  3. Low power temperature/humidity node with sonoff si7021
1 Posts 1 Posters 1.6k Views 1 Watching
  • Y Offline
    Y Offline
    yelti_be
    My little project:
    Temperature/humidity sensor with a sonoff si7021.
    You can find the sonoff si7021 sensors quite cheap on aliexpress (about 4,5€/piece).
    Pro's: has sensor and housing
    Con's: needs some tinkering to use it in low power application.
    The build:
    Arduino mini pro 8mhz 3.3v
    Sonoff si7021 sensor
    Lipo 3.7v battery
    nrf24l01+ radio
    I modded the arduino nano clone for low low power.
    First I tried with the one-wire protocol of the sonoff, but no luck in there.
    Next I soldered sda/scl lines directy and the sensor worked, but sleeping current was 1ma and way out of specs for the si7021 + mini pro.
    Next I modded the si7021sonoff si7021
    • I removed the transistor Q1
    • I remove capacitor C4
    • I cut all traces from the mcu
    After this the sleeping current is about 15 uA.
    The sketch sends temperature, humidity, batterylevel and batteryvoltage.
    My code:
    //#define MY_DEBUG
    // #define MY_RF24_PA_LEVEL RF24_PA_LOW
    //#define MY_DEBUG_VERBOSE_RF24
    // RF channel for the sensor net, 0-127
    #define RF24_CHANNEL     125
    //PiHome Node ID
    #define MY_NODE_ID 23
    //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
    #define RF24_DATARATE      RF24_250KBPS
    #include "Adafruit_Si7021.h"
    Adafruit_Si7021 sensor = Adafruit_Si7021();
    // Define sensor node childs
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    #define CHILD_ID_BATT 2
    #define CHILD_ID_BATT_VOLTAGE 3
    #define COMPARE_BVOLT 1 // Send battery voltage only if changed? 1 = Yes 0 = No
    #define         READ_SAMPLE_INTERVAL         (10)    //define how many samples you are going to take in normal operation
    #define         READ_SAMPLE_TIMES            (5)     //define the time interal(in milisecond) between each samples in
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 10000;
    unsigned long SLEEP_TIME = 56000; // Sleep time between reads (in milliseconds)
    // Battery related init
    int BATTERY_SENSE_PIN = A6;  // select the input pin for the battery sense point
    float oldBatteryV = 0;
    #define SKETCH_NAME "Temp_Humid_Bat_Uterum"      // Change to a fancy name you like
    #define SKETCH_VERSION "2.1"                    // Your version
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    //Definition messages
    MyMessage msgBattVolt(CHILD_ID_BATT_VOLTAGE, V_VOLTAGE);
    MyMessage msgBatt(CHILD_ID_BATT, V_VOLTAGE);
    //Variables
    int chk;
    float hum;  //Stores humidity value
    float temp; //Stores temperature value
      if (!sensor.begin()) {
        Serial.println("Did not find Si7021 sensor!");
        while (true);
      // needed for battery soc
          analogReference(INTERNAL1V1);
      #else
          analogReference(INTERNAL);
      delay(2000);
      #ifdef MY_DEBUG
        Serial.println("***Debug Activated***");
        Serial.print("Sleep_Time: ");
        Serial.print((SLEEP_TIME / 1000)/60);
        Serial.println(" min");
      #else
        Serial.println("***Debug Deactivated***");
    void presentation() {
      sendSketchInfo("Temperature Sensor", "1.34");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_BATT, S_POWER);
      present(CHILD_ID_BATT_VOLTAGE, S_MULTIMETER , "Battery ");
      // disable ADC
      // get the battery Voltage
      int battSensorValue = analogRead(BATTERY_SENSE_PIN);
      float batteryV  = battSensorValue * 0.011828;
        // 1M, 100K divider across battery and using internal ADC ref of 1.1V
        // ((1e6+100e3)/100e3)*1.1 = Vmax = 12.1 Volts
        // 12.1/1023 = Volts per bit = 0.011828
      int batteryPcnt = (batteryV / 4.2) * 100;
      #ifdef MY_DEBUG
        Serial.print("Pin Reading: ");
        Serial.println(battSensorValue);
        Serial.print(batteryV);
        Serial.println(" v");
        //Print Battery Percentage
        Serial.print(batteryPcnt);
        Serial.println(" %");
      #if COMPARE_BVOLT == 1
        send(msgBatt.set(batteryV, 2));
        send(msgBattVolt.set(batteryV,2));
      #else
        if (oldBatteryV != batteryV) {
          oldBatteryV = batteryV;
      delay(500);
        //Read data and store it to variables hum and temp
        hum = sensor.readHumidity();
        temp= sensor.readTemperature();
        #ifdef MY_DEBUG
        //Print temp and humidity values to serial monitor
        Serial.print("Humidity: ");
        Serial.print(hum);
        Serial.print(" %, Temp: ");
        Serial.print(temp);
        Serial.println(" Celsius");
      if (isnan(temp)) {
      } else if (temp != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS) {
        lastTemp = temp;
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        temp += SENSOR_TEMP_OFFSET;
        send(msgTemp.set(temp, 1));
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temp);
      } else {
        nNoUpdatesTemp++;
      if (isnan(hum)) {
      } else if (hum != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) {
        lastHum = hum;
        nNoUpdatesHum = 0;
        send(msgHum.set(hum, 1));
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(hum);
      } else {
        nNoUpdatesHum++;
      sleep(SLEEP_TIME);
    My inspirations:
    • low power arduino
    • pi home battery ds18b20 sensor
    • many others :relaxed:
