Is ARM the future of MySensors?
I certainly can see the appeal for the NRF5 series, which wil work perfect in areas with detached and terraced houses. But in Urban areas with lots of high rises the 2.4GHz band is a bit congested. So there another band will work much better.
In that regard I fully agree with @nagelc to pray to your deity of choice for HopeRF to start integrating an MCU with the RFM, or Nordic to start exploring a different part of the ether.
I have not set foot in the 'large' part of the MCU spectrum, but I have a Feather M0 in the house which will be the center of my new experiments.@davidzh said in Is ARM the future of MySensors?:
That's my case , there are 350 appartments in my building alone and my nrf24 network runs well, while my old 433MHz system regularly miss messages, that's why it will soon be replaced.
@nca78 said in Is ARM the future of MySensors?:
LoRa isn't as much affected by interference since it's spread spectrum.
So is anyone thinking they will use the encryption features on a normal Arduino? Or is it, as I was thinking, that if you want to use encryption you'll have to upgrade?
@alowhum if you only enable encryption (not signing) you can fit more into an atmga328p. Also, if you use a rfm69 radio, encryption is hw backed, so it require less flash space (thus potentially allow you to also fit signing).
Furthermore, using a atsha204a means signing also take less of flash since some of the algorithms are hw backed. -
Well, regarding the OP, I think I read somewhere that development would largely move to ARM, and that at some point it would stop on the atmega. Not sure that I'm recalling it correctly though. Is it true?
@anticimex: interesting.
This is my use case: all I want is that I put a password at the top of all my arduino files, and then my neighbours won't be able to receive my data because they don't have the password. That's encryption, right? At the moment anyone can pick up the values that my sensors are sending out into the city. And that's kinda creepy.
@alowhum the simple password option is the simplest way of enabling security. At the same time it is the most expensive as it does not require personalization and therefore is pure software based (except for rfm69 encryption). So you need to trade simplicity for code size.
That said, once you have figured out personalization (and there is plenty documentation on the matter) it can easily be repeated, as long as you keep the sketch used to program the personalization data. -
@alowhum also, the simple password option enable both signing and encryption so it takes up a lot of memory. If encryption is the only thing you want, just personalize the devices with an AES key and enable encryption only. It is not that good (fixed iv) and easily crackable by someone who has an idea about AES but it at least obfuscate your messages fairly well. Combined with signing it is better, but, again, that costs memory.
That said, once you have figured out personalization (and there is plenty documentation on the matter) it can easily be repeated, as long as you keep the sketch used to program the personalization data.@anticimex Hmm, I didn't realise that. Could it be an idea to create a MY_ENCRYPTION_SIMPLE_PASSWD feature as well, without the signing? Would that fit the "opportunistic curious neighbour" scenario?
@alowhum I bet there are hundreds of people interested in your house temperature :sweat_smile:
Btw, yes that is encryption@gohan said in Is ARM the future of MySensors?:
Btw, yes that is encryptionActually, just my temperature would already indicate
- Whether I am home or not. "He'll never know we took the jewelry".
- if I go on holidays a lot. "How is he paying for all that".
- Whether I am feeling ill (set it a bit higher). "Got a fever last week? Or did your grandma visit"?
- If I am environmentally conscious. Something I don't want to talk about at the neighbourhood BBQ..
- Etc.
Now add to that my other sensors.
Now add to that all the actuators (yikes!). -
Don't your neighbors have better things to do?
If nrf24 working on same/similar frequency as wifi, is it not being disturbed by other wifi networks? (I guess that in 350 apartments there are a minimum of 350 wifi networks).
I never quite understood how exactly nrf24 and wifi go along. -
I never quite understood how exactly nrf24 and wifi go along.@dakipro said in Is ARM the future of MySensors?:
I never quite understood how exactly nrf24 and wifi go along.It depends on the channels used by NRF24 and wifi networks, so far I've been lucky it seems :)
Also, high rise is in fact probably helping by having thick concrete walls with lots of rebars inside, attenuating radio signals. I see many networks but most of them have week signal. -
