  3. Myscontroller not connecting to server
4 Posts 2 Posters 1.1k Views 2 Watching
  • pgvP Offline
    pgvP Offline
    pgv
    Using Myscontroller and it used to work OK but now it never reports messaging. In the debug it always reports:
    27/05/2018 14:24:42 INFO Connected to 192.168.1.9:5003
    27/05/2018 14:24:43 ERROR Error on connect: connection refused
    I have a username and password set on the mosquitto server. Should these be entered to the Myscontroller.ini file? And if so how is it done?
    TIA
      MyScontroller works only for serial and ethernet gateways.
      • pgvP Offline
        pgvP Offline
        pgv
        Thanks.
        Thats a bummer! I had read that somewhere too way back.
        Thank you.
          If you want there is mycontroller that is compatible with mqtt and supporta firmware update
