  3. Resolved - 18650 battery powered temperature sensors
14 Posts 3 Posters 5.5k Views 3 Watching
  • pihomeP
    pihomeP
    pihome
    wrote on last edited by pihome
    Hi Guys,
    need little bit help to refine my 18650 battery status, see below sketch, i have followed battery Battery Powered Sensors instructions. on hardware side i only removed both leds from arduino mini pro 3.3v and feeding it through raw pin, and have two resisters as per instruction as i m not electronics expert i just did lots of hit and miss but so far voltage on multimeter is 4.01 but arduino is reading it as 3.78. what i m doing wrong here????
    //PiHome Battery Powered Temperature Sensor
    //#define MY_DEBUG
    // #define MY_RF24_PA_LEVEL RF24_PA_LOW
    //#define MY_DEBUG_VERBOSE_RF24
    // RF channel for the sensor net, 0-127
    #define RF24_CHANNEL     125
    //PiHome Node ID
    #define MY_NODE_ID 25
    //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
    #define RF24_DATARATE 	   RF24_250KBPS
    #include <OneWire.h>
    // Define sensor node childs
    #define CHILD_ID_BATT 1
    #define CHILD_ID_TEMP 0
    #define COMPARE_BVOLT 0 // Send battery voltage only if changed? 1 = Yes 0 = No
    unsigned long SLEEP_TIME = 56000; // Sleep time between reads (in milliseconds)
    // Battery related init
    float oldBatteryV = 0;
    MyMessage msgBatt(CHILD_ID_BATT, V_VOLTAGE);
    // Dallas Temperature related init
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    void before()
      sensors.begin();
      // needed for battery soc
          analogReference(INTERNAL1V1);
      #else
          analogReference(INTERNAL);
    void presentation() {
      sendSketchInfo("Temperature Sensor", "1.33");
         present(i, S_TEMP);
      // get the battery Voltage
      int battSensorValue = analogRead(BATTERY_SENSE_PIN);
      float batteryV  = battSensorValue * 0.003695015;
        // 3.44/1023 = Volts per bit = 0.003363075 0.0036950146627566
    	int batteryPcnt = battSensorValue / 10;
    	#ifdef MY_DEBUG
    		Serial.print("Pin Reading: ");
    		Serial.println(battSensorValue);
    		Serial.print(batteryV);
    		Serial.println(" v");
    		//Print Battery Percentage
    		Serial.print(batteryPcnt);
    		Serial.println(" %");
    	#if COMPARE_BVOLT == 1
    		send(msgBatt.set(batteryV, 2));
    	#else
    		if (oldBatteryV != batteryV) {
    			oldBatteryV = batteryV;
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msgTemp.setSensor(i).set(temperature,1));
      sleep(SLEEP_TIME);
    PiHome - Smart Heating Control
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      what are your resistor devider values ? your "Volts per bit" value sugests that the max voltage you can measure is 3.78V so I guess you have wrong division ratio. I would go for 1M and 1k ohms, then you can measure up to 12V.
      • rozpruwaczR
        rozpruwaczR
        rozpruwacz
        and also this may help :) https://en.wikipedia.org/wiki/Voltage_divider
          Look at my post about solar powered node, I explained how to measure higher input voltage
          • pihomeP
            pihomeP
            pihome
            after changing r2 to 1k ohms and volts per bit to 1.076344086 i m getting first reading is 34.44v and then 2.15, this is even more messed up.... :(
            float batteryV  = battSensorValue * 1.076344086;
            4 MCO:BGN:BFR
            65 TSM:INIT
            65 TSF:WUR:MS=0
            73 TSM:INIT:TSP OK
            75 TSM:INIT:STATID=25
            77 TSF:SID:OK,ID=25
            79 TSM:FPAR
            116 TSF:MSG:SEND,25-25-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            438 TSF:MSG:READ,0-0-25,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            444 TSF:MSG:FPAR OK,ID=0,D=1
            2125 TSM:FPAR:OK
            2125 TSM:ID
            2127 TSM:ID:OK
            2129 TSM:UPL
            2164 TSF:MSG:SEND,25-25-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2355 TSF:MSG:READ,0-0-25,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2361 TSF:MSG:PONG RECV,HP=1
            2365 TSM:UPL:OK
            2365 TSM:READY:ID=25,PAR=0,DIS=1
            2371 TSF:MSG:SEND,25-25-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            2506 TSF:MSG:READ,0-0-25,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            2514 TSF:MSG:SEND,25-25-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
            2525 TSF:MSG:SEND,25-25-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            4534 TSF:MSG:SEND,25-25-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
            4544 TSF:MSG:SEND,25-25-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=OK:1.34
            4554 TSF:MSG:SEND,25-25-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
            4562 MCO:REG:REQ
            4564 TSF:MSG:SEND,25-25-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            4841 TSF:MSG:READ,0-0-25,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            4847 MCO:PIM:NODE REG=1
            4849 MCO:BGN:STP
            4851 MCO:BGN:INIT OK,TSP=1
            Pin Reading: 32
            Battery Voltage: 34.44 v
            Battery percent: 3 %
            4859 TSF:MSG:SEND,25-25-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:34.44
            4870 TSF:MSG:SEND,25-25-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:3
            4878 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
            4884 MCO:SLP:TPD
            4886 MCO:SLP:WUP=-1
            4919 TSF:MSG:SEND,25-25-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.7
            4927 MCO:SLP:MS=56000,SMS=0,I1=255,M1=255,I2=255,M2=255
            4933 MCO:SLP:TPD
            4935 MCO:SLP:WUP=-1
            Pin Reading: 2
            Battery Voltage: 2.15 v
            Battery percent: 0 %
            4941 TSF:MSG:SEND,25-25-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:2.15
            4952 TSF:MSG:SEND,25-25-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:0
            4960 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
            4966 MCO:SLP:TPD
            4968 MCO:SLP:WUP=-1
            5001 TSF:MSG:SEND,25-25-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.5
            5009 MCO:SLP:MS=56000,SMS=0,I1=255,M1=255,I2=255,M2=255
            5015 MCO:SLP:TPD
              I used R1 1.22M (1M + 220K) and R2 300K in order to read a maximum of 5.57v
              ((1e6+220e3+300e3)/300e3)*1.1 = Vmax = 5.57 Volts
              5.57/1023 = Volts per bit = 0.005448028
              • pihomeP
                pihomeP
                pihome
                Do you have 1m and 220k in series?
                  Yes of course. Use the following link to find the most suitable divider for the resistor you have, just remember to keep output voltage to 1.1 http://www.ohmslawcalculator.com/voltage-divider-calculator
                  • pihomeP pihome
                    4 MCO:BGN:BFR
                    65 TSM:INIT
                    65 TSF:WUR:MS=0
                    73 TSM:INIT:TSP OK
                    77 TSF:SID:OK,ID=25
                    79 TSM:FPAR
                    2125 TSM:FPAR:OK
                    2125 TSM:ID
                    2127 TSM:ID:OK
                    2129 TSM:UPL
                    2365 TSM:UPL:OK
                    4562 MCO:REG:REQ
                    4849 MCO:BGN:STP
                    Pin Reading: 32
                    4884 MCO:SLP:TPD
                    4886 MCO:SLP:WUP=-1
                    4933 MCO:SLP:TPD
                    4935 MCO:SLP:WUP=-1
                    Pin Reading: 2
                    4966 MCO:SLP:TPD
                    4968 MCO:SLP:WUP=-1
                    5015 MCO:SLP:TPD
                    rozpruwaczR
                    rozpruwaczR
                    rozpruwacz
                    @pihome sorry, I meant 100kOhm. I would suggest You to understand the theory behind the voltage divider, then you would know what you are doing and be able to solve your problem by yourself. This is just one simple formula, not magic.
                      I started to punch in resistor values more or less randomly of various combinations of the resistors I had until I got close enough to the maximum input voltage I wanted to have
                      • pihomeP
                        pihomeP
                        pihome
                        thank you guys for help, really appreciate this. for 18650 battery with 4.2volt in following combination would do the job for you, i m adding here so in future if some one wants reference and save some time on trial and error. @rozpruwacz i m using your idea with 1m and 100k thank you for help.
                        620k
                        220k
                        1.1v out
                        470k
                        170k
                        1.116v out
                        1m
                        355k
                        1.1v out
                        220k
                        80k
                        1.12v out
                        680k
                        270k
                        1.194v out
                        390k
                        150k
                        1.167v out
                        330k
                        120k
                        1.12v out
                        270k
                        100k
                        1.135v out
                          Try to use the highest total resistance in order to lower the battery drain as much as possible
                          pihomeP 1 Reply Last reply
                            pihomeP
                            pihomeP
                            pihome
                            @gohan i m using 1m with 100k but second best combination would be then 620k with 220k ?
                              Yes, but there could be also other combinations that will allow you to detect higher voltage but with an higher total resistance
