  3. DHT plus two relays
DHT plus two relays
5 Posts 3 Posters 1.6k Views 4 Watching
  • N
    N
    Newzwaver
    HI Everyone,
    I have my temp/hum sensor in my AV cab and what two computer fans to cool it down. I have tried this and it originally worked with one relay and I got creative and screwed it up. When i tried to get it back to the original version i couldn't as I yes saved over it. I have checked on the forum and see projects like this but they don't appear to work. Can should one give a few pointers?
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 29
    #include <MyConfig.h>
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    #define RELAY_1  4
    #define CHILD_ID_HUM 28
    #define CHILD_ID_TEMP 29
    #define NUMBER_OF_RELAYS 1
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 40000;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    void before()
    pinMode(pin, OUTPUT);
    sendSketchInfo("TempHumRelay", "1.2");
      present(CHILD_ID_HUM, S_HUM);
      present(sensor, S_BINARY);
       dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
      if (message.type==V_STATUS) {
        Serial.print(message.sensor);
    • N Newzwaver
      HI Everyone,
      #include <DHT.h>
      #define RELAY_1  4
      #define RELAY_ON 1
      #define RELAY_OFF 0
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      void before()
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      @Newzwaver in what way doesn't it work? It would be easier to help you if we knew what to look for :-)
      My best guess so far is that the node goes to sleep, which means it can not receive changes to the relays.
      • dbemowskD
        dbemowskD
        I am only speculating, but I think that he is missing the MySensors part of things. It sounds like he wants to run two relays with a temp/hum sensor and that's it. So he tries a MySensors sketch and without a gateway to respond, the sketch just hangs waiting for a gateway to connect to. Again, I could be wrong.
        • N
          N
          Newzwaver
          This works whether its correct or not it is working again.
          #define MY_NODE_ID 31
          #include <DHT.h>
          #define RELAY_1 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
          #define CHILD_ID_TEMP 27
          #define RELAY_ON 1 // GPIO value to write to turn on attached relay
          static const uint64_t UPDATE_INTERVAL = 10000;
          float lastTemp;
          float lastHum;
          bool metric = true;
          DHT dht;
          void before()
          sendSketchInfo("TempHum2Relay", "1.1B");
          if (!metric) {
          // Reset no updates counter
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          } else {
          nNoUpdatesHum++;
          // Change relay state
          // Store state in eeprom
          // Write some debug info
          dbemowskD 1 Reply Last reply
          • N Newzwaver
            #include <DHT.h>
            float lastTemp;
            float lastHum;
            bool metric = true;
            DHT dht;
            void before()
            if (!metric) {
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            } else {
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            } else {
            nNoUpdatesHum++;
            dbemowskD
            dbemowskD
            @Newzwaver When you post code, it helps out a lot if you use the code tag button </> before pasting in your code.
            The other alternative which is basically what the code tag button does is to put 3 tick marks ( ``` ) before and after your code.
            It keeps the code indented and makes it MUCH easier to read.
