  3. ESP8266 + Radio + Relay Working Fine
2 Posts 2 Posters 1.5k Views 2 Watching
  • N
    N
    Newzwaver
    HI Everyone,
    I noticed that I couldn't find a relay working with ESP8266MOD, I was messing with it over the last few days and figured out that the following sketch works. The big fix was in the sketch you use pin 0 for the relay and actually attach it to pin 3. This works great with WEMOS ESP8266.
    #define MY_NODE_ID 97 //esp8266relay
    #define MY_REPEATER_FEATURE
    #define RELAY_1 0 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    void before()
    pinMode(pin, OUTPUT);
    	present(sensor, S_BINARY);
    if (message.type==V_STATUS) {
    // Change relay state
    // Store state in eeprom
    // Write some debug info
    Serial.print(message.sensor);
    • N Newzwaver
      HI Everyone,
      void before()
      @Newzwaver I think that makes sense. D3 on Wemos D1 Minis is GPIO0. I usually use the Dn notation, because I find it easier to understand.
