  3. Dallas temperature and button sensor and repeater function
1 Posts 1 Posters 946 Views 1 Watching
  • F
    F
    floris
    wrote on last edited by floris
    after 2 years i started again with mysensors, specially for my sons aquarium. i have a temp-sketch working and a button-sketch-with red and green leds working (a reed contact float for water level, and green and red LED for indicate the level near the aquarium, besides a switch signal to the controller (domoticz)). i want to combine both sketches and i came up with this sketch. compiling works fine, but before im broke up my 2 working sketches, will this sketch work? or am i missing something or did i make some mistakes?
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    //#define MY_DEBUG
    #include <OneWire.h>
    #include <Bounce2.h>
    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
    #define CHILD_ID 6
    #define BUTTON_PIN  6  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
    int reading;     // the current reading from the input pin
    int GreenLedPin = 4;  // the number of the Green LED output pin
    int RedLedPin = 5;    // the number of the Red LED output pin
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      pinMode (GreenLedPin, OUTPUT);
      pinMode (RedLedPin, OUTPUT);
      Serial.begin(9600);
    void presentation() {
      sendSketchInfo("Aquarium Ben", "1.1");
         present(i, S_TEMP);
      present(CHILD_ID, S_DOOR);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
       debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
         reading = digitalRead(BUTTON_PIN);
      if (reading == 1) {
        digitalWrite(RedLedPin, HIGH);   // if tilted, turn the red LED ON
        digitalWrite(GreenLedPin, LOW);
       delay(500);
      } else {
        digitalWrite(RedLedPin, LOW);
        digitalWrite(GreenLedPin, HIGH);    // if not tilted, turn the green LED ON
     // sleep(SLEEP_TIME);
    thanks already, FLoris
