  3. Send time request over arduino "monitor serial"
14 Posts 3 Posters 5.0k Views 2 Watching
  • ch3b7C
    ch3b7C
    ch3b7
    How can i send a time request ?? " over monitor serial in arduino ...
    1;255;3;0;1;14:55:30 06/01/2015" something like this??
    thanks! im finally complete the most part of my windows controller in .net ^^
      You can't.
      The serial messages you enter in monitor is only destined to radio network. Whilst the time request is sent from a node over radio network to gateway/controller.
      • ch3b7C
        ch3b7C
        ch3b7
        thanks man!
        • ch3b7C
          ch3b7C
          ch3b7
          when the node send "gw.requestTime(receiveTime); " i cant answer from arduino monitor serial no?
            yes, you can
            • ch3b7C
              ch3b7C
              ch3b7
              how, who need send?? or an example
                Something like:
                <node-id>;255;3;0;1;<seconds since 1970>\n
                • ch3b7C
                  ch3b7C
                  ch3b7
                  thanks, the problem is i dont know who is "<seconds since 1970> any example? im use a custom controller.
                    Depends on your programming language. Normally you would have a function returning milliseconds since 1970. Just divide this with 1000.
                    • ch3b7C
                      ch3b7C
                      ch3b7
                      wrote on last edited by ch3b7
                      WORK! im get "1420578901" ^^ thanks HEK!
                      im have other question about the light actuator with a button, i send the command to tun on/off its works, but can the node can send again the new state when received the turn on/off command? sorry for my bad english im from argentina^^ im needed to update the state in my controller and know if the command sended work.
                      this work but when i press the button the controller send 2 sets commands
                      **void incomingMessage(const MyMessage &message) {
                      if (message.isAck()) {
                      // Change relay state
                      state = message.getBool();
                      // Store state in eeprom
                      gw.saveState(CHILD_ID, state);
                      // Write some debug info
                      Serial.print(message.sensor);
                      gw.send(msg.set(state), false); // Send new state and request ack back
                        Just request ack from the node by setting ack parameter to 1.
                        <node-id>;<child-sensor-id>;<message-type>;<ack>;<sub-type>;<payload>\n
                        The node will then respond back with the same message in return. (You don't need to update sketch code)
                        • ch3b7C
                          ch3b7C
                          ch3b7
                          THANKS for your help!!
                          E 1 Reply Last reply
                          • ch3b7C ch3b7
                            E
                            E
                            ericvdb
                            @ch3b7 do you mind sharing your .net code?
                            • ch3b7C
                              ch3b7C
                              ch3b7
                              HERE my source code my-sensors-controller-net
