  2. Bug Reports
  3. Sketchinfo from gateway
5 Posts 2 Posters 5.3k Views 1 Watching
  • marceltrapmanM
    marceltrapmanM
    marceltrapman
    wrote on last edited by marceltrapman
    When I send sketch info (like this gw.sendSketchInfo("Repeater", "1.0");) from the gateway I don't seem to receive the actual sketch info.
    Instead I see that the gateway 'want's to send it but does not actually do that.
    At least that is how I interpret it...
    2014-05-04 17:27:43	MySensors Debug	Receiving command 0;0;4;11;Tx: fr=0,to=0,la=0,ne=0,ci=255,mt=4,ty=14,cr=231: Gateway
    2014-05-04 17:27:48	MySensors Debug	Receiving command 0;0;4;11;Ack: receive timeout
    2014-05-04 17:27:53	MySensors Debug	Receiving command 0;0;4;11;Relaying message back to gateway.
    2014-05-04 17:27:58	MySensors Debug	Receiving command 0;0;4;11;Tx: fr=0,to=0,la=0,ne=0,ci=255,mt=4,ty=15,cr=127: 1.0
    2014-05-04 17:28:03	MySensors Debug	Receiving command 0;0;4;11;Ack: receive timeout
    Fulltime Servoy Developer
      Why would you send sketch info from the gateway? To where?
      • marceltrapmanM
        marceltrapmanM
        marceltrapman
        Well, the gateway can also be a sensor if I am correct.
        In which case I would like what sketch version it is.
        Or, when I make changes to the gateway...
        Maybe I did not think the 'bug report' through well enough :(
        Your question makes sense but I want this info in the Controller...
        hekH 1 Reply Last reply
        • marceltrapmanM marceltrapman
          @marceltrapman
          You can get version of the library used by gateway. But that is about it.
          • marceltrapmanM
            marceltrapmanM
            marceltrapman
            Hmm, ok.
