1.1k Posts 105 Posters 792.9k Views 98 Watching
    It is actually very simple project: I followed this guide -> http://www.sysrun.io/2017/02/22/use-a-esp8266-to-control-your-ac-via-mqtt/ and used a pn2222a to boost the IR Led.
    Also the app is very simple: just link each item to one of the topics.
    It was meant to be a simple stand alone solution, connected to an external mqtt broker so you can turn on heating/cooling before coming back home without using any complex Home automation system. It is still in the test phase as I just have the IR led transmitting something and I have to test if it is actually working with the Daikin unit I need to control (it is not in my house so I have to way for the real test)
    • sinczeS
      sinczeS
      sincze
      MySensors Evangelist
      wrote on last edited by sincze
      #89
      With help of @dbemowsk @sundberg84 I was able to complete my "CV All in one sensor" using the easy PCB. ;-)
      It now replaces 2 Arduino Nanos with only 1 Easy PCB. Currently the 0,1u Capacitor is missing, however as I was told by the designer it still could work. And it does.
      This node:
      • monitors the pipes of my central house heating,
      • Is able to detect if the heating unit has a leakage.
      • Switches on the light if the door is opened
      • if the humidity in the bathroom becomes to high, or somebody is cooking.. It will start the BRINKS central WTW.
      • Can reset my OTGW unit if it has a lock up.
        SquareKinematics
        4x cheap load cells under each foot of my bed
        Sparkfun HX711 breakout and an Arduino
        Was going for a bed occupancy sensor, but I got a pretty decent scale out of it, it is sensitive enough that it registers if I put my water bottle down on the bed.
        Nca78N 1 Reply Last reply
        • S SquareKinematics
          @SquareKinematics said in What did you build today (Pictures) ?:
          Sounds awesome if it's that precise, could you make a post in "My Project" with reference to the load cells you used, wiring and some test code ? Thank you in advance :)
          S 1 Reply Last reply
          • Nca78N Nca78
            SquareKinematics
            @Nca78 I will be sure to do that when it's done, it's still a little rough around the edges :)
            • sundberg84S
              sundberg84S
              Today I made a pogo pin programming board for my Logger. (The logger works except one last thing... Rev 5 here we come!)
              • nagelcN
                nagelcN
                nagelc
                I've been playing with an Adafruit AudioFX board and cobbled together this annunciator. Eventually it will be a MySensors node to play alarms or other sounds. It is using a cheap portable speaker to play the sounds. I got it to work with my doorbell button node today.
                annunciator test
                • sundberg84S
                  sundberg84S
                  Last fix done on my Logger... I will send it to pcb house today and probably publish a beta on openhardware. Probably nothing special but for me as hobby pcb maker this has been a challenge and great knowledge increase in using oscilloscope and new components.
                  Tomorrow Black Friday!! (I work in retail so that's a high focus now...)
                    #96
                    Yesterday received the PCB. Today assembled for testing this battery-powered nRF52-based passive infrared motion detector:
                    YveauxY I 2 Replies Last reply
                      #97
                      Battery powered MySensors Washing machine & dryer monitor, using LDR's to monitor LEDs on front of the appliances.
                      Each time a LED toggles, the node wakes from interrupt and sends a message. Easy peasy!
                      When a device is ready, I'll get a message on my mobile phone :smile:
                      0_1511607742913_upload-656fdf4c-6707-4a8b-a58c-ef7e74fe1b9f
                      0_1511607798459_upload-0183f0a1-571d-45e6-8ecc-b4a33fd9c4e9
                      Still need to stuff it in an enclosure...
                      gohanG bjacobseB dbemowskD 3 Replies Last reply
                      • YveauxY Yveaux
                        @Yveaux said in What did you build today (Pictures) ?:
                        Yes, definitely very low WAF 😁
                          sundberg84S
                          sundberg84S
                          #99
                          @gohan - you mean HIGH waf? :) I really like the design... (if the first picture is only what you see)
                          • sundberg84S sundberg84
                            Ofcourse! WAF is overrated anyhow...
                            • YveauxY Yveaux
                              sundberg84S
                              sundberg84S
                              @Yveaux - Yes, as long as you don't tell her ;)
                              • YveauxY Yveaux
                                bjacobseB
                                bjacobseB
                                bjacobse
                                #102
                                @Yveaux
                                I think I have similar washing machine, doesn't the LED blink if leave the laundry inside the machine after it had ended washing?
                                Just curious, if you anyway have had the lid/cover removed from washing machine, why not solder wires parallel to LED and connect to an optocoupler that feeds signal direct to Arduino, and also take 5V supply from the washing machine, and then you can avoid using batteries
                                Nca78N YveauxY 2 Replies Last reply
                                • bjacobseB bjacobse
                                  @Yveaux
                                  @bjacobse it's pretty different to remove the top that's usually easily removable to put inside furniture, and to unmount front panel and then solder stuff on the PCB. High WAF probably includes ensuring the warranty is not void :D
                                    @Yveaux
                                    @bjacobse said in What did you build today (Pictures) ?:
                                    @Yveaux
                                    The sensor is placed on a led that lights when the machine is finished. I would prefer a led that is lit when it is washing and goes out when finished, but my machine hasn't any.
                                    Now I simply removed the cover to hide the wire. The electronics and led are hidden behind a lot of metal aan plastic. I didn't want to take the washer apart and the dryer too.
                                    Just a simple solution working for multiple devices.
                                    bjacobseB 1 Reply Last reply
                                    • YveauxY Yveaux
                                      @Yveaux
                                      bjacobseB
                                      bjacobseB
                                      bjacobse
                                      @Yveaux
                                      Ah this make good sense, I didn't think the electronics was hidden and difficult to get to
                                        @Yveaux
                                        It's German quality :smirk:
                                        • bjacobseB
                                          bjacobseB
                                          bjacobse
                                          Finally got my LoRaWAN RAk831 with RPI gateway online
