test)
                  • sinczeS
                    sinczeS
                    sincze
                    #89
                    With help of @dbemowsk @sundberg84 I was able to complete my "CV All in one sensor" using the easy PCB. ;-)
                    It now replaces 2 Arduino Nanos with only 1 Easy PCB. Currently the 0,1u Capacitor is missing, however as I was told by the designer it still could work. And it does.
                    This node:
                    • monitors the pipes of my central house heating,
                    • Is able to detect if the heating unit has a leakage.
                    • Switches on the light if the door is opened
                    • if the humidity in the bathroom becomes to high, or somebody is cooking.. It will start the BRINKS central WTW.
                    • Can reset my OTGW unit if it has a lock up.
                    • S
                      SquareKinematics
                      4x cheap load cells under each foot of my bed
                      Sparkfun HX711 breakout and an Arduino
                      Was going for a bed occupancy sensor, but I got a pretty decent scale out of it, it is sensitive enough that it registers if I put my water bottle down on the bed.
                      Nca78N 1 Reply Last reply
                      • S SquareKinematics
                        Nca78N
                        Nca78N
                        @SquareKinematics said in What did you build today (Pictures) ?:
                        Sounds awesome if it's that precise, could you make a post in "My Project" with reference to the load cells you used, wiring and some test code ? Thank you in advance :)
                        • Nca78N Nca78
                          SquareKinematics
                          @Nca78 I will be sure to do that when it's done, it's still a little rough around the edges :)
                          • sundberg84S
                            Today I made a pogo pin programming board for my Logger. (The logger works except one last thing... Rev 5 here we come!)
                            • nagelcN
                              nagelcN
                              nagelc
                              I've been playing with an Adafruit AudioFX board and cobbled together this annunciator. Eventually it will be a MySensors node to play alarms or other sounds. It is using a cheap portable speaker to play the sounds. I got it to work with my doorbell button node today.
                              annunciator test
                              • sundberg84S
                                Last fix done on my Logger... I will send it to pcb house today and probably publish a beta on openhardware. Probably nothing special but for me as hobby pcb maker this has been a challenge and great knowledge increase in using oscilloscope and new components.
                                Tomorrow Black Friday!! (I work in retail so that's a high focus now...)
                                • NeverDieN
                                  NeverDieN
                                  #96
                                  Yesterday received the PCB. Today assembled for testing this battery-powered nRF52-based passive infrared motion detector:
                                  YveauxY I 2 Replies Last reply
                                  • NeverDieN NeverDie
                                    YveauxY
                                    YveauxY
                                    #97
                                    Battery powered MySensors Washing machine & dryer monitor, using LDR's to monitor LEDs on front of the appliances.
                                    Each time a LED toggles, the node wakes from interrupt and sends a message. Easy peasy!
                                    When a device is ready, I'll get a message on my mobile phone :smile:
                                    0_1511607742913_upload-656fdf4c-6707-4a8b-a58c-ef7e74fe1b9f
                                    0_1511607798459_upload-0183f0a1-571d-45e6-8ecc-b4a33fd9c4e9
                                    Still need to stuff it in an enclosure...
                                    gohanG bjacobseB dbemowskD 3 Replies Last reply
                                    • YveauxY Yveaux
                                      @Yveaux said in What did you build today (Pictures) ?:
                                      Yes, definitely very low WAF 😁
                                        #99
                                        @gohan - you mean HIGH waf? :) I really like the design... (if the first picture is only what you see)
                                        YveauxY 1 Reply Last reply
                                        • sundberg84S sundberg84
                                          YveauxY
                                          YveauxY
                                          @sundberg84 said in What did you build today (Pictures) ?:
                                          Ofcourse! WAF is overrated anyhow...
