  3. Not all Relais visible in Domoticz
9 Posts 3 Posters 1.9k Views 2 Watching
  • DickD
    DickD
    Dick
    I started a project with 5 relays and 2 binary buttons. In Domotics 3 of the 5 relays pops up including the 2 binary buttons. Why not 5 relays?
    #define MY_REPEATER_FEATURE
    #include <Bounce2.h>
    #define RELAY_1  A0  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 5 // Total number of attached relays
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    #define CHILD_ID_IRBIN 3
    #define CHILD_ID_IRBUI 4
    #define IRBIN_PIN  3  // Arduino Digital I/O pin for button/reed switch
    #define IRBUI_PIN  4
    Bounce debouncerIRBIN = Bounce();
    Bounce debouncerIRBUI = Bounce();
    int oldValue_IRBIN = -1;
    int oldValue_IRBUI = -1;
    MyMessage msgIRBIN(CHILD_ID_IRBIN, V_TRIPPED);
    MyMessage msgIRBUI(CHILD_ID_IRBUI, V_TRIPPED);
    void before()
    		pinMode(pin, OUTPUT);
      // Setup the button1
      pinMode(IRBIN_PIN, INPUT);
      debouncerIRBIN.attach(IRBIN_PIN);
      debouncerIRBIN.interval(5);
      digitalWrite(IRBIN_PIN, HIGH);
      // Setup the button2
      pinMode(IRBUI_PIN, INPUT);
      debouncerIRBUI.attach(IRBUI_PIN);
      debouncerIRBUI.interval(5);
      digitalWrite(IRBUI_PIN, HIGH);
      present(CHILD_ID_IRBIN, S_DOOR);
      present(CHILD_ID_IRBUI, S_DOOR);
    		present(sensor, S_BINARY);
      debouncerIRBIN.update();
      // Get the update value
      int valueIRBIN = debouncerIRBIN.read();
      if (valueIRBIN != oldValue_IRBIN) {
        // Send in the new value
        send(msgIRBIN.set(valueIRBIN == HIGH ? 1 : 0));
        oldValue_IRBIN = valueIRBIN;
      debouncerIRBUI.update();
      int valueIRBUI = debouncerIRBUI.read();
      if (valueIRBUI != oldValue_IRBUI) {
        send(msgIRBUI.set(valueIRBUI == HIGH ? 1 : 0));
        oldValue_IRBUI = valueIRBUI;
    	if (message.type==V_STATUS) {
    		// Change relay state
    		// Store state in eeprom
    		// Write some debug info
    		Serial.print(message.sensor);
    • nagelcN
      nagelcN
      nagelc
      For me, sometimes Domoticz does not show a switch until it gets a value, even though the switch was presented. I add a small routine to Loop() with a flag so it only runs the first time after startup. Then i send the default value for each switch, Usually Off. It is not very elegant, but seems to work.
      If (startup) {
      Send initial value for each switch/relay
      startup=false;
      DickD 1 Reply Last reply
      • nagelcN nagelc
        If (startup) {
        startup=false;
        DickD
        DickD
        Dick
        @nagelc
        Thanks for the reply but I am not that experience. I must add your script to the "LOOP" but doing that I get a message "startup" was not declared in the scope. Can you show me was to declair?
        • DickD Dick
          @nagelc
          @dick add
          static bool startup = true;
          before the If (startup) line.
          You might also need to add delay(100) after each present and send, to avoid stressing the radio and power source too much.
          nagelcN DickD 2 Replies Last reply
            @dick add
            nagelcN
            nagelcN
            nagelc
            @mfalkvidd Exactly. Thanks for clarifying.
              @dick add
              DickD
              DickD
              Dick
              @mfalkvidd I tested the solution and the LOOP code looks like this
              but having an error during compiling ("IF" was not declared in this scope). how can I fix that?
                If (startup) {
              startup=false;
              • DickD Dick
                  If (startup) {
                startup=false;
                @dick if needs to be lowercase. Change "If" to "if".
                  DickD
                  DickD
                  Dick
                  @mfalkvidd thanks for your support and no errors anymore. Unfortunately it did not work forme. probably I split my sensors in to, one with the relais switches and 1 with the binary buttons. I think that is the only way to continue right now.
                  • nagelcN
                    nagelcN
                    nagelc
                    wrote on last edited by nagelc
                    Another thing to try. Try changing the button IDs to 6 and 7.
                    You define the button child IDs as 3 and 4.
                    The relays are presented with child ID's 1 through 5 by the loop in Presentation(). So the buttons have the same child IDs as two of the relays. Some sensors can have the same child ID, like temperature and humidity, but I don't know about S_DOOR and S_BINARY.
                    Also, delete this code i suggested. It needs some tweaking and I suspect the issue is really the overlap of the child IDs:
                    If (startup) {
                    startup=false;
