  3. How many servers in the network?
4 Posts 2 Posters 1.2k Views 2 Watching
  • pgvP Offline
    pgvP Offline
    pgv
    Hi
    How many MySensor servers are allowed in the network?
    I have added a server to an existing working installation on a different channel and now it seems nothing is working!!
    Both servers are RPi based and the original one was an ethernet based one and worked fine.
    I have changed both servers to be MQTT and they are based on 2.3 development branch. I've also changed all nodes (there is only 3 of them) to a fixed Node_ID.
    I will post logs etc if someone can indicate whether multiple servers are valid. I thought it would be OK based on the use of a separate RF channel but I think the problem might lie in the routing table and it's interaction with the MQTT server. In other words there are two Node 0's in the network.
    Thoughts anyone.
    Y 1 Reply Last reply
    • pgvP pgv
      Hi
      Thoughts anyone.
      Y Offline
      Y Offline
      @pgv said in How many servers in the network?:
      In MySensors-world there are nodes, gateways and controllers. Nodes and gateways contain MySensors software, controllers are third-party.
      As you are talking about different channels, I assume you built another gateway.
      Make sure all nodes which should be talking to a certain gateway share the same settings with that gateway (channel, base-ID), or they will not be able to communicate.
      As you're using MQTT you should also use separate MQTT base topics for each gateway, or both gateways will write to the same topics.
      • pgvP Offline
        pgvP Offline
        pgv
        Thanks Yveaux
        Yes I definitely built another MySensors gateway...trying to access a back shed with a metal roof...radio just not making it.
        I attempted to create separate mqtt devices in Home Assistant (controller I am using) under the MySensors gateway component but it complains.
        Do you have any suggestions there?
        Thanks again for your help.
        • pgvP Offline
          pgvP Offline
          pgv
          Hi Yveaux
          It's all OK .... just a little YAML format problem with HA. Seems to be OK now.
          Cheers
          12.2k
