  3. Error when i compile sketch
8 Posts 3 Posters 5.5k Views 1 Watching
  • eliabieriE
    eliabieriE
    eliabieri
    When I want to compile the sketch so send sensor data to my RPi i get this error:
    BinarySwitchSensor:14: error: 'Bounce' does not name a type
    BinarySwitchSensor.ino: In function 'void setup()':
    BinarySwitchSensor:27: error: 'debouncer' was not declared in this scope
    BinarySwitchSensor.ino: In function 'void loop()':
    BinarySwitchSensor:40: error: 'debouncer' was not declared in this scope
    What can i do?
    hekH 1 Reply Last reply
    • eliabieriE eliabieri
      What can i do?
      @eliabieri
      You have probably just missed to add the libraries.
      • eliabieriE
        eliabieriE
        eliabieri
        No, I added them! Under Examples I can see the library.
        But theres something wrong with the include of the Bounce2.h, Sensor.h and RF24.h. They dont change to orange like EEPROM.h and SPI.h does.
        Its the same problem in every example sketch
          @eliabieri
          Hmm... something is obviously wrong in your setup. Did you restart IDE after adding the libraries?
          • eliabieriE
            eliabieriE
            eliabieri
            Yes I did!
            • eliabieriE
              eliabieriE
              eliabieri
              I found the solution.
              I copied all the libraries directly to the libraries folder of the Arduino IDE
              now it works!
              epierreE 1 Reply Last reply
                now it works!
                epierreE
                epierreE
                epierre
                I did that too, for arduino 1.0.1 under debian 7.5:
                In file included from /usr/share/arduino/libraries/RF24/RF24.h:788:0,
                from SerialGateway.cpp:26:
                /usr/share/arduino/libraries/RF24/RF24.c:27:21: fatal error: spi/spi.h: Aucun fichier ou dossier de ce type
                compilation terminated.
                when downloading 1.0.5 (following) I have:
                SerialGateway.ino:31:25: fatal error: avr/progmem.h: Aucun fichier ou dossier de ce type
                when running 1.5.6r2 or nightly I have:
                SerialGateway:41: error: ‘Gateway’ does not name a type
                SerialGateway:44: error: ‘MAX_RECEIVE_LENGTH’ was not declared in this scope
                SerialGateway.ino: In function ‘void setup()’:
                SerialGateway:50: error: ‘gw’ was not declared in this scope
                SerialGateway:57: error: ‘MsTimer2’ has not been declared
                SerialGateway:58: error: ‘MsTimer2’ has not been declared
                SerialGateway:60: error: ‘PCintPort’ has not been declared
                SerialGateway.ino: In function ‘void loop()’:
                SerialGateway:66: error: ‘gw’ was not declared in this scope
                SerialGateway.ino: In function ‘void startInclusionInterrupt()’:
                SerialGateway:73: error: ‘gw’ was not declared in this scope
                SerialGateway.ino: In function ‘void ledTimersInterrupt()’:
                SerialGateway:77: error: ‘gw’ was not declared in this scope
                SerialGateway.ino: In function ‘void checkSerialInput()’:
                SerialGateway:84: error: ‘gw’ was not declared in this scope
                SerialGateway:84: error: ‘inputString’ was not declared in this scope
                SerialGateway.ino: In function ‘void serialEvent()’:
                SerialGateway:102: error: ‘MAX_RECEIVE_LENGTH’ was not declared in this scope
                SerialGateway:104: error: ‘inputString’ was not declared in this scope
                SerialGateway:108: error: ‘inputString’ was not declared in this scope
                z-wave - Vera -> Domoticz
                • epierreE
                  epierreE
                  epierre
                  good news, it works but here is the solution:
                  • ide 10.3 to 1.0.5 fails to work.
                  • 1.5.6r2 works but the sketch directory is now called Arduino, and then it works...just select port to ttyACM0 and not COM1 !
