  3. FOTA wont work, Controller error NACK
20 Posts 3 Posters 3.2k Views 3 Watching
  • H
    H
    Harrdy
    wrote on last edited by Harrdy
    I've got a little problem here. Actually, everything works great. My nodes transfer their data every x minutes and everything is displayed in the controller (MyController).
    Now I've been trying to get FOTA running for two days.. I burned the mysbootloader to the Arduini Min Pro. The sketch is compiled and stored in MyController. When I now start a node, I get the following errors in the controller log
    	Aug 13, 2018 20:34:48	Notice	Node	 Serial   0	Received	Intern	[Log message] 669742 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    	Aug 13, 2018 20:34:48	Notice	Node	 Serial   0	Received	Intern	[Log message] 669698 TSF:MSG:GWL OK
    	Aug 13, 2018 20:34:48	Notice	Node	 Serial   0	Received	Intern	[Log message] 669694 TSF:CKU:OK,FCTRL
    	Aug 13, 2018 20:34:48	Notice	Node	 Serial   0	Received	Intern	[Log message] 669690 TSF:MSG:FPAR REQ,ID=6
    	Aug 13, 2018 20:34:48	Notice	Node	 Serial   0	Received	Intern	[Log message] 669688 TSF:MSG:BC
    	Aug 13, 2018 20:34:48	Notice	Node	 Serial   0	Received	Intern	[Log message] 669682 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    	Aug 13, 2018 20:34:46	Notice	Node	 Serial   0	Received	Intern	[Log message] 667683 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    	Aug 13, 2018 20:34:46	Notice	Node	 Serial   0	Received	Intern	[Log message] 667644 TSF:MSG:GWL OK
    	Aug 13, 2018 20:34:46	Notice	Node	 Serial   0	Received	Intern	[Log message] 667641 TSF:CKU:OK,FCTRL
    	Aug 13, 2018 20:34:46	Notice	Node	 Serial   0	Received	Intern	[Log message] 667637 TSF:MSG:FPAR REQ,ID=6
    	Aug 13, 2018 20:34:46	Notice	Node	 Serial   0	Received	Intern	[Log message] 667635 TSF:MSG:BC
    	Aug 13, 2018 20:34:46	Notice	Node	 Serial   0	Received	Intern	[Log message] 667629 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    	Aug 13, 2018 20:34:45	Notice	Node	 Serial   0	Received	Intern	[Log message] 666646 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    	Aug 13, 2018 20:34:44	Notice	Node	 Serial   0	Received	Intern	[Log message] 665590 TSF:MSG:GWL OK
    	Aug 13, 2018 20:34:44	Notice	Node	 Serial   0	Received	Intern	[Log message] 665587 TSF:CKU:OK,FCTRL
    	Aug 13, 2018 20:34:44	Notice	Node	 Serial   0	Received	Intern	[Log message] 665583 TSF:MSG:FPAR REQ,ID=6
    	Aug 13, 2018 20:34:44	Notice	Node	 Serial   0	Received	Intern	[Log message] 665580 TSF:MSG:BC
    	Aug 13, 2018 20:34:44	Notice	Node	 Serial   0	Received	Intern	[Log message] 665574 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    	Aug 13, 2018 20:34:43	Notice	Node	 Serial   0	Received	Intern	[Log message] 664594 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    	Aug 13, 2018 20:34:42	Notice	Node	 Serial   0	Received	Intern	[Log message] 663540 TSF:MSG:GWL OK
    	Aug 13, 2018 20:34:42	Notice	Node	 Serial   0	Received	Intern	[Log message] 663537 TSF:CKU:OK
    	Aug 13, 2018 20:34:42	Notice	Node	 Serial   0	Received	Intern	[Log message] 663534 TSF:PNG:SEND,TO=0
    	Aug 13, 2018 20:34:42	Notice	Node	 Serial   0	Received	Intern	[Log message] 663530 TSF:MSG:FPAR REQ,ID=6
    	Aug 13, 2018 20:34:42	Notice	Node	 Serial   0	Received	Intern	[Log message] 663527 TSF:MSG:BC
    	Aug 13, 2018 20:34:42	Notice	Node	 Serial   0	Received	Intern	[Log message] 663521 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    	Aug 13, 2018 20:34:38	Notice	Node	 Serial   0	Received	Intern	[Log message] 660078 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
    	Aug 13, 2018 20:34:38	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
    	Aug 13, 2018 20:34:38	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] 0A000300D80476B30103
    	Aug 13, 2018 20:34:38	Notice	Node	 Serial   0	Received	Intern	[Log message] 660019 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:0A000300D80476B30103
    	Aug 13, 2018 20:34:35	Notice	Node	 Serial   0	Received	Intern	[Log message] 656988 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
    	Aug 13, 2018 20:34:35	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
    	Aug 13, 2018 20:34:35	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] 0A000300D80476B30103
    	Aug 13, 2018 20:34:35	Notice	Node	 Serial   0	Received	Intern	[Log message] 656928 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:0A000300D80476B30103
    	Aug 13, 2018 20:34:32	Notice	Node	 Serial   0	Received	Intern	[Log message] 653900 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
    	Aug 13, 2018 20:34:32	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
    	Aug 13, 2018 20:34:32	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] 0A000300D80476B30103
    	Aug 13, 2018 20:34:32	Notice	Node	 Serial   0	Received	Intern	[Log message] 653842 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:0A000300D80476B30103
    	Aug 13, 2018 20:34:32	Notice	Node	 Serial   0	Received	Intern	[Log message] 653277 TSF:MSG:READ,2-2-0,s=40,c=1,t=16,pt=0,l=1,sg=0:0
    	Aug 13, 2018 20:34:29	Notice	Node	 Serial   0	Received	Intern	[Log message] 650813 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
    Sometimes nothing happens and the client comes a short time later with its old sketch online, but sometimes the client is overwritten and I have to transfer the sketch to the node again via IDE.
    I have also tried different NRF24l01+ and NRF24l01+pa+lna. I support VCC/GND of the NRF24l01+ with a 47uF capacitor. The nodes are based on the Newbie PCB with 3.3V booster and 2xAA
    During the start of the node and the fota process the red led of the gateway flashes.
    I'm running out of ideas. Anybody have any other ideas? Does anyone have a Nano Gateway shield that you can order via osh or similar
      Do you see any errors on the node serial debug output?
      • H
        H
        Harrdy
        On my "normal sketch", the node output is clean. Sometimes the node has to send a sensor value again because there is an error message nack at the node, but this is relatively rare.
        I try the pingping sketch to check the reply from gateway. In this situation i got a nack error @ node. No reply from gateway
         *  This is a simple sketch used to demonstrate and test node-to-node MySensors communication.
         *  To use this sketch, assemble MySensors nodes - they need nothing more than a radio
         *  1.  Flash each node with the same sketch, open the console and type either 0 or 1 to the respective nodes to set their ID
         *  2.  You only need to set the node id once, and restart the nodes
         *  3.  To being a ping-pong test, simply type T in the console for one of the nodes.
         *  2015-05-25 Bruce Lacey v1.0
        //#define MY_RADIO_NRF5_ESB
        //#define MY_RADIO_RFM95
        #include "MYSLog.h"
        #define VSN "v1.0"
        // Define two generic nodes with a single child
        #define YING 200
        #define YANG 201
        #define CHILD 1
        MyMessage mPing(CHILD, V_VAR1);   //Ping message
        MyMessage mPong(CHILD, V_VAR2);   //Pong message
        	present(CHILD, S_CUSTOM);  //
        	sendSketchInfo( nodeTypeAsCharRepresentation( getNodeId() ), VSN );
        	LOG(F("\n%sReady.\n"), nodeTypeAsCharRepresentation(getNodeId()));
        	// Interactive command and control
        	// Entering a number from 0 or 1 will write the node 200 (YING) or 201 (YANG) to EEPROM
        	// Entering T on either node will initiate a ping-pong test.
        	if (Serial.available()) {
        		byte inChar = Serial.read();
        		uint8_t node = getNodeId();
        		// Manual Test Mode
        		if (inChar == 'T' || inChar == 't') {
        			LOG(F("T received - starting test...\n"));
        			MyMessage msg = mPong;
        			msg.sender = (node == YING ? YANG : YING);
        			sendPingOrPongResponse( msg );
        		} else if (inChar == '0' or inChar == '1') {
        			byte nodeID = 200 + (inChar - '0');
        			setNodeId(nodeID);
        		} else {
        			LOG("Invalid input\n");
        	LOG(F("Received %s from %s\n"), msgTypeAsCharRepresentation((mysensor_data)message.type),
        	    nodeTypeAsCharRepresentation(message.sender));
        	delay(250);
        	sendPingOrPongResponse( message );
        void sendPingOrPongResponse( MyMessage msg )
        	MyMessage response = (msg.type == V_VAR1 ? mPong : mPing);
        	LOG(F("Sending %s to %s\n"), msgTypeAsCharRepresentation( (mysensor_data)response.type ),
        	    nodeTypeAsCharRepresentation(msg.sender));
        	// Set payload to current time in millis to ensure each message is unique
        	response.set( (uint32_t)millis() );
        	response.setDestination(msg.sender);
        	send(response);
        void setNodeId(byte nodeID)
        	LOG(F("Setting node id to: %i.\n***Please restart the node for changes to take effect.\n"), nodeID);
        	hwWriteConfig(EEPROM_NODE_ID_ADDRESS, (byte)nodeID);
        const char * msgTypeAsCharRepresentation( mysensor_data mType )
        	return mType == V_VAR1 ? "Ping" : "Pong";
        const char * nodeTypeAsCharRepresentation( uint8_t node )
        	return node == YING ? "Ying Node" : "Yang Node";
        I also try this.
         requestTime(receiveTime);
        void receiveTime(unsigned long time) {
          Serial.println(time);
        And here? the node prints the controller time. Without any error.
          No, I meant looking at the serial debug while it is doing the fota
          • H
            H
            Harrdy
            How can i do this? I have the ttl reader on the arduino during the start. but the console is empty. Only after the fota process is finished, i see the output of the mysensors sketches. While the gateway is flashing red, the console remains empty. It takes about 10-15 seconds
            tekkaT 1 Reply Last reply
              I think there is a define to enable it, but I don't remember well as I use the dual optiboot. Maybe @tekka could help
              • H Harrdy
                tekkaT
                tekkaT
                tekka
                @harrdy MYSBootloader does not have a serial console output. In order to get a better understanding of your setup: can you post the full debug logs (GW & node) starting from the node booting until sending sensor data + node sketch?
                • H
                  H
                  Harrdy
                  Re: [FOTA wont work](Controller error NACK)
                  @tekka
                  node log during start until send sensor data
                   __  __       ____
                          |___/                      2.3.0
                  16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
                  26 MCO:BGN:BFR
                  28 TSM:INIT
                  30 TSF:WUR:MS=0
                  36 TSM:INIT:TSP OK
                  38 TSF:SID:OK,ID=6
                  40 TSM:FPAR
                  77 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2084 !TSM:FPAR:NO REPLY
                  2086 TSM:FPAR
                  2123 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4130 !TSM:FPAR:NO REPLY
                  4132 TSM:FPAR
                  4169 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4188 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  4194 TSF:MSG:FPAR OK,ID=0,D=1
                  6176 TSM:FPAR:OK
                  6176 TSM:ID
                  6178 TSM:ID:OK
                  6180 TSM:UPL
                  6184 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  8192 TSM:UPL
                  8198 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  10207 TSM:UPL
                  10209 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  10901 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                  10907 TSF:MSG:BC
                  11608 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                  12218 TSM:UPL
                  12255 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  12265 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  12271 TSF:MSG:PONG RECV,HP=1
                  12273 TSM:UPL:OK
                  12275 TSM:READY:ID=6,PAR=0,DIS=1
                  12314 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                  14329 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.3.0
                  14372 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  16386 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=1,st=OK:TestBoard BMP180
                  16402 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                  16420 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
                  16429 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                  16435 MCO:REG:REQ
                  16474 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                  18489 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                  20496 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  22507 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  24516 MCO:BGN:STP
                  25018 MCO:BGN:INIT OK,TSP=1
                  Battery Voltage: 3.25 V
                  Battery percent: 96 %
                  25552 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:96
                  Temperature = 24.80 *C
                  Pressure = 1016.96 hPa
                  Forecast = unknown
                  25608 TSF:MSG:SEND,6-6-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.8
                  25620 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1017
                  25630 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
                  25638 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  25645 TSF:TDI:TSL
                  25647 MCO:SLP:WUP=-1
                  25649 TSF:TRI:TSB
                  Battery Voltage: 2.95 V
                  Battery percent: 87 %
                  26189 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=NACK:87
                  Pressure = 1016.87 hPa
                  Forecast = unknown
                  26243 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=1,st=OK:1017
                  26251 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  26257 TSF:TDI:TSL
                  gateway log
                  	Aug 14, 2018 10:57:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 3637381 TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:89
                  	Aug 14, 2018 10:57:44	Notice	Node	 Serial   5:TestBoard BH1750	Received	Internal	[Battery level] 89
                  	Aug 14, 2018 10:57:44	Info	Sensor variable	 Serial   5:TestBoard BH1750   20:45857 TSF:MSG:READ,5-5-0,s=20,c=0,t=16,pt=0,l=0,sg=0:  Light level	Received	Set	[Light level] 199
                  	Aug 14, 2018 10:57:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 3637369 TSF:MSG:READ,5-5-0,s=20,c=1,t=23,pt=3,l=2,sg=0:199
                  	Aug 14, 2018 10:57:36	Info	Sensor variable	 Serial   9:TestBoard BMP180   1:1939766 TSF:MSG:READ,9-9-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                  	Aug 14, 2018 10:57:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3629883 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                  	Aug 14, 2018 10:57:21	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
                  	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614796 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
                  	Aug 14, 2018 10:57:21	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                  	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614785 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                  	Aug 14, 2018 10:57:21	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.8
                  	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614773 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.8
                  	Aug 14, 2018 10:57:21	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 96
                  	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614691 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
                  	Aug 14, 2018 10:57:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 3611703 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 10:57:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 3611661 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 10:57:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 3609686 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 10:57:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 3609644 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 10:57:14	Notice	Node	 Serial   0	Received	Internal	[Log message] 3607665 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 10:57:14	Notice	Node	 Serial   0	Received	Internal	[Log message] 3607623 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605614 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605572 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 10:57:12	Notice	Sensor	 Serial   6:TestBoard BMP180   0:3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                  	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                  	Aug 14, 2018 10:57:12	Notice	Sensor	 Serial   6:TestBoard BMP180   1:3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                  	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                  	Aug 14, 2018 10:57:12	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
                  	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605530 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                  	Aug 14, 2018 10:57:12	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
                  	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605516 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
                  	Aug 14, 2018 10:57:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 3603517 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                  	Aug 14, 2018 10:57:10	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
                  	Aug 14, 2018 10:57:10	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
                  	Aug 14, 2018 10:57:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 3603466 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  	Aug 14, 2018 10:57:10	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
                  	Aug 14, 2018 10:57:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 3603451 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                  	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601444 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                  	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601401 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601386 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601347 TSF:MSG:PINGED,ID=6,HP=1
                  	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601341 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  	Aug 14, 2018 10:57:07	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Discover response] 0
                  	Aug 14, 2018 10:57:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600699 TSF:MSG:READ,6-6-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                  	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600049 TSF:SAN:OK
                  	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600040 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600003 TSM:READY:NWD REQ
                  	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599915 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                  	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599904 TSF:MSG:READ,7-7-0,s=0,c=1,t=0,pt=7,l=5,sg=0:23.0
                  	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599368 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599328 TSF:MSG:PINGED,ID=6,HP=1
                  	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599322 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  	Aug 14, 2018 10:57:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 3597344 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 10:57:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 3597305 TSF:MSG:PINGED,ID=6,HP=1
                  	Aug 14, 2018 10:57:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 3597299 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  	Aug 14, 2018 10:57:02	Notice	Node	 Serial   0	Received	Internal	[Log message] 3595327 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 10:57:02	Notice	Node	 Serial   0	Received	Internal	[Log message] 3595287 TSF:MSG:PINGED,ID=6,HP=1
                  	Aug 14, 2018 10:57:02	Notice	Node	 Serial   0	Received	Internal	[Log message] 3595281 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593279 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593241 TSF:MSG:GWL OK
                  	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593238 TSF:CKU:OK,FCTRL
                  	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593234 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593231 TSF:MSG:BC
                  	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593225 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  	Aug 14, 2018 10:56:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591251 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591188 TSF:MSG:GWL OK
                  	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591185 TSF:CKU:OK,FCTRL
                  	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591181 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591178 TSF:MSG:BC
                  	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591172 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  	Aug 14, 2018 10:56:56	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589200 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589139 TSF:MSG:GWL OK
                  	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589136 TSF:CKU:OK
                  	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589133 TSF:PNG:SEND,TO=0
                  	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589129 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589126 TSF:MSG:BC
                  	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589120 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  	Aug 14, 2018 10:56:52	Notice	Node	 Serial   0	Received	Internal	[Log message] 3585674 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                  	Aug 14, 2018 10:56:52	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                  	Aug 14, 2018 10:56:52	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                  	Aug 14, 2018 10:56:52	Notice	Node	 Serial   0	Received	Internal	[Log message] 3585614 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                  	Aug 14, 2018 10:56:49	Notice	Node	 Serial   0	Received	Internal	[Log message] 3582587 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                  	Aug 14, 2018 10:56:49	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                  	Aug 14, 2018 10:56:49	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                  	Aug 14, 2018 10:56:49	Notice	Node	 Serial   0	Received	Internal	[Log message] 3582528 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                  	Aug 14, 2018 10:56:46	Notice	Node	 Serial   0	Received	Internal	[Log message] 3579492 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                  	Aug 14, 2018 10:56:46	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                  	Aug 14, 2018 10:56:46	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                  	Aug 14, 2018 10:56:46	Notice	Node	 Serial   0	Received	Internal	[Log message] 3579432 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                  	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576639 TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:91
                  	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576627 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:60.8
                  	Aug 14, 2018 10:56:43	Info	Sensor variable	 Serial   1:TemperatureAndHumidity   1:405720740 TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 22.8
                  	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576616 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:22.8
                  	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576399 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                  	Aug 14, 2018 10:56:43	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                  	Aug 14, 2018 10:56:43	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                  	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576339 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                  	Aug 14, 2018 10:56:39	Notice	Node	 Serial   0	Received	Internal	[Log message] 3572920 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                  	Aug 14, 2018 10:56:39	Notice	Node	 Serial   0	Received	Internal	[Log message] 3572877 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569977 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569800 TSF:MSG:GWL OK
                  	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569796 TSF:CKU:OK,FCTRL
                  	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569792 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569789 TSF:MSG:BC
                  	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569782 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                  	Aug 14, 2018 10:56:34	Notice	Node	 Serial   0	Received	Internal	[Log message] 3567338 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                  	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566862 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566706 TSF:MSG:GWL OK
                  	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566703 TSF:CKU:OK
                  	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566700 TSF:PNG:SEND,TO=0
                  	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566696 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566693 TSF:MSG:BC
                  	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566687 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                  its my ota file, the same thing that is already on the arduino. i only change the sketch name.
                  node sketch was too long, i use github to host it
                  https://github.com/Harrdy/MySensors-TestBoard/blob/master/MySensors-TestBoard.ino
                  currently used gateway
                  3.3v directly from arduino with 47uF cap
                  currently used node
                  • H Harrdy
                    @tekka
                     __  __       ____
                            |___/                      2.3.0
                    26 MCO:BGN:BFR
                    28 TSM:INIT
                    30 TSF:WUR:MS=0
                    36 TSM:INIT:TSP OK
                    38 TSF:SID:OK,ID=6
                    40 TSM:FPAR
                    2086 TSM:FPAR
                    4132 TSM:FPAR
                    6176 TSM:FPAR:OK
                    6176 TSM:ID
                    6178 TSM:ID:OK
                    6180 TSM:UPL
                    8192 TSM:UPL
                    10207 TSM:UPL
                    10907 TSF:MSG:BC
                    12218 TSM:UPL
                    12273 TSM:UPL:OK
                    16435 MCO:REG:REQ
                    24516 MCO:BGN:STP
                    Forecast = unknown
                    25645 TSF:TDI:TSL
                    25649 TSF:TRI:TSB
                    Forecast = unknown
                    26257 TSF:TDI:TSL
                    gateway log
                    currently used node
                    tekkaT
                    tekkaT
                    tekka
                    @harrdy Node RF24: There are lots of failed transmissions during startup which normally hints to a power issue (bad capacitor?), a defective radio or a signal interference. Can you exchange both components and give it another spin?
                    • H
                      H
                      Harrdy
                      @tekka said in FOTA wont work, Controller error NACK:
                      I change both the cap against a new one (old 4,7uF 50v, new 10uF 16v) and change ne nrf against a brand new one
                      first node startup
                       __  __       ____
                              |___/                      2.3.0
                      26 MCO:BGN:BFR
                      28 TSM:INIT
                      30 TSF:WUR:MS=0
                      36 TSM:INIT:TSP OK
                      38 TSF:SID:OK,ID=6
                      40 TSM:FPAR
                      2086 TSM:FPAR
                      4132 TSM:FPAR
                      6176 TSM:FPAR:OK
                      6176 TSM:ID
                      6178 TSM:ID:OK
                      6180 TSM:UPL
                      8192 TSM:UPL
                      10207 TSM:UPL
                      10907 TSF:MSG:BC
                      12218 TSM:UPL
                      12273 TSM:UPL:OK
                      16435 MCO:REG:REQ
                      24516 MCO:BGN:STP
                      Forecast = unknown
                      25645 TSF:TDI:TSL
                      second node startup
                       __  __       ____
                              |___/                      2.3.0
                      26 MCO:BGN:BFR
                      28 TSM:INIT
                      30 TSF:WUR:MS=0
                      36 TSM:INIT:TSP OK
                      38 TSF:SID:OK,ID=6
                      40 TSM:FPAR
                      2086 TSM:FPAR
                      4132 TSM:FPAR
                      6176 !TSM:FPAR:NO REPLY
                      6178 TSM:FPAR
                      6215 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      8222 !TSM:FPAR:FAIL
                      8224 TSM:FAIL:CNT=1
                      8226 TSM:FAIL:DIS
                      8228 TSF:TDI:TSL
                      18229 TSM:FAIL:RE-INIT
                      18231 TSM:INIT
                      18237 TSM:INIT:TSP OK
                      18241 TSF:SID:OK,ID=6
                      18243 TSM:FPAR
                      18280 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      20289 !TSM:FPAR:NO REPLY
                      20291 TSM:FPAR
                      20328 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      22337 !TSM:FPAR:NO REPLY
                      22339 TSM:FPAR
                      22376 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      24385 !TSM:FPAR:NO REPLY
                      24387 TSM:FPAR
                      24424 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      26433 !TSM:FPAR:FAIL
                      26435 TSM:FAIL:CNT=2
                      26437 TSM:FAIL:DIS
                      26439 TSF:TDI:TSL
                      36442 TSM:FAIL:RE-INIT
                      36444 TSM:INIT
                      36450 TSM:INIT:TSP OK
                      36454 TSF:SID:OK,ID=6
                      36456 TSM:FPAR
                      36493 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      38502 !TSM:FPAR:NO REPLY
                      38504 TSM:FPAR
                      38541 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      40550 !TSM:FPAR:NO REPLY
                      40552 TSM:FPAR
                      40589 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      40929 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      40935 TSF:MSG:FPAR OK,ID=0,D=1
                      42598 TSM:FPAR:OK
                      42600 TSM:ID
                      42600 TSM:ID:OK
                      42602 TSM:UPL
                      42606 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      42622 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      42629 TSF:MSG:PONG RECV,HP=1
                      42631 TSM:UPL:OK
                      42633 TSM:READY:ID=6,PAR=0,DIS=1
                      42643 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      44660 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
                      44679 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      44709 TSF:MSG:READ,0-0-6,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      44752 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=0,st=OK:TestBoard BMP180
                      44763 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                      44785 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
                      44795 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                      44802 MCO:REG:REQ
                      44838 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                      46848 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                      46882 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      46888 MCO:PIM:NODE REG=1
                      46891 MCO:BGN:STP
                      47392 MCO:BGN:INIT OK,TSP=1
                      47908 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:96
                      Temperature = 25.00 *C
                      Pressure = 1017.10 hPa
                      Forecast = unknown
                      47964 TSF:MSG:SEND,6-6-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.0
                      47982 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1017
                      47994 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
                      48003 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      48009 TSF:TDI:TSL
                      48011 MCO:SLP:WUP=-1
                      48013 TSF:TRI:TSB
                      48523 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:87
                      Pressure = 1017.06 hPa
                      1. node startup
                       __  __       ____
                              |___/                      2.3.0
                      26 MCO:BGN:BFR
                      28 TSM:INIT
                      30 TSF:WUR:MS=0
                      36 TSM:INIT:TSP OK
                      38 TSF:SID:OK,ID=6
                      40 TSM:FPAR
                      288 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      294 TSF:MSG:FPAR OK,ID=0,D=1
                      2084 TSM:FPAR:OK
                      2084 TSM:ID
                      2086 TSM:ID:OK
                      2088 TSM:UPL
                      2093 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      2123 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2129 TSF:MSG:PONG RECV,HP=1
                      2131 TSM:UPL:OK
                      2134 TSM:READY:ID=6,PAR=0,DIS=1
                      2138 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      4155 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
                      4165 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      6150 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                      6156 TSF:MSG:BC
                      6176 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                      6189 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=0,st=OK:TestBoard BMP180
                      6234 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                      6256 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
                      6264 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                      6270 MCO:REG:REQ
                      6275 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      8318 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                      10328 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                      10350 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      10356 MCO:PIM:NODE REG=1
                      10360 MCO:BGN:STP
                      10862 MCO:BGN:INIT OK,TSP=1
                      Battery Voltage: 3.34 V
                      Battery percent: 99 %
                      11368 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:99
                      Temperature = 24.90 *C
                      Forecast = unknown
                      11423 TSF:MSG:SEND,6-6-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.9
                      11431 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1017
                      11444 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
                      11452 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      11458 TSF:TDI:TSL
                      11460 MCO:SLP:WUP=-1
                      11462 TSF:TRI:TSB
                      gateway during 3. startup
                      Aug 14, 2018 12:17:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 8415023 TSF:MSG:READ,7-7-0,s=0,c=1,t=0,pt=7,l=5,sg=0:23.1
                      	Aug 14, 2018 12:17:18	Notice	Node	 Serial   7:TestBoard BMP180	Received	Internal	[Battery level] 96
                      	Aug 14, 2018 12:17:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 8414968 TSF:MSG:READ,7-7-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
                      	Aug 14, 2018 12:17:11	Notice	Node	 Serial   1:TemperatureAndHumidity	Received	Internal	[Battery level] 91
                      	Aug 14, 2018 12:17:11	Notice	Node	 Serial   0	Received	Internal	[Log message] 8408024 TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:91
                      	Aug 14, 2018 12:17:11	Info	Sensor variable	 Serial   1:TemperatureAndHumidity   0:405720731 TSF:MSG:READ,1-1-0,s=0,c=0,t=7,pt=0,l=0,sg=0:  Humidity	Received	Set	[Humidity] 58.7
                      	Aug 14, 2018 12:17:11	Notice	Node	 Serial   0	Received	Internal	[Log message] 8408009 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:58.7
                      	Aug 14, 2018 12:17:11	Info	Sensor variable	 Serial   1:TemperatureAndHumidity   1:405720740 TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 23.5
                      	Aug 14, 2018 12:17:11	Notice	Node	 Serial   0	Received	Internal	[Log message] 8407990 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.5
                      	Aug 14, 2018 12:17:09	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
                      	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405341 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
                      	Aug 14, 2018 12:17:09	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                      	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405331 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                      	Aug 14, 2018 12:17:09	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.9
                      	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405321 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.9
                      	Aug 14, 2018 12:17:09	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 99
                      	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405268 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99
                      	Aug 14, 2018 12:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 8404247 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                      	Aug 14, 2018 12:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 8404224 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402214 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402172 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 12:17:06	Notice	Node	 Serial   4:TestBoard DS18B20	Received	Internal	[Battery level] 87
                      	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402153 TSF:MSG:READ,4-4-0,s=255,c=3,t=0,pt=1,l=1,sg=0:87
                      	Aug 14, 2018 12:17:06	Info	Sensor variable	 Serial   4:TestBoard DS18B20   4:2254193 TSF:MSG:READ,4-4-0,s=4,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 21.7
                      	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402139 TSF:MSG:READ,4-4-0,s=4,c=1,t=0,pt=7,l=5,sg=0:21.7
                      	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400197 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400155 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 12:17:04	Notice	Sensor	 Serial   6:TestBoard BMP180   0:8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                      	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                      	Aug 14, 2018 12:17:04	Notice	Sensor	 Serial   6:TestBoard BMP180   1:8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                      	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                      	Aug 14, 2018 12:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
                      	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400079 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                      	Aug 14, 2018 12:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
                      	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400066 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
                      	Aug 14, 2018 12:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Discover response] 0
                      	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400054 TSF:MSG:READ,6-6-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                      	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400045 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400007 TSM:READY:NWD REQ
                      	Aug 14, 2018 12:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 8398089 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                      	Aug 14, 2018 12:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
                      	Aug 14, 2018 12:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
                      	Aug 14, 2018 12:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 8398036 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      	Aug 14, 2018 12:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
                      	Aug 14, 2018 12:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 8398020 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                      	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8396046 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                      	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8396004 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8395988 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                      	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8395963 TSF:MSG:PINGED,ID=6,HP=1
                      	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8395957 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      	Aug 14, 2018 12:16:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 8394148 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393918 TSF:MSG:GWL OK
                      	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393915 TSF:CKU:OK,FCTRL
                      	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393911 TSF:MSG:FPAR REQ,ID=6
                      	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393908 TSF:MSG:BC
                      	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393902 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      	Aug 14, 2018 12:16:52	Notice	Node	 Serial   0	Received	Internal	[Log message] 8388131 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387324 TSF:MSG:GWL OK
                      	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387321 TSF:CKU:OK
                      	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387317 TSF:PNG:SEND,TO=0
                      	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387314 TSF:MSG:FPAR REQ,ID=6
                      	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387311 TSF:MSG:BC
                      	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387305 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                      i'm not sure, is this a node or a gateway issue? i test many times with the node id 6, but all other nodes have the same error at fota. but i use the same components on all nodes, newbie pcb, 4,7uF cap, nrf24l01+, 3.3v booster and 2xAA
                      and sometimes, randomly, 1-2 per hour, the gateway flashs red without fota process.
                      i already try to change the gateway nrf24l01 pa against a normal one. i think, the red flashes were less. But fota did not work either. But with a normal nrf24l01 i have not received any data from far away nodes
                      YouTube - Gateway flashes
                      • H Harrdy
                        first node startup
                         __  __       ____
                                |___/                      2.3.0
                        26 MCO:BGN:BFR
                        28 TSM:INIT
                        30 TSF:WUR:MS=0
                        36 TSM:INIT:TSP OK
                        38 TSF:SID:OK,ID=6
                        40 TSM:FPAR
                        2086 TSM:FPAR
                        4132 TSM:FPAR
                        6176 TSM:FPAR:OK
                        6176 TSM:ID
                        6178 TSM:ID:OK
                        6180 TSM:UPL
                        8192 TSM:UPL
                        10207 TSM:UPL
                        10907 TSF:MSG:BC
                        12218 TSM:UPL
                        12273 TSM:UPL:OK
                        16435 MCO:REG:REQ
                        24516 MCO:BGN:STP
                        Forecast = unknown
                        25645 TSF:TDI:TSL
                        second node startup
                         __  __       ____
                                |___/                      2.3.0
                        26 MCO:BGN:BFR
                        28 TSM:INIT
                        30 TSF:WUR:MS=0
                        36 TSM:INIT:TSP OK
                        38 TSF:SID:OK,ID=6
                        40 TSM:FPAR
                        2086 TSM:FPAR
                        4132 TSM:FPAR
                        6178 TSM:FPAR
                        8222 !TSM:FPAR:FAIL
                        8224 TSM:FAIL:CNT=1
                        8226 TSM:FAIL:DIS
                        8228 TSF:TDI:TSL
                        18231 TSM:INIT
                        18243 TSM:FPAR
                        20291 TSM:FPAR
                        22339 TSM:FPAR
                        24387 TSM:FPAR
                        26437 TSM:FAIL:DIS
                        26439 TSF:TDI:TSL
                        36444 TSM:INIT
                        36456 TSM:FPAR
                        38504 TSM:FPAR
                        40552 TSM:FPAR
                        42598 TSM:FPAR:OK
                        42600 TSM:ID
                        42600 TSM:ID:OK
                        42602 TSM:UPL
                        42631 TSM:UPL:OK
                        44802 MCO:REG:REQ
                        46891 MCO:BGN:STP
                        Forecast = unknown
                        48009 TSF:TDI:TSL
                        48013 TSF:TRI:TSB
                        1. node startup
                         __  __       ____
                                |___/                      2.3.0
                        26 MCO:BGN:BFR
                        28 TSM:INIT
                        30 TSF:WUR:MS=0
                        36 TSM:INIT:TSP OK
                        38 TSF:SID:OK,ID=6
                        40 TSM:FPAR
                        2084 TSM:FPAR:OK
                        2084 TSM:ID
                        2086 TSM:ID:OK
                        2088 TSM:UPL
                        2131 TSM:UPL:OK
                        6156 TSF:MSG:BC
                        6270 MCO:REG:REQ
                        10360 MCO:BGN:STP
                        Forecast = unknown
                        11458 TSF:TDI:TSL
                        11462 TSF:TRI:TSB
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        @harrdy ok, the caps are a bit small, do you have larger ones (10 or 100uF)? GW: exchange the capacitor on the GW radio (>=100uF) and/or power supply (eventually the USB port is too weak?)
                        • H
                          H
                          Harrdy
                          yes, i have a full box of caps in all sizes. i swap the gw cap from 10uF to 100uF and change the large (2meter) usb cable against a short one (1meter). the usb cable is attached to a supermicro x86 board (usb 2.0 port). this can deliver 500mA @ 5v
                          	Aug 14, 2018 13:17:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 542441 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                          	Aug 14, 2018 13:17:13	Info	Sensor variable	 Serial   9:TestBoard BMP180   1:1939766 TSF:MSG:READ,9-9-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                          	Aug 14, 2018 13:17:13	Info	Sensor variable	 Serial   9:TestBoard BMP180   0:1939775 TSF:MSG:READ,9-9-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 23.4
                          	Aug 14, 2018 13:17:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 542432 TSF:MSG:READ,9-9-0,s=0,c=1,t=0,pt=7,l=5,sg=0:23.4
                          	Aug 14, 2018 13:17:13	Notice	Node	 Serial   9:TestBoard BMP180	Received	Internal	[Battery level] 94
                          	Aug 14, 2018 13:17:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 542377 TSF:MSG:READ,9-9-0,s=255,c=3,t=0,pt=1,l=1,sg=0:94
                          	Aug 14, 2018 13:17:08	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
                          	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537254 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
                          	Aug 14, 2018 13:17:08	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                          	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537240 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                          	Aug 14, 2018 13:17:08	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.4
                          	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537228 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.4
                          	Aug 14, 2018 13:17:08	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 96
                          	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537170 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
                          	Aug 14, 2018 13:17:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 536145 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                          	Aug 14, 2018 13:17:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 536108 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          	Aug 14, 2018 13:17:05	Notice	Node	 Serial   0	Received	Internal	[Log message] 534134 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          	Aug 14, 2018 13:17:05	Notice	Node	 Serial   0	Received	Internal	[Log message] 534092 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532113 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532072 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          	Aug 14, 2018 13:17:03	Notice	Sensor	 Serial   6:TestBoard BMP180   0:532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:17:03	Notice	Sensor	 Serial   6:TestBoard BMP180   1:532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
                          	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532023 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                          	Aug 14, 2018 13:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
                          	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532012 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 530048 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529998 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529988 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529974 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529937 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529925 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529895 TSF:MSG:PINGED,ID=6,HP=1
                          	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529889 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 528380 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                          	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527849 TSF:MSG:GWL OK
                          	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527846 TSF:CKU:OK,FCTRL
                          	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527842 TSF:MSG:FPAR REQ,ID=6
                          	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527840 TSF:MSG:BC
                          	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527834 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:16:57	Info	Sensor variable	 Serial   7:TestBoard BMP180   1:38654387 TSF:MSG:READ,7-7-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                          	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 526502 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                          	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 526326 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                          	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525798 TSF:MSG:GWL OK
                          	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525796 TSF:CKU:OK
                          	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525792 TSF:PNG:SEND,TO=0
                          	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525789 TSF:MSG:FPAR REQ,ID=6
                          	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525786 TSF:MSG:BC
                          	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525779 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:16:53	Notice	Node	 Serial   0	Received	Internal	[Log message] 522332 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                          	Aug 14, 2018 13:16:53	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                          	Aug 14, 2018 13:16:53	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:16:53	Notice	Node	 Serial   0	Received	Internal	[Log message] 522274 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:16:50	Notice	Node	 Serial   0	Received	Internal	[Log message] 519248 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                          	Aug 14, 2018 13:16:50	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                          	Aug 14, 2018 13:16:50	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:16:50	Notice	Node	 Serial   0	Received	Internal	[Log message] 519189 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:16:47	Notice	Node	 Serial   0	Received	Internal	[Log message] 516157 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                          	Aug 14, 2018 13:16:47	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                          	Aug 14, 2018 13:16:47	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:16:47	Notice	Node	 Serial   0	Received	Internal	[Log message] 516098 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:16:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 513064 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                          	Aug 14, 2018 13:16:44	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                          	Aug 14, 2018 13:16:44	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:16:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 513005 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:16:40	Notice	Node	 Serial   0	Received	Internal	[Log message] 509591 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                          	Aug 14, 2018 13:16:40	Notice	Node	 Serial   0	Received	Internal	[Log message] 509548 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          	Aug 14, 2018 13:16:38	Notice	Node	 Serial   0	Received	Internal	[Log message] 507119 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506473 TSF:MSG:GWL OK
                          	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506469 TSF:CKU:OK,FCTRL
                          	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506466 TSF:MSG:FPAR REQ,ID=6
                          	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506463 TSF:MSG:BC
                          	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506457 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                          nothing has changed
                          • H
                            H
                            Harrdy
                            i also have some 5v to 3.3v DC-DC StepDown breakouts. So i change the gw nrf24 powering source from directly to 3.3v arduino to this breakout.
                            The breakout is powering from 5v arduino.
                            https://www.ebay.de/itm/5Stks-800MA-5V-to-3-3V-DC-DC-Step-Down-Power-Supply-Buck-Module-AMS1117-LDO-MT/273132979923?hash=item3f97fe86d3:g:6GUAAOSwVzRavJuB
                            Unfortunately, this had no success
                            Bus 003 Device 045: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
                            Device Descriptor:
                              bLength                18
                              bDescriptorType         1
                              bcdUSB               1.10
                              bDeviceClass          255 Vendor Specific Class
                              bDeviceSubClass         0
                              bDeviceProtocol         0
                              bMaxPacketSize0         8
                              idVendor           0x1a86 QinHeng Electronics
                              idProduct          0x7523 HL-340 USB-Serial adapter
                              bcdDevice            2.54
                              iManufacturer           0
                              iProduct                2 USB2.0-Serial
                              iSerial                 0
                              bNumConfigurations      1
                              Configuration Descriptor:
                                bLength                 9
                                bDescriptorType         2
                                wTotalLength           39
                                bNumInterfaces          1
                                bConfigurationValue     1
                                iConfiguration          0
                                bmAttributes         0x80
                                  (Bus Powered)
                                MaxPower               96mA
                                Interface Descriptor:
                                  bLength                 9
                                  bDescriptorType         4
                                  bInterfaceNumber        0
                                  bAlternateSetting       0
                                  bNumEndpoints           3
                                  bInterfaceClass       255 Vendor Specific Class
                                  bInterfaceSubClass      1
                                  bInterfaceProtocol      2
                                  iInterface              0
                                  Endpoint Descriptor:
                                    bLength                 7
                                    bDescriptorType         5
                                    bEndpointAddress     0x82  EP 2 IN
                                    bmAttributes            2
                                      Transfer Type            Bulk
                                      Synch Type               None
                                      Usage Type               Data
                                    wMaxPacketSize     0x0020  1x 32 bytes
                                    bInterval               0
                                    bLength                 7
                                    bDescriptorType         5
                                    bEndpointAddress     0x02  EP 2 OUT
                                    bmAttributes            2
                                      Transfer Type            Bulk
                                      Synch Type               None
                                      Usage Type               Data
                                    bInterval               0
                                    bLength                 7
                                    bDescriptorType         5
                                    bEndpointAddress     0x81  EP 1 IN
                                    bmAttributes            3
                                      Transfer Type            Interrupt
                                      Synch Type               None
                                      Usage Type               Data
                                    wMaxPacketSize     0x0008  1x 8 bytes
                                    bInterval               1
                            Device Status:     0x0000
                              (Bus Powered)
                            probably a issue with the arduino nano clone?
                            • H
                              H
                              Harrdy
                              i have another original arduino uno. so, i build a second gateway with it.
                              nrf24l01+pa directly connected to 3.3v with wires. (100uF between vcc and gnd)
                              Aug 14, 2018 13:48:50	Notice	Node	 Serial   0	Received	Internal	[Log message] 72726 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                              	Aug 14, 2018 13:48:50	Info	Sensor variable	 Serial   7:TestBoard BMP180   1:38654387 TSF:MSG:READ,7-7-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                              	Aug 14, 2018 13:48:37	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
                              	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60128 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
                              	Aug 14, 2018 13:48:37	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                              	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60115 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                              	Aug 14, 2018 13:48:37	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.6
                              	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60103 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.6
                              	Aug 14, 2018 13:48:37	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 99
                              	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60050 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99
                              	Aug 14, 2018 13:48:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 59038 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                              	Aug 14, 2018 13:48:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 59019 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                              	Aug 14, 2018 13:48:34	Notice	Node	 Serial   0	Received	Internal	[Log message] 57044 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                              	Aug 14, 2018 13:48:34	Notice	Node	 Serial   0	Received	Internal	[Log message] 57004 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                              	Aug 14, 2018 13:48:32	Notice	Node	 Serial   0	Received	Internal	[Log message] 55029 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                              	Aug 14, 2018 13:48:32	Notice	Node	 Serial   0	Received	Internal	[Log message] 54987 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 53012 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52970 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                              	Aug 14, 2018 13:48:30	Notice	Sensor	 Serial   6:TestBoard BMP180   0:52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                              	Aug 14, 2018 13:48:30	Notice	Sensor	 Serial   6:TestBoard BMP180   1:52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52912 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52896 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52888 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52838 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
                              	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52822 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                              	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50811 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                              	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50769 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                              	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50754 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                              	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50746 TSF:MSG:PINGED,ID=6,HP=1
                              	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50740 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                              	Aug 14, 2018 13:48:28	Info	Sensor variable	 Serial   9:TestBoard BMP180   1:1939766 TSF:MSG:READ,9-9-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                              	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50475 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                              	Aug 14, 2018 13:48:28	Notice	Node	 Serial   9:TestBoard BMP180	Received	Internal	[Battery level] 94
                              	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50420 TSF:MSG:READ,9-9-0,s=255,c=3,t=0,pt=1,l=1,sg=0:94
                              	Aug 14, 2018 13:48:26	Notice	Node	 Serial   0	Received	Internal	[Log message] 48758 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                              	Aug 14, 2018 13:48:26	Notice	Node	 Serial   0	Received	Internal	[Log message] 48718 TSF:MSG:PINGED,ID=6,HP=1
                              	Aug 14, 2018 13:48:26	Notice	Node	 Serial   0	Received	Internal	[Log message] 48713 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                              	Aug 14, 2018 13:48:24	Notice	Node	 Serial   0	Received	Internal	[Log message] 46737 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                              	Aug 14, 2018 13:48:24	Notice	Node	 Serial   0	Received	Internal	[Log message] 46698 TSF:MSG:PINGED,ID=6,HP=1
                              	Aug 14, 2018 13:48:24	Notice	Node	 Serial   0	Received	Internal	[Log message] 46692 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                              	Aug 14, 2018 13:48:23	Notice	Node	 Serial   0	Received	Internal	[Log message] 45289 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                              	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44651 TSF:MSG:GWL OK
                              	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44648 TSF:CKU:OK,FCTRL
                              	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44645 TSF:MSG:FPAR REQ,ID=6
                              	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44642 TSF:MSG:BC
                              	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44636 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                              	Aug 14, 2018 13:48:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 43259 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                              	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42601 TSF:MSG:GWL OK
                              	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42598 TSF:CKU:OK
                              	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42595 TSF:PNG:SEND,TO=0
                              	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42592 TSF:MSG:FPAR REQ,ID=6
                              	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42589 TSF:MSG:BC
                              	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42583 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                              	Aug 14, 2018 13:48:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 39150 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                              	Aug 14, 2018 13:48:16	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                              	Aug 14, 2018 13:48:16	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                              	Aug 14, 2018 13:48:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 39076 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                              	Aug 14, 2018 13:48:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 36052 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                              	Aug 14, 2018 13:48:13	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                              	Aug 14, 2018 13:48:13	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                              	Aug 14, 2018 13:48:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 35986 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                              	Aug 14, 2018 13:48:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 32973 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                              	Aug 14, 2018 13:48:10	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                              	Aug 14, 2018 13:48:10	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                              	Aug 14, 2018 13:48:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 32902 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                              	Aug 14, 2018 13:48:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 29905 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                              	Aug 14, 2018 13:48:07	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                              	Aug 14, 2018 13:48:07	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                              	Aug 14, 2018 13:48:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 29818 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                              	Aug 14, 2018 13:48:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 26406 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                              	Aug 14, 2018 13:48:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 26364 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                              	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 24090 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                              	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23288 TSF:MSG:GWL OK
                              	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23285 TSF:CKU:OK,FCTRL
                              	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23281 TSF:MSG:FPAR REQ,ID=6
                              	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23279 TSF:MSG:BC
                              	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23273 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                              	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20989 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                              	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20202 TSF:MSG:GWL OK
                              	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20199 TSF:CKU:OK
                              	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20196 TSF:PNG:SEND,TO=0
                              	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20193 TSF:MSG:FPAR REQ,ID=6
                              	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20190 TSF:MSG:BC
                              	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20184 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                              	Aug 14, 2018 13:47:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 17587 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                              	Aug 14, 2018 13:47:55	Notice	Gateway	 Serial	Sent	Internal	[Discover]
                              	Aug 14, 2018 13:47:48	Info	Sensor variable	 Serial   7:TestBoard BMP180   1:38654387 TSF:MSG:READ,7-7-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                              	Aug 14, 2018 13:47:48	Notice	Node	 Serial   0	Received	Internal	[Log message] 11030 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                              	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 34 MCO:BGN:INIT OK,TSP=1
                              	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 28 MCO:BGN:STP
                              	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Presentation	[Repeater node] 2.3.0
                              	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[GatewayTable ready] Gateway startup complete.
                              	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 23 MCO:REG:NOT NEEDED
                              	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 17 TSM:INIT:GW MODE
                              	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 20 TSM:READY:ID=0,PAR=0,DIS=0
                              	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 14 TSM:INIT:TSP OK
                              	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 6 TSF:WUR:MS=0
                              unfortunately somehow makes no difference
                              I think I let the fun with FOTA first and reburn the stock arduino bootloader. The normal sensor transmission works so apparently without problems
                              tekkaT 1 Reply Last reply
                                Try using nrf24 normal module, not PA, on gateway and see if you get better results
                                • H Harrdy
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @harrdy Maybe node & GW are too close - try moving them further away. Also, what RF24_PA_LEVEL setting are you using on your GW?
                                  • H
                                    H
                                    Harrdy
                                    wrote on last edited by Harrdy
                                    i also try different distances, from few cm to a few meters. All nodes were flashed with RF24_PA_LEVEL HIGH. On the gw i try LOW and HIGH
                                    My idea was still to get the Sensebender Gateway to exclude the gateway as a source of error. But I'm not sure if the Sensebender gw supports the nrf24l01+pa. Or i buy another finish builded gateway based on esp8266 (like MDMSGate) or something else ...
                                      Try low power on both radio and put them 3 meters away. Those unshielded pa modules are a pain with higher power settings
                                      • H
                                        H
                                        Harrdy
                                        Your right, it was a power supply issue. I made few changes.
                                        • first step, change back from uno to nano.
                                        • second step, move from nano shield to breadboard
                                        • third step, add a powersupply breadboard shield
                                        • fourth step, add 0.1uF & 100uF cap between gnd and 3.3v
                                        after this, all red flashes are gone (PA LEVEL High). all "NACK" messages have disappeared and never come back until now.
                                        edit: ok, too happy ... wrong wired leds, connected to 3-5 instead of 4-6. red flashes are still alive and my arrest because of the disappeared nack messages? a filter in mycontroller ... :/
                                        i also tried both radios @low with 3 meters distance. same result.
                                          Try a normal radio on gateway instead of the PA lna
