  3. [SOLVED] 2.2.0 node - sleep() problem
11 Posts 3 Posters 2.3k Views 2 Watching
  • N Offline
    N Offline
    nucutza
    Hi, I need some help. I made a DHT22 node with pro mini and rfm69hw radio.
    It works well but it drain too much current when it supposed to sleep, about 4ma !
    (and some 17ma spikes when radio is active)
    I tested the mini with the old low power library and a blink sketch and I get 4ua in sleep mode !
    What could be wrong ?
    • B Offline
      B Offline
      bjacobse
      wrote on last edited by bjacobse
      DHT22 is a notorious hungry for current, don't use with a battery, replace it with a similar device like Si7021 or SHT21.
      Or alternative use a MOSFET to switch off the power supply to DHT22 meanwhile your CPU is asleep
      • N Offline
        N Offline
        nucutza
        But datasheet for dht22 says : 1.5ma when measuring and 50ua in standby.
        B 1 Reply Last reply
        • N Offline
          N Offline
          nucutza
          This is my sketch. Can anybody test it please ?
          #include <DHT.h>
          #define MY_RADIO_RFM69
          #define MY_RFM69_NEW_DRIVER
          #define MY_RFM69_FREQUENCY RFM69_433MHZ
          #define MY_IS_RFM69HW
          #define MY_NODE_ID 1
          #define CHILD_ID_TEMP 7
          #define CHILD_ID_HUM 8
          #define DHT_DATA_PIN 3
          #define SENSOR_TEMP_OFFSET 0
          /****************** CONSTANTS *********************/
          static const uint64_t UPDATE_INTERVAL = 10000;
          /****************** VARIABLES *********************/
          float lastTemp;
          float lastHum;
          float temperature;
          float humidity;
          uint8_t nNoUpdatesTemp;
          uint8_t nNoUpdatesHum;
          /****************** MESSAGES **********************/
          DHT dht;
          present(CHILD_ID_HUM, S_HUM);
          delay(2000); //Wait 2 seconds before starting sequence
          if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod())
          dht.setup(DHT_DATA_PIN);
          sendTemperatureHumiditySensor();
          Serial.println("Sleep for 10s !");
          sleep(UPDATE_INTERVAL);
          /**************** AUX. FUNCTIONS ******************/
          void sendTemperatureHumiditySensor()
          dht.readSensor(true);
          temperature = dht.getTemperature();
          humidity = dht.getHumidity();
          if (isnan(temperature))
          } else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS)
          lastTemp = temperature;
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          Serial.print("T: ");
          Serial.println(temperature);
          } else
          nNoUpdatesTemp++;
          if (isnan(humidity))
          } else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS)
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
          } else
          nNoUpdatesHum++;
          • N Offline
            N Offline
            nucutza
            And this is what I get from debug terminal. However 4ma in sleep !
            Sleep for 10s !
            8540 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
            8546 TSF:TDI:TSL
            8548 MCO:SLP:WUP=-1
            8550 TSF:TRI:TSB
            8570 TSF:MSG:SEND,1-1-0-0,s=8,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:59.3
            H: 59.30
            Sleep for 10s !
            8579 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
            8585 TSF:TDI:TSL
            8587 MCO:SLP:WUP=-1
            8589 TSF:TRI:TSB
            8609 TSF:MSG:SEND,1-1-0-0,s=7,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.0
            T: 24.00
            8634 TSF:MSG:SEND,1-1-0-0,s=8,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:59.1
            H: 59.10
            Sleep for 10s !
            8642 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
            8648 TSF:TDI:TSL
            • N Offline
              N Offline
              nucutza
              My gateway is raspberry pi mqtt.
              • S Offline
                The best way to debug this is to remove the sensor and see what kind of mA you get. If it's still a high reading I would replace the radio.
                • N nucutza
                  B Offline
                  B Offline
                  bjacobse
                  @nucutza
                  True spec looks a kind of decent for DHT22 (bur only for main operated power supply), but voltage minimum is not good enough. So that means when your battery is half empty your DHT22 isn't working anymore, using si7021 or SHT21 can go much lower, so that you can use more of your battery, as they go low to 1,9V or 1,5V
                  DHT22:
                  si7021:
                  SHT21:
                  • S sundberg84
                    B Offline
                    B Offline
                    bjacobse
                    @sundberg84 said in 2.2.0 node - sleep() problem:
                    Sundbergs approach is the right one, and if non of those are working, replace your Arduino
                    did you remove the LDO voltage converter on your Arduino Pro Mini? This will use current
                    clones are not 100% identical, so your clone could have the LDO positioned somewhere else:
                    https://andreasrohner.at/posts/Electronics/How-to-modify-an-Arduino-Pro-Mini-clone-for-low-power-consumption/
                    • N Offline
                      N Offline
                      nucutza
                      wrote on last edited by nucutza
                      Yes I did remove the LDO on the arduino and the power led.
                      But finally I found the problem ! On my prototype sensor board there was another voltage converter (5 to 3.3V) because I wanted to use the node with an one cell 18650 power bank with 5V output. Even I fed directly the arduino with an external 3.3v power source the output of this LDO remained connected and guess what ? It drained around 4-5ma ! So I desoldered it and now it's ok ! I get around 15-20ua in sleep mode with the dht22.
                      • B Offline
                        B Offline
                        bjacobse
                        Great that you solved your problem, I still recommend to replace DHT22 to a a better sensor that uses less current consumption and also is working with a lower voltage. This will save plenty of money else spend on replacing batteries too often
