  3. PIN 12 broken .... Could I use another pin instead?
3 Posts 2 Posters 1.7k Views 2 Watching
    Meister_Petz
    unfortunately some PINs on one of my arduinos are broken - due to beginners soldering. (A0, A6, A7, D12) (after unsoldering for the 5th time, there were some issues). :-(
    So is there maybe a way to use instead of PIN 12 for the radio e.g. PIN 8?
    I already had a look at SoftSPI, but then I would need to use A0 which is broken as well.
    Many Thanks
    Petz
    • AnticimexA
      AnticimexA
      Anticimex
      For soft SPI, there are no constraints. You should be able to pick any pin you want. Just replace the pin assignments in RF24_config.h (assuming you run on the master branch):
        const uint8_t SOFT_SPI_MISO_PIN = 16;
        const uint8_t SOFT_SPI_MOSI_PIN = 15;
        const uint8_t SOFT_SPI_SCK_PIN = 14;
        Meister_Petz
        Worked!
        Many Thanks
