  3. Discreet APA102 or SK9822?
1 Posts 1 Posters 1.1k Views 1 Watching
  • J
    J
    johnyradio
    wrote on last edited by johnyradio
    hello
    i've purchased some hi-watt RGB LED's, similar to these:
    https://www.ebay.com/itm/100W-100Watt-RGB-Red-Green-Blue-High-Power-LED-Light-Lamp-Panel-Chip-DIY/401361314623
    i want to make an addressable string of 50 of these big guys , preferably using 4-wire protocol (with clock wire).
    How? I don't mind if it's a chip or a whole module. Also don't mind if it uses some other protocol-- does not have to be a standard.
    I cannot find a discreet APA102 or SK9822-- those chips seem only to be available on a board with an LED.
    Could any of these work?
    https://www.ebay.com/itm/PCA9685-16-Channel-PWM-Servo-RGB-LED-Driver-I2C-12-Bit-For-Arduino-BS1/262847153393
    https://www.ebay.com/itm/RGB-LED-Light-Modulator-Programmable-PWM-Controller-for-Arduino/362113940268
    https://www.ebay.com/itm/PCA9685-16-Channel-PWM-Servo-RGB-LED-Driver-I2C-12-bit-Part-for-Arduino-Hot/382170803578
    https://www.ebay.com/itm/9-channels-RGB-bi-color-LED-driver-w-256-level-PWM-TM1809-arduino-RGB-LED-strip/121039360751
    https://www.ebay.com/itm/10pc-Worldsemi-WS2801SO-3-Channel-RGB-Constant-Current-PWM-LED-Driver-WS2801/151850734726
    thx
